Results 1 to 16 of 16
    Jun 01 2008
    Apopka, FL
    cam seal replacement tips?
    car has 103k on it and i'm going to replace all the camshaft seals while i have the car apart doing tb and stuff, since this involves removing the sproket, besides making timing marks, anyone have any other suggestions to prevent the cam from moving?
    Apr 18 2007
    ny
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    Jun 01 2008
    Apopka, FL
    Re: cam seal replacement tips?
    you have to remove the bar at some point to take the sproket off, haven't eyeballed it alot.. I'm assuming you're suggesting putting the bar back on when you have the seal semi-on?
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    the cams are keyed for the bar, so if you take the bar off to remove the gears your are ok. the cams wont move when you pull the seal.
    Apr 18 2007
    ny
    I forgot which thread it was, but someone changed they're TB without removing the sprocket, try doing a search on here. If I remember correctly they slipped the belt on but it might be alittle tough.
    SOLD
    Greg
    C5UNION
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    Quote Originally Posted by A62TURBO View Post
    He WANTS to replace the cam seals on his own. he knows the cam seals have nothing to do with Timing belt.
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Apr 18 2007
    ny
    Quote Originally Posted by S4 in_lowplaces View Post
    I KNOW he wants to replace the seals, but he's also asking about keeping the cams in place while takes the sprockets off.
    SOLD
    Greg
    C5UNION
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by blmlozz View Post
    Pull the valve covers off and set the engine to TDC for cyl#1.
    In that position, the driver side exhaust cam keyway should be inline with the arrow on the bearing cap closest to the inter-cam chain.
    The passenger side exhaust cam keyway should also be inline with the arrow on the bearing cap closest to the inter-cam chain. I forget if this chain is up front on the passenger side and out back on the driver side (that is how it is on a 2.8L).
    Take timing belt off
    Take exhaust cam timing belt gears off.
    Loosen up bearing cap closest to cam seal
    Remove cam seal and put new seals in. Retorque bearing cap to proper spec (10Nm?).
    Reinstall cam timing belt gears.
    Replace water pump and timing belt eccentric pulley and gas tensioner.
    Reassemble timing belt and time the engine.
    When reassembling the timing belt make sure the exhaust cams on either head are in-line with the arrow in the bearing cap. that denotes TDC cyl#1 for the heads. Make sure the crank is set to TDC cyl#1 and set tension on the timing belt. The engine is now in 'time'.
    You don't need that cam lock bar if the valve covers are off and you're checking TDC on the heads via the cam keyway and arrow in bearing cap. I just did this including the cam tensioner seals on a B5 2.8L without the cam lock bar and crank lock pin. Its not that hard if you know what you are doing. My friend's 2.8L fired right up and runs solid.
    -Doug
    Jun 01 2008
    Apopka, FL
    this is *exactly* what I'm looking for, since I was planning on removing the valve covers this time around to change the cam plugs and such that I didn't do when I did the cover gaskets, thanks a bunch!
    thanks for the other input as well guys.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Images and what-not are in the Bentley if you have one. Might help relative to a few things I stated. Or, I'm sure someone can post up images from that section of the Bentley. I don't have one. I kind of fly blind and make a few phone calls when I am unsure of something.
    -Doug
    Jun 01 2008
    Apopka, FL
    today's my 21st birthday,so I might try to haggle the old man for a bentley, been needing to get one anyway.
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    Even if the cams move you wont damage anything just move them back with the bar when you are done.
    the 2.7 uses cylinder 3 for tdc
    the cams only go on one way, there is a a little plate that works on the cambar to make sure its aligned. if it moves just align it back with the tool
    Jun 01 2008
    Apopka, FL
    I lack the cambar, something about $180 for a bent piece of $3 steel dosen't sit well with me. :(
    im going to try it without one, since i'm sure it won't be very difficult in the first place, but i'm sure it's fairly simple to make with my machine skills anyway should i need it.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by goohead View Post
    Thank You. I couldn't remember if it was 1 or 3.
    -Doug
    i got my cam bar for about $100 new
