Results 1 to 36 of 36
    Mar 02 2007
    Brisbane, Australia
    Lightbulb DIY: CARBONIO 2.0 + Heatshield + Silicone Intake Pipe
    My objective for this project was simple: Build the best CAI for this car that I could for as little cost as possible !
    Now, before I get started, I would recommend anyone that wants to further discuss/debate the technical aspects of cold air intakes does so in the excellent thread started by Keith of APR:
    http://www.audizine.com/forum/showthread.php?t=257109
    Please take the time to read Keith's thread before starting another Carbonio/Cold Air debate here....
    OK, firstly the Carbonio CAI:
    I did all my research on the Carbonio, read all the conflicting opinions, online debates etc. Given it's cost, it appears to have it's share of fitment issues but I was confident that they could be sorted out with a little TLC & DIY know how.
    Did I go out and buy a new one ? NO WAY !! In Australia, a new Carbonio CAI costs the equivalent of about $460 USD I watched ebay for ages and scored an as new Carbonio setup out of Cananda for a very nice price.
    As I had read, the fitment of the Carbonio is poor. Not much lined up as it should and a lot of twisting and pushing was needed to get the 3 pieces even close to coming together.
    Once in place I wasn't over impressed with a size and quantity of gaps around the inner body work and the edges of the Carbonio air box. Gaps that would invite hot engine bay air to be drawn in to the filter:
    I set out to close these gaps. On the front side of the airbox there is a gap left from the metal tab that is pressed out to locate the Pipercross filter.
    I cut a small piece of scrap alloy angle bracket to fill this one:
    Next, the side piece of the air box need some work in order to get the Carbon Fiber lid to fit properly (approx 6mm recess cut out):
    Even with this, all 3 holes in the CF lid needed to be slotted to get the fitment correct:
    Now after about the 5th test fit, I noticed that the side piece has about 60mm of completely redundant material on the lower end that bolts to the chasis rail. While it was on the bench and I had the jigsaw out, I removed this excess. It made fitment and removal a little easier !
    For the rest of the gaps around the airbox edges, I used generic automotive boot rubber.
    This was easily cut and applied to the airbox edges:
    The Carbonio airbox now sits snugly in the corner of the engine bay and lines up perfectly with the OEM cold air intake duct:
    Mar 02 2007
    Brisbane, Australia
    Re: DIY: CARBONIO 2.0 + Heatshield + Silicone Intake Pipe
    Next on the agenda was the Heat Shield:
    With the turbo & catalytic converter so close to the air box, I wanted to make a more effective heat shield that would also close off the large air gaps at the rear of the Carbonio side panel.
    This is the material I used: http://www.aclperformance.com.au/prod_heatshield.htm
    It's a nice material to work with, easy to bend & curve to the desired shape. Pictures are self-explanatory to the fitment:
    Mar 02 2007
    Brisbane, Australia
    Silicone Intake Pipe was next !
    No doubt inspired by the GSG Intake pipe discussions and the various other DIY jobs that others have posted.
    Firstly, the OEM intake pipe for reference purposes:
    I took a slightly different approach to the other intakes I've seen to date. In my opinion, an alloy pipe with short couplings is not suitable for a Carbonio or OEM airbox fitment as the AFM housing is in a fixed location. The intake pipe, like the OEM part, needs to be flexible. I set out to make a cost effective ALL silicone intake pipe out of 2 silicone elbows. I picked up the following parts from the discount bin at a local auto part shop.
    Total cost of parts was ~$40 USD !
    To work out the fitment, I basically trimmed a small amount at a time, test fitted, cut again, test fit, cut again, test fit, etc... Here is a useful link on trimming silicone joints:
    http://www.siliconeintakes.com/stpg....ddc08a3401bccd
    One method I found effective is that instead of using tape, attach a hose clamp to the position you want to make the cut. Tighten the hose clamp lightly and then cut along the edge of the clamp as a guide. Ensure your knife is new - the sharper the better and less effort required. (and therefore less likely to cut yourself !)
    After many trims and test fits, I concluded that a 45deg bend off the turbo flange just wasn't going to do the job !
    The angle needed to be more so it was back to the store to buy a 90deg 2.5" elbow. Only downer is that it's a different brand and a different shade of blue !
    The angle needed at the turbo inlet was more like 80-85degs so I angle cut the 90deg elbow at the turbo end.
    This allowed the joint to sit up a tad such that everything lined up perfectly:
    While I was at it, I took to the ends of the alloy coupler with a carbide burr in die grinder
    5 minutes later:
    One final tip/observation, T-Clamps are completely unnecessary for this application. In fact, they won't actually fit correctly on the AFM housing and Turbo inlet:
    The width of clamp area on the AFM and turbo inlet are only just wide enough for the traditional hose clamps.
    T-Clamps are too wide and will actually sit OVER the flange bead rather than behind the bead. Not ideal.
    I hope this has helped others with their planned DIY projects. Cheers !
    Veteran Member Four Rings p1nk50ck's Avatar
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    nice writeup. the carbonio really does look good in the engine bay.
    silicone intake pics?
    Dec 07 2008
    Harrisburg, PA
    Quote Originally Posted by p1nk50ck View Post
    +1 but the silicone parts are just for show. No gain in h.p. over the factory elbow but it does look better.
    DUH! an Audi
    los angeles, CA
    great DIY, looks like A LOT of work went into making the intake fit and the silicone pipes fit as well. This guide is not for the faint of heart!
    How do you like it so far? Was it worth it?
    Veteran Member Three Rings audidrver's Avatar
    Mar 31 2007
    CA
    very impressed. Looks very clean too.
    ooooO..................Ooooo
    ...............oooo
    .........o.............o
    Saint Cloud, Fl
    hey man very nice work, looks like fun
    instagram ------------> low_enforcement
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    bravo. informative and brilliant. thank you for a beneficial thread.
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Registered Member Three Rings P3RryaudiA4's Avatar
    Oct 15 2007
    2000 Audi A4 quattro
    Brocktron Ma
    nive work man, you got talent bro...
    Dec 01 2007
    Markham, Ontario
    looks amazing, but too much work for me... too scared to start trimming the metal and carbon top
    2015 BMW M3 Alpine White
    2013 Phantom Black RS5
    2012 Audi TTRS Black / Black - Sold
    Plus One
    Gabriel
    3255 Highway 7 East Unit 159
    Markham Ontario
    Cellular sales / repairs / unlocking / flashing - PM if you need help with anything
    Veteran Member Four Rings CZA420tAvant's Avatar
    May 24 2008
    06 A4 Avant 6MTQ Brilliant Red
    Orange County, NY
    I like that intake pipe. Great write up.
    Driving: 2006 Brilliant Red A4 Avant 2.0TQM
    Revo Stage 2|Carbonio Intake|Stasis SS coils|Podi Gauge|iForged 19"|H&R spacers|RS4 F/R sways|custom inlet pipe|Milltek turbo back with custom twin tips
    Endorsing:
    Veteran Member Four Rings agkellyboy's Avatar
    Feb 27 2007
    2010 S4
    Philly 2 Bmore
    Fantastic write up, might start looking for a Carbonio now!
    FS - Dolphin B7 A4 Ti 2.0T MT6 Quattro Project 400R
    Active Member Four Rings juggernaut201's Avatar
    Dec 12 2008
    06' A4 2.0T 6MTQ
    Jersey
    wow good write up bro lol u beat me 2 it i finished mine today for anyone intrested siliconeintakes.com has everything you need for this and it works perfect did it today all i used was the 3 inch pipe 45 degree angle ... 3 inch jointer ... 90 degree coupler 3 inch to 2.5 i trimed the one hose a little bit but it was realllly simple i used tbolt clamps tho but it worked fine for me lol .... but great write up and i think its def worth it looks so much better i bout all my stuff for 60 ... cant go wrong
    *JUGGERNAUT*
    (Revo Stage II + HPFP File, AWE Cat Back, DMH Performance Electric Cutout, Forge Diverter/Spacer, Carbonio Intake, AWE FMIC, Snub Mount, RS4 Motor Mounts, S4 Big Brake Kit, E Code TestPipe, KW Variant 3 Coilovers, H Sport F & R Sways, KMD Fuel Kit, KMD Cam Follower, NGK Colder Plugs, Boost Gauge, South Bend Stage 3 Clutch, ECS Light Weight Pulley,Custom Inlet Pipe, 034 Street Mount, Apikol Rear Diff Mount, JHM SS Kit W/ Linkage Upgrade And Weighted Knob Lo Jack
    276hp/331tq
    Veteran Member Four Rings LampyB's Avatar
    Apr 25 2007
    MA
    looks very good, nice work man...doesn't look like it was easy. my only complaint is the number of clamps in the final product, just many additional areas that can potentially leak air.
    Custom Trunk Badges For Sale!
    | 2004 A4 USP 1.8TQ | 6SPD | GIAC 1+ | APIKOL | HYPERBOOST | FORGE TIP | NGK | 20% TINT | VMR | OFE SS | PODI | N249 Delete |
    Veteran Member Four Rings Dangler's Avatar
    PA
    Great Job Terry!!! Intake looks great. I'm going to go back and mod the carbonio i have now, to get a better fitment and seal.
    Awesome!!!
    F.T.W.L.T.B.D.W.I.C.T.W
    Dec 12 2008
    06' A4 2.0T 6MTQ
    Jersey
    Quote Originally Posted by LampyB View Post
    it was insanely easy .... and as for the clamps its just because of the jointer so if you think aboyt it its like a solid pipe n e way
    *JUGGERNAUT*
    276hp/331tq
    Senior Member Two Rings dj_dub's Avatar
    Mar 07 2008
    2010 BMW E90 M3, 2001 Mercedes Benz ML430, 2010 VW Tiguan SEL
    Great job! ...makes me wanna change my intake pipe now too!
    2010 BMW E90 M3, 6MT - Space Gray / Fox Red & 2006 BMW E46 M3 Vert, SMG - TiAg / Imola Red
    2008 Audi B7 A4 2.0T Quattro, 6MT - Phantom Black Pearl (sold) | 2000 VW MkIV Golf 1.8T, 5MT - Uni Black (totaled)
    NoFuknJoke | Photographer
    I1I1III
    Deactivated Three Rings
    Nov 28 2008
    2005.5 Audi A4 2.0T
    Houston, TX
    Love the excellent write-up by DownUnderSLine, especially the excellent photgraphs and mark-ups. Great job!
    Personally, I would not bother with the extra relatively miniscule gains that might be had from the silicone intake pipe. I am not into showing the car to the extent that this pipe, mostly obscured by the system intake from the grille, needs to be changed unless there is something wrong with the OEM ribbed pipe.
    OTOH, the sealing of the gaps and the new heat shield aspect is great work and something I would be very interested in doing. Now I just have to find a Carbonio for a price I am willing to pay.
    Side note -- my K&N Filtercharge filter is quite nice so far. Reduces lag at takeoff (slightly) and the engine is a little more lively, even on standard (not sport) shift mode, playing around under 4000 rpm. To me it is worth the $46 I spent. Carbonio will follow chipping, unless someone "gives it away".
    Veteran Member Four Rings Great White's Avatar
    Oct 07 2008
    Pinarello Prince w/Record 10sp
    Raleigh, NC
    Great job man
    Senior Member Two Rings TX-A4's Avatar
    Jan 23 2009
    '07 Titanium A4; '04 WJ; '13 F-250; ‘17 C2S 911
    TX
    These are the best write-ups; no need to read, just look at the pics .
    2007 A4 2.0T-Q, S-Titanium, 6MT, Brilliant red; couple'a mods and a tenacious driver.
    Established Member Two Rings cab7a4's Avatar
    Oct 09 2008
    Southern California
    very very clean!!!gotta get rid of my evoms
    Senior Member Three Rings Grassmonkey's Avatar
    Sep 23 2006
    B7 A4 DTM
    The Netherlands
    I liked what you did!!!
    2006 B7 A4 DTM
    Mods: RS4 Pedals, RS4 side mirrors, RS4 grill, S4 Blades, PSS9's, RS4 rear swaybar, 034 HFC, Milltek Exhaust, ATP GT28RS, S3 Injectors, HPFP, Rennworx RSL 19x9
    Mar 02 2007
    Brisbane, Australia
    Thanks everyone for all the positive feedback !
    It did take some time to do all this but I LOVED EVERY MINUTE OF IT !
    Not hard at all - just a lot of time spent test fitting, thinking, trimming, test-fitting, trimming etc. About a 12 beer exercise over a couple of weekends.
    I've been tinkering with cars and bike for over 25 years and have a nice collection of tools & equipment down in the garage. I get a lot of satisfaction out of working with what I've got and making something better for minimal outlay. Doing It Yourself is what car tuning/mod'ing is all about in my books - a lot more fun than handing over my hard earned to someone else....
    Mar 02 2007
    Brisbane, Australia
    The silicone intake I did last and was mainly done out of interest & curiosity following the numerous discussions around the GSG intake product.
    It only cost me ~$40 USD to gather the needed parts.
    Did it make a difference over the OEM pipe ? Not that I can tell from the butt-dyno. Possibly a minor improvement in low end throttle response but that could just be the sound effects foolin' me.
    The Carbonio, (as well documented), provides a huge increase in induction and DV noise. The sound has changed slightly again with the addition of the silicone intake.
    One thing I plan to do in the near future is capture some temperature data. I have a dual input K-Type thermocouple meter - it doesn't do logging but it will show real time delta between the two probes. It won't be hard to gather some intake air temp vs engine bay temp vs ambient air temp.
    Veteran Member Four Rings autoverruckt's Avatar
    Sep 26 2004
    STL
    thanks for the time and effort put into the write up!
    04 A4 USP 1.8TQ 6MT Silver | GIAC | evo dv
    05 S4 6MT silver
    07 A4 2.0TQ Black | APR93 | Eibach/Koni Sport | oem B7S4 18's
    03 A4 Avant 3.0L Silver | oem B7S4 18's | 10mm rear spacers
    14 A4 2.0TQ Silver | APR93 | S-Line Pkg| Cold Weather Pkg | 12mm rear
    Present:
    20 Q5 Manhattan Gray | Titanium Sport Pkg | Black Optic pkg
    23 S4 Chronos Gray | Premium Plus | S Sport pkg | Sport exhaust
    Nov 28 2008
    2005.5 Audi A4 2.0T
    Houston, TX
    Quote Originally Posted by DownUnderSLine View Post
    Now that I want to see! Thanks again for this great effort.
    Senior Member Two Rings G-Ride's Avatar
    Dec 16 2008
    Imola 2003 A4 1.8TQ 5spd
    Melbourne Australia
    Thumbs up Re: DIY: CARBONIO 2.0 + Heatshield + Silicone Intake Pipe
    Was talking to my mechanic yesterday about the carbonio on my car as i think it pretty much sucks. I think ill be closing it up as you have with the help of this DIY ...
    If you want the carbonio to work even more efficiently, grab a V6 intake snorkle instead of the 1.8. Has a much larger throat on the inlet and is able to ram a much larger volume of air. Cost for the OE part is about 40-50 bucks. He mentioned it does rub slightly on the plastic engine cover which isnt really a big deal. I dont know why they dont pair them up with the intake to begin with!?
    Cheers
    Senior Member Two Rings kitae80325's Avatar
    Mar 31 2008
    07 a4 2.0t, 07 VW 2.5 Jetta
    pasadena, ca
    my carbonio doesn't have carbonio logo on the top? whts up wit dat?
    does anybody else have the samething??
    Veteran Member Four Rings eskimopunk's Avatar
    Mar 26 2008
    63 Ford Falcon Futura Convertible
    Las Vegas
    Quote Originally Posted by G-Ride View Post
    Cheers
    can you use that with the rest of the snorkel for the 2.0T??
    flickr
    "ALL I REMEMBER IS ARGURFIN WITH DRCURITY AND THEM KICKING me out of neptunes i ve had like 6 LIT's biches is crazy my backj fucking hurts" - El_Chapusca
    SBSC Designer
    For awesomeness. Thanks Pat.
    Dec 16 2008
    Melbourne Australia
    Quote Originally Posted by kitae80325 View Post
    It's just a decal anyway. Dont stress.
    Dec 16 2008
    Melbourne Australia
    Maybe look at the V6 3.2lt B7 snorkle. Id imagine it'd be the same airbox design and would fit correctly?
    Sep 17 2008
    san diego, ca
    FYI, by looking at the intake pipe, it looks good but with the metal fitting inside, it actually slows down the air flow... intake pipe should be continious flow. just an FYI
    Veteran Member Four Rings bmc333's Avatar
    Feb 12 2009
    NoVA
    Quote Originally Posted by dlcarreon View Post
    Exactly - that's why the stock intake pipe is one piece. But as he said - no HP gains were expected. Hopefully he didn't lose anything either...
    Established Member Two Rings JHaag13's Avatar
    Dec 09 2008
    2005 Harley Dyna Wide Glide
    Grand Forks, ND
    I tried that alcperformance please to get some of that material and they dont distribute to the U.S. I tried to get my shop to get it for me and they couldn't. Guessing they distribute to Austrailia?
    Audi A4 B7 Dolphin Grey Quattro, APR Exhaust, 034 HFC, 9500i Escort Radar Hardwired w/ Remote, KW V2 coilovers, GIAC x-chip, Forge Diverter Blow-off valve w/ adjustable spacer, Alpine double din, TypeR 12", Polk dxi components, LEDs, APR Snub Mount, APR Carbonio, 35mm Front Sway, 28mm Rear Sway, Dayline Headlights 5000k, S-line converted, converted titanium, Sti coilpacks
