Results 1 to 8 of 8
    Feb 15 2007
    Royal Purple Synchromax
    I was wondering if this stuff is any good? Also, can it be used in a 6-speed manual tranny (B7 RS4)?
    Thanks in advance!
    2007 Audi RS4 - Daytona Grey - Original Owner
    1957 MG MGA 1800 - Austin Healey Spruce Green
    2020 Mercedes-Benz GLC 63 AMG - designo Cardinal Red
    2024 Tesla Model 3 Dual Motor - Stealth Grey
    Feb 15 2007
    Re: Royal Purple Synchromax
    anyone?
    Nov 13 2007
    Chino Hills, CA
    Royal purple is the shit! only ever used in my vehicles and is the best!
    Aug 06 2008
    Canadia
    if the transmission oil is also lubricating the front differential i would use redline MT-90 as its designed to lubricate both differentials and gearboxes.
    the B5 S4 is like the mafia... there is only one way out!
    Feb 15 2007
    It is..... What harm would the synchromax do to the front diff?
    Veteran Member Four Rings Grishbok's Avatar
    Apr 15 2008
    Reston
    ive heard that royal purple failed particular parts of the cold weather testing, I cant find the specific article, however when i red it, it made me switch to red line oil real quick.
    2008 A4 Quattro Brilliant Black
    *SOLD*
    StreetTunedTV.com
    You are violating the 3 rules of forum posting.
    1. Title thread appropriately
    2. Use the search first
    3. If you didnt find what you were looking for, its because someone else didnt follow #1.
    Senior Member Three Rings jessefrank's Avatar
    Jan 09 2006
    Q7.Prestige.S-line.Pkg.2
    Rapid.City
    ...just something to condsider...if you don't have any real reason to change the tranny fluid, why do it? I have a B6 A4...so the gearbox is different. I had the input shaft seal fail, put in some synchromesh (pennzoil) to suffice till I could put in some Redline but now wishing I didn't.
    I used Mt-90 with some Shockproof (as I've read quite a few have done and like) and since I live in E NM which dosen't get real cold. Since doing this over 2 weeks ago my shifting is acutally harsher/harder to engage than the mix of factory/synchromesh filled to the correct levels. Since I just spent the $$ on the redline I'm trying to deal with it hoping it will get better but now wish I would have just left it since it is a "lifetime" fluid anyhow.
    From what I've read on AZ most like Redline or Motul so my case maybe an isolated one. The motul is a bit more expensive, but wish I would have tried the Gear 300 instead of MT-90 or left it alone.
    Also the Synchromax, synchromesh, synchroshift, etc, etc fluids are of a thinner weight than the spec'd 75w90 transmission fluid. If you compare the data sheets they are I'd say around a 20w motor oil where the 75w90 is more like a 10w40. Thinner should result in better shifting but sacrificing overall protection.
    Active Member One Ring Johndrin's Avatar
    Feb 02 2009
    Southeast CT
    just put in royal purple max gear 75w90 in my '01 A6 6 speed tranny and rear differential and it is much smoother when shifting gears. i bought it at autozone for $16 a quart.
