Results 1 to 16 of 16
    Veteran Member Four Rings SLC_S4's Avatar
    Jul 15 2007
    2001.5 S4
    Utah
    Front caliper bolts
    What size are the bolts? The only write up that I can find says 7mm hex, but that doesn't work. Anyone know for sure?
    -Seth
    APR Stage 3 - APR Stealth exhaust - APR downpipes - APR Bipipe - APR snub mount - AWE side mount intercoolers - AWE LWFW - RS4 clutch - ITG panel filter - JHM Shifter - Startup Racing Vogtland GT coilovers - Stern adjustable control arms - Fiber Images vented carbon fiber hood - Fiber Images carbon fiber fenders - Recaro Style Topline seats - A bunch of other stuff I can't remember
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: Front caliper bolts
    Quote Originally Posted by SLC_S4 View Post
    7mm? Did you mean 17mm? I've seen 18mm on some and 22mm on others.
    08 S4- Stock SOLD
    Jul 15 2007
    2001.5 S4
    Utah
    Yeah, sorry, I meant 17mm, but that wasn't the right size. I found that mine are 21mm
    -Seth
    Veteran Member Four Rings GQ//S4's Avatar
    Jul 25 2007
    Today?
    North of Seattle in trees, WA
    yeah they're 21mm's on the front, and then the small bolt holding on the brake lines is 13mm I think. The rear calipers require a 13 and 15 mm wrench, and a 7mm allen wrench (male end), if you want to take off the caliper bracket as well at least.
    Amazingly, the s4 is easier to do than the b5 a4.
    - Michael
    Fact: I'm Awesome
    Former: '92 911 C2, 01.5 S4 Stg 3, 00 S4
    I always dreamed of walking on clouds, so I drive on air
    My logic is infallible. Always.
    Grammar Nazi #1
    "I'm too close for missiles, I'm switching to guns!!!"
    Jan 29 2007
    08 S4 00 S4
    MD
    So apparently the Audi parts bin was low stock on bolts during certain production runs..
    Mine are 18mm and I knew some were 22mm, and apparently 21mm..
    08 S4- Stock SOLD
    Veteran Member Four Rings Rapter's Avatar
    May 01 2004
    2009 honda CRV
    Jersey
    Quote Originally Posted by mholme View Post
    Maybe it goes by the build year because mine is a 2000 and it has 18mm also.
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by Rapter View Post
    Maybe, but knowing audi, there's probably no ryhme or reason to it..
    08 S4- Stock SOLD
    Veteran Member Three Rings sjmelling's Avatar
    Jan 06 2010
    Winchester -> Centreville, VA
    So, I'm bringing this thread back from the dead. I had a caliper bolt back out last night at some point. Is the pitch of the threads all the same between the different bolt sizes. If so, what is it?
    Stephen J Melling
    2001.5 Audi S4
    ~~Laser Red Stage 3, Rods, F21's, other stuff and things
    2000 Audi S4
    ~~Hibiscus Red, Silver Interior, 01E, stock AF
    Jan 06 2010
    Anybody? I've got the 18mm bolt. Just trying to save some effort. Don't want to remove the caliper and take the bolt somewhere to match it up
    Stephen J Melling
    2001.5 Audi S4
    2000 Audi S4
    Senior Member Three Rings usmc.S4's Avatar
    Jun 20 2011
    Look em up on ECS. That's where I got mine.
    Veteran Member Four Rings Timtheguru's Avatar
    Dec 30 2009
    2001.5 And was an 18mm head, I think they are M14 bolts though...
    2001.5 S4 Sedan
    2002 A4 Avant 1.8t - Traded in
    2001.5 A4 1.8t - Sold for $5
    2013 Q7 TDI Premium Plus (RIP, rear ended and totaled, assholes)
    2013 Q7 TDI Prestige S-Line
    2018 Q5 2.0t
    2022 e-Tron Chronos Edition
    Jun 20 2011
    14x1.5x38 part number N90876802
    Jan 06 2010
    Thanks man. I did end up looking on ECS and ordered 1. Was going to post back up if it fit correctly.
    Stephen J Melling
    2001.5 Audi S4
    2000 Audi S4
    Jul 28 2008
    01.5 S4, 09 Touareg, 88 Cabriolet 16vT
    Pittsburgh PA
    i also have a post on how to break them if frozen with sizes, i believe... i had a nightmare breaking the fronts free.
    Latest mod - JHM rebuild kit :swoll:
    Established Member Two Rings 6speeds's Avatar
    Sep 11 2012
    My garage.
    Quote Originally Posted by fshowcars View Post
    Liquid wrench, leverage, and a torch if needed.
    B5 S4 - Stage 2+ - Slow & Loud
    Jun 20 2011
    Soak in PB blaster and work on something else for an hour
