Results 1 to 13 of 13
    Veteran Member Four Rings TH85's Avatar
    Oct 02 2006
    2008 A4 2.0T
    Chicago
    Dashboard lights dont turn off? Need HELP!!!
    I got in my car just now (cold out) and turned on my aftermarket xenons and now my dashboard lights are inverted (bright when lights on) and everything on the dashboard isnt working....speedometer, odometer...
    how do i shut it off? pull the fuse of the dashboard? anyone know what number that is?
    thanks!!
    koni fsd/eibach suspension
    Oct 02 2006
    2008 A4 2.0T
    Chicago
    Re: Dashboard lights dont turn off? Need HELP!!!
    i took out fuse 15 and that turned off the dashboard lights (the lights stayed on when the car is turned off). i then put a new fuse in there and the dashboard lights up so something is wrong. i left the fuse out so i dont run out of batteries....
    what do ya think i should do?
    Veteran Member Four Rings oneohone's Avatar
    Nov 13 2007
    Baur TC2 / W221 S600
    Dallas, TX
    Weird, I think I have the same problem in my S4. Maybe that's why my battery keeps dieing.
    Daily - 00' Audi A4 1.8t Quattro 5mt Laser Red Avant
    In.Progress - 00' A4 2.7t Swap (w/ K04's)
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    check the ground connections on the bulbs. i had a similar issue with led bulbs in the taillights. whenever i would break my entire dash would light up
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Oct 02 2006
    2008 A4 2.0T
    Chicago
    forgot to mentioin that the dash lights dont even turn off when i turn off the car...they stay on, but i took out the fuse so i dont kill my battery
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    Sounds like a broken earth connection.
    Or moisture ingress somewhere...
    Jul 01 2008
    Minnesota
    Yeah I swear aftermarket xenons will make stuff act weird. When i turn mine on some type of warning light will quick flash, it will be either a seatbelt or coolant or oil or brake light.
    Apr 25 2007
    millersville, maryland
    did you just install the xenons?
    Jan 09 2008
    United Kingdom
    I doubt the Xenon's have anything to do with the dash lights remaining on.
    Oct 02 2006
    2008 A4 2.0T
    Chicago
    Quote Originally Posted by keeganhartman View Post
    theyv been in for almost a year...but iv always had problems...i think they messed up the wiring....i always get a "power surge" when i turn them off that resets the radio and sometimes blows the fuse, and now i have a feeling it screwed up my dashboard.
    im taking it in on monday to have the wiring looked at..
    Established Member Two Rings 99A4B5Quattro's Avatar
    Sep 06 2012
    1980 VW Caddy, 1981 VW Scirocco, 1985 Audi Coupe GT
    Georgia
    I hate to revive an old thread, but was anything ever found about this? My interior lights stay on permanently unless I pull fuse 15. No one seems to know anything about it.
    Jun 30 2008
    Erie, Pennsylvania
    Which lights, specifically? The dome lights and footwell lights and such? Trunk lights? (AKA "courtesy lamp circuit"). Or the dashboard "illumination" lights (gauge backlights, radio button backlights, window switches, etc.)
    Sep 06 2012
    Georgia
    The backlighting for radio, vents, HVAC, etc... Dome lights seem to operate normally.
