Results 1 to 8 of 8
    Feb 23 2008
    reston VA
    Broke connector housing to coil pack while changing the spark plugs
    I was changing my spark plugs last night and broke a couple of the clips that lock the connector housings on the wiring harness to the coil packs. Is this an easy fix? Can anyone explain how to fix it?
    I also noticed some oil in one of the spark plug wells. Leads me to believe that the gasket is leaking. Is this covered under the certified pre-owned warranty, or should I fix it myself?
    Thanks for the help guys.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: Broke connector housing to coil pack while changing the spark plugs
    CPO should cover the gasket.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Which spark plug. Is it directly adjacent to the oil fill neck. You might get oil in there when filling up oil and it spills over the edge.
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Senior Member Three Rings jessefrank's Avatar
    Jan 09 2006
    Q7.Prestige.S-line.Pkg.2
    Rapid.City
    ...as for those clips....yea...not an easy fix. You have to replace the wiring harness to just replace the connectors (to do it right) or split new sections in (which aren't sold by audi)...so you'd have to splice connectors from a used harness. Either way it sucks and is better left untouched.
    I broke one of mine like 30k ago. Alot of people have this happen due to the plastic getting old and brittle and with how often some of us change plugs. IMO except fo astetic purposes the connectors still work just fine even with that stupid little clip broken. Drink some alcohol and get over it.
    Feb 23 2008
    reston VA
    yeah, it seems to be running fine. With the harness screwed into the valve cover, its not moving very much.
    The spark plug well that had the oil in it was the one closest to the oil fill cap. However, a bit of oil was on the ceramic part of the plug and a bit in the threads of the spark plug...
    Thanks for the help
    Veteran Member Four Rings HeymyAudi's Avatar
    Sep 23 2006
    Las Vegas, NV
    Quote Originally Posted by jessefrank View Post
    YOU DO NOT NEED TO CHANGE THE HARNESS OR SLICE ANYTHING... I had the same problem where the plastic got brittle and just crumbled... My friend at audi changed it for me but you will need a tech to do it becuase of the special tool to align up the pins.... I changed all 4 for $80.00 ( Parts and labor) Its a pretty simple fix but like I said its better if you have a tech do it...
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Is it just one of the tiny little clips that broke - so the connector itself is fine? If so, you can actually use a zip tie to secure the connector to the CP - you'll see how to wrap it when you look at the connector.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Feb 23 2008
    reston VA
    Quote Originally Posted by HeymyA4 View Post
    That's what I was thinking. It looks to me as though it would be a matter of pulling the connecting pins out of the connector housing and putting them in new ones. I have seen the connector housings for sale for around 12 to 15 bucks online. 80 bucks for 4 actually isnt that bad of a deal...
