Results 1 to 34 of 34
    Veteran Member Three Rings ItsThat2.0T's Avatar
    Oct 28 2007
    Rhode Island
    Thumbs down oil around cap and all over engine cover!! CRAPPY UPDATE!
    OLD POST
    Ahh crap.
    Well I searched a bit but I'm on my phone so it was a bit difficult.
    As the title says: my oil light has been coming on every 2k miles and today I saw a ton of oil around the cap and on the engine cover.
    I've read this before but I can't remember what its linked to.
    TIA
    '07 Quattro A4 Brilliant Black
    | Premium Package | Carbonio CAI | 35% Tint | Trunk Lid Spoiler | REVO | VMR Vent Boost Gauge |
    2 Pedals.
    Senior Member Two Rings A4CE1's Avatar
    Feb 10 2008
    06 A4 2.0, 03 Wrangler, 96 XJ
    Westchester, NY
    Re: oil around cap and all over engine cover!!
    usually oil all over the engine means your PCV failed. unless its something simpler like a bad seal on the oil cap.
    VW Touareg V10 TDI. Don't mess.
    Past: Stg. 2+ B7 2.0T, B6 A4 1.8T, Allroad 2.7T 6spd (<-monster), Chevys, Jeeps, and a Nissan.
    Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you, Body kits and decals are how much of a mess you leave on the wall.
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    you have 2 things messed up... first... top off your oil. second... get your pcv replaced... seems like you are changing your oil ever 10k and driving your car hard.
    Oct 28 2007
    Rhode Island
    I don't drive hard at all. I think I've only floored it maybe 5 times in 20kmiles that it has.
    Will the PCV be changed under warranty? I'm chipped too so I hope its not a problem.
    Oh, ii didn't put any oil in it but the light went off. I just cleaned the cap with a rag. Hm
    2 Pedals.
    Veteran Member Four Rings eskimopunk's Avatar
    Mar 26 2008
    63 Ford Falcon Futura Convertible
    Las Vegas
    pcv is a warranty thing im pretty sure there is a revised part. i got mine done not too long ago with the same problem now its all fixed
    flickr
    "ALL I REMEMBER IS ARGURFIN WITH DRCURITY AND THEM KICKING me out of neptunes i ve had like 6 LIT's biches is crazy my backj fucking hurts" - El_Chapusca
    SBSC Designer
    For awesomeness. Thanks Pat.
    Senior Member Three Rings HPW's Avatar
    Sep 30 2008
    2013 A3 TDI
    Pasadena, Ca
    My PCV was fixed under warranty at 33k or so. There is a TSB for it. Chip shouldn't be an issue. Get it done soon - the oil out of my PCV caused a coilpack to fail on my car as well.
    Nov 16 2006
    Skokie, IL
    regardless... i'm pretty sure its 2 separate issues... our cars consume crazy oil when breaking in and even after... and the oil outside is related to PCV... PCV is the reason why some oil has been leaked i guess might have to do with your low oil light, i would still immediately drop some oil in ASAP...
    Veteran Member Four Rings redhott06's Avatar
    Mar 15 2007
    2006 A4 2.0t
    Bedford, NY
    Quote Originally Posted by A4CE1 View Post
    look at you charlie..
    pcv/valve cover gasket. replace both via warranty
    06 Brilliant Red A4 2.0T stage2+
    sparco, bbs, revo, stasis
    [email protected]
    Established Member Two Rings Chb04's Avatar
    Jan 12 2009
    11" B8 Sedan , 07" B7 Avant, 11" Jeep Wrnglr Unlmtd
    USofA
    I've been having same issue bought car Pre-owned and have been through 3qrts of oil and have oil all over the top of motor. When I needed the first quart I called dealer and they said normal but 3 qrts in 10,000 mile doesn't sound proper. Goes in Mn. for 45000 mile tune up so I will see what they say and post info.
    Established Member Two Rings snackbarber's Avatar
    Jan 03 2009
    2001.5 S4 brilliant black, 2006 B7 A4 Ocean Blue Metallic Stage 2+
    Hood River, OR
    PCV can be a recall part. I just made my first service appointment and the dealer said that there are recalls for my car for: PCV, fuel pressure regulator, and flash ECU to newer version.
    Veteran Member Three Rings 04Ultrasprt's Avatar
    Jan 13 2008
    North NJ
    yea, its the PCV. HID had a nice write up on doing it yourself, you can even just clean it out for a temp fix if you cant get to the dealer right away.
    Previous rides:
    Lotus Elise - B6 S4 Cab - E90 335i - E46 ///M3 - B6 PES Stage 2 S4
    B6 Nogaro S4 - B5 S4 Stage II - B7 A4 2.0T K04 - B6 A4 1.8T USP
    USP CLUB MEMBER #95
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    Just had my second one fail. Same problem, oil all over the cap and engine cover. Covered under warranty.
    Established Member Two Rings Alecd90's Avatar
    Jul 23 2008
    2008 audi a4 2.0tip s line/ti
    new york
    not to thread jack but i tend to find some oil around my engine cover and cap every now and then ...how much oil are we looking at for a pcv failure??
    Revo 93//awe diverter valve//carbonio cai//awe boost gauge//9500i
    soon to come:stasis exhaust and Street sports
    Dec 25 2008
    VA, USA
    Hey everyone,
    This is my first Audi. I bought a pre-owned 05.5 with 30k mi. I have put roughly 3k on it, and it hasn't consumed any oil. Sanjman's comment concerns me, if my car isn't consuming oil should I be worried?
    05 A4 Quatro2.0T6M Dolphin Gray Tinted APR 93
    Nov 16 2006
    Skokie, IL
    Quote Originally Posted by krkspds View Post
    Hey everyone,
    Yeah I was exaggerating a little up there... you already have 30k on it... it should be broken in by now so thats why you don't notice your car consuming oil. Plus every acts differently in terms of how much oil actually gets consumed... I think majority of the people here change their oils around ever 5K miles just so our cars has fresh oil at all times... especially when chipped, driving hard, etc., as we all love to do.
    Jan 12 2009
    USofA
    Well had the 45k service today and low and behold I had a cracked breather valve pin which was causing the oil spew all over. They replaced the pressure regulator valve, gasket, cleaned engine ,and all was under warranty because there is a TSB on it. So if you have the same issue of oil go to dealer and have them fix!
    Oct 28 2007
    Rhode Island
    Update in first post!
    2 Pedals.
    Active Member One Ring skeefer's Avatar
    Oct 18 2007
    20013 A4 6MT; 2007 A4 6MT
    Ann Arbor, MI
    Does anyone have the TSB # for this issue? My car is currently at the dealer and they are completely clueless ("never saw this issue before"). I brought it in with 45K miles and oil all over the top of the engine and underneath the plastic cover. After asking me if someone had spilled oil on it (um...no) they apparently are in the process of adding dye to detect where the leak is, because they couldn't duplicate it by letting the engine idle for an hour.
    2018 A4 MT6
    2013 A4 MT6
    2007 A4 MT6
    2018 Q5
    2013 911
    Established Member Two Rings kuwaiti's Avatar
    Dec 13 2008
    Kuala Lumpur
    Someone told me that it doesn't matter how many newer version of the PCV they come up with, it's just going to fail eventually. Sort of a design defect that could not be sorted out. I got mine modded, check it out.
    Suppose to take care of the oil leaks and spills around the PCV area, and restore a little of the boost. sigh! still notice some oil stains though
    Oct 28 2007
    Rhode Island
    I'm sitting in Inskip Audi right now waiting for my 25k service to be complete; I also had them check out the oil issues...
    The tech says there is a two part test to see if I am "using" too much oil (which has already been proven):
    1- Drive until the oil light comes on and then call right away
    2- Drive another 650 to see exactly how much oil its burning.
    They said it most likely needs new rings but they cannot do that until this two step test.
    Inskip is a really great place, don't get me wrong, but what the EF!! I don't want to keep driving with this shit wrong, fix my car!!!!
    2 Pedals.
    Oct 28 2007
    Rhode Island
    Fuck?
    The tech just came over and said I'm pushing 20lbs of boost which they saw in the test drive. He asked if I was chipped and I said no haha. He just looked at me until I confessed...the rings aren't covered because of that.
    Any suggestions guys??
    Looks like I'm not buying this car out after lease.....
    2 Pedals.
    Veteran Member Four Rings Grishbok's Avatar
    Apr 15 2008
    Reston
    you can live with it or replace the rings yourself. Great way to learn your way around the engine yknow? If your replacing the rings yourself, you could go with some forged pistons and rods with the money your saving in labor cost.
    2008 A4 Quattro Brilliant Black
    *SOLD*
    StreetTunedTV.com
    You are violating the 3 rules of forum posting.
    1. Title thread appropriately
    2. Use the search first
    3. If you didnt find what you were looking for, its because someone else didnt follow #1.
    Jul 20 2008
    Chicago
    Quote Originally Posted by ItsThat2.0T View Post
    Did they do a cylinder compression leak-down test? What were the results and what are the pressures between cylinders? It would be amazing to me that you need rings (i.e. oil control rings) if the compression rings were not also compromised. The dealer may be reaching at straws and looking for a nice fat arguably useless repair in which to make some $$$ off Audi. Are you BURNING oil or just losing it? How sooty are your tailpipes? Do you have significant or measurable amounts of blue exhaust smoke? Good luck.
    Established Member Two Rings Jedidiah's Avatar
    Jul 17 2007
    07 A4 2.0T SLine, 06 300C SRT8
    Rochester MI
    my dealer had to look up the TSB by VIN. but my car wasn't in the list. So they looked up the 2.0 FSI and were able to find the issue.
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    actually, the 07 models only, came with a different piston design, and thus different rings. i believe (but may be wrong, they dont tell us these things) that its due to improper ring gap size and not due to an inferior design. it is also more common on cars that are driven very easy, or only short trips, as the pistons dont have time to fully expand and seal the combustion chamber. if your driving characteristics are more sporty/aggressive/enthusiastic, or just plain drive more miles/trip, the engine should consume less oil.
    ive actually done this repair to one such vehicle that failed the oil consumption measurement test (2 part 630mi evaluation). there is a tsb for oil consumption which states to do the test (drain oil, measure amount put in, drive 630mi, measure amount drained). all these measurements are to the nearest gram, using an electronic scale, and the scan tool to calculate oil consumption/miles traveled. afaik, the 07's are the only ones that will actually fail the parameters of the test (more than 1 qt/1000mi). once it fails, you have to make a TAC contact, and they then tell you to do the compression test and leak down test. and in my case (compression and leakdown tests passed on the car i did rings on), they still told me to replace the rings. im not complaining cuz it payed 20 hours and was fun to tear apart a 2.0, but the dealer can only really do what they are told to do from Audi of America.
    and yes, since your car is chipped, they can refuse to warranty any engine repairs. be glad they did the pressure regulation valve for you.
    hope this helps. peace.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Oct 28 2007
    Rhode Island
    Thanks for all the input guys. Just an fyi I do not drive hard at all.
    Two last questions:
    -Should I get my chip removed to prevent any (further) damage? Or it won't change anything.
    -I really don't want to keep spending money on all the oil and want the car off my hands. If I give the car back a year early would it be red-flagged for anything that may have me paying for down the road?
    Thanks a lot I really appreciate all the input.
    2 Pedals.
    Oct 28 2007
    Rhode Island
    ttt
    2 Pedals.
    Junior Member Two Rings Esko626's Avatar
    Jan 03 2020
    LA
    I need help ?? Anyone know where it might be comming from http://imgur.com/a/RO4RO2P
    Veteran Member Three Rings Cyrik's Avatar
    Oct 03 2017
    2007 Audi A4 2.0T Quattro
    Quote Originally Posted by Esko626 View Post
    Nice 11 year old thread revival lol
    If you can't tell where a leak is coming from, clean it. Drive it 50-100 miles and check it again. Looks like a bad PCV judging from the fresh looking oil on the cap, read above. Not even a bad leak either.
    Not to be an asshat here but I don't think your engine is from a B7...
    '07 A4 2.0TQ Tip: JHM Stage 2 Tune, 18" Sparco wheels, CTS Turbo 3" HFC w/ 2.5 - 3" custom exhaust, ECS Luft-Technik IC w/ custom AEM intake, GFB DV+, 034 control arms/tie-rods/strut mounts/engine mounts, ECS snub mount, Bilstein B4 shocks, BrakePerformance D/S rotors and have replaced LITERALLY EVERYTHING ELSE.
    Senior Member Three Rings lumberwood's Avatar
    Apr 06 2016
    Hamilton, ON
    Quote Originally Posted by Cyrik View Post
    ^^this - good advice and for sure not a B7 motor.
    That said, is there oil showing anywhere else? Vacuum pump? Rear PCV (breather)?
    Sep 30 2009
    08 A4 2L MT, 87 Jag XJ6, Lex RX350, ~30 Road Bikes, Piper Aztec, Grumman AA1, Zlin242L
    Indiana
    Yes, as stated above clean your engine up and check soon after for the oil leak source.
    Quite often (but not always) this is the result of a faulty PCV valve which VAG refers to as a 'pressure control valve'. Crankcase pressure might be pushing oil past the filler cap.
    In the meantime try this: with engine idling remove the oil filler cap (clean cap and check the rubber gasket). Your engine should stumble with the cap off. Place the palm of you hand over the opening. You should feel some suction. If no suction you need to replace the PCV valve and, while you're at it, replace the the right side front breather check valve (which is part of the crankcase pressure control system).
    If you do feel suction you will still need to assess the function of the two check valves, the one in the right front breather tube going to the pre-TC port, and the other in the PCV valve body going to the IM. If all that works out the cause of your leak is coming from somewhere else.
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by Brillo View Post
    keep in mind we are not sure what engine he has though . Even Early b7 does not have a check valve in the breather tube to the turbo. It is housed in the PCV. ( if we are talking about the same hose )
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Sep 30 2009
    Indiana
    True. Good point Theiceman.
    Oct 24 2015
    Perth, WA
    Yep, but I just replced the whole PCV system including those hoses with the updated parts. One can update to the latest revision, only when all of the other parts are also at that same revision level.
    My respray thread
