Results 1 to 14 of 14
    Apr 18 2007
    LO, OR
    Airbag Control Module Rebuild
    has anyone had success with sending their airbag controller to a company that can rebuild them? I've sent mine to www.airbagsystems.com twice now with no success. I'm willing to try one more time with another company before I buy a new one. Any help would be great. My car wasn't in a wreck or anything, the light just came on and I get the usual bad airbag module code.
    Address 15: Airbags Labels: 8D0-959-655-AI8.lbl
    Part No: 8D0 959 655 G
    Component: Airbag Front+Kopf 2002
    Coding: 00304
    Shop #: WSC 63351
    1 Fault Found:
    65535 - Internal Control Module Memory Error
    00-10 - - - Intermittent
    Veteran Member Three Rings davyboi's Avatar
    Jun 03 2008
    So.CAL
    Re: Airbag Control Module Rebuild
    I just had mine changed 2 weeks ago...damn thing cost me 600 bucks....
    Veteran Member Three Rings BlueturboS4's Avatar
    Feb 21 2006
    2010 s4, 2001 S4, 2002 dakota
    i got the same error!
    Deactivated Four Rings
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    We just replaced one with that same error. Hmmmm.
    Apr 18 2007
    LO, OR
    so none of you have tried sending one in to be rebuilt? I know what the problem is and i know I can buy a new one and fix it, but $50 fix is better than $600 part.
    Veteran Member Four Rings PinoyS4's Avatar
    2018 catalunya RS3
    sf bay area
    have the same error. just been too cheap and lazy to change it
    work hard, play hard[;)
    Jul 26 2008
    Jersey
    I have one for sale. 150 bux
    Veteran Member Three Rings willowtreexx's Avatar
    Feb 27 2008
    2004 GSX-r750
    Chicago/Tampa
    yea i have the same issue and was wondering the same thing...
    for a while ive just been driving with the light on, but if i buy a used one, do i have to VAG it in? or willl it be fine?
    2000 A4 1.8TQ Auto tip
    Unitronics Stage 1 chip / H&R coilovers / 18x8.5 MRR GT1's/35% tint
    Jul 26 2008
    Jersey
    I think you may have to vag-com the new module, but here's how you install it.
    http://www.audiworld.com/tech/elec152.shtml
    Veteran Member Three Rings audikidS4's Avatar
    Sep 03 2008
    2001.5 S4 Avant 6spd - Sil/Blk, 1995 S6 Avant - Blk/Ercu
    Wareham, MA 02571
    Just to Chime-in...same airbag module problem here too...my lights been on for about a year now...
    The original audikid! Coined as ebay username spring 1999.
    **MTM ECU, Piggies, ASP Tru-Duel, Stratmo ss kit, Stern sm, AWE DTS, Voltgland GT2, Neuspeed 19mm RSB, full Samco kit, drilled and slotted rotors, PODI/S-W boost gauge, Sportec pedals, 30% Huper optik, CCMod, stubby antenna, VMR 708s 18X8.5 32mm**
    Aug 20 2007
    2006 Audi A4 2.0T Tip'
    Fitchburg, MA
    Sounds like your unit is defective and not a programming issue.
    Have you tried purchasing a used control module & reprogramming that one?
    Active Member Four Rings nthusiastt's Avatar
    Oct 27 2008
    B5 S4 Avant
    My airbag light flashes speratically only about 25% of the time. Is this the same issue?
    They want you afraid of your neighbors, your community, your family, your ability to support yourself, terrorists, climate change, China, Russia, Covid. As long as you are afraid, and won't unite red or blue, they win.
    Aug 20 2007
    Fitchburg, MA
    Quote Originally Posted by nthusiastt View Post
    The only way to know is to get a vag-com cable and scan the module.
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    We are going to try to source the lowest price possible for this module. Please e-mail [email protected] if you are interested.
