Long story short, had that tranny rebuilt 3 times now. '96 A4 Quattro with the 12V V6. Seems very good now. Shifts great, etc. However:
Now I put an OBD reader on it and it has this P0735 code in it...says "Gear 5 ratio is incorrect." As I understand it, that means the output shaft is spinning at the wrong speed for that ratio. I cannot clear the code. If I erase all codes, the OBD says the erase is successful. If I scan again, immediately, the P0735 is still there...or there again.
I see no problems driving and shifting. So, after having that tranny in & out 3 times, did some sensor just get killed or some wiring go wrong? Or do I have a real mechanical problem?
