Results 1 to 22 of 22
    Veteran Member Three Rings jimmya4's Avatar
    Aug 21 2008
    A4 b7
    The OC/ Boulder, CO
    subwoofer box facing forward towards the trunk?
    i have had twin 12's in a ported box in my audi sense i bought it but always had the box facing the trunk. the face of the subwoofers and the large port (releases air) are on one side of the box. problem is, i would need a longer wire to turn the subwoofer box around and face the cabin (long story) should i hunt this wire down and do it? anyone have their subs facing the inside of the car? i would thing that this would slightly help in trunk rattle too? thanks for any input. ill post some pictures for the fun of it pretty soon
    2005.5 Quartz grey A4 Quattro 6mt/ REVO stage II
    Veteran Member Four Rings Erocko's Avatar
    Feb 16 2008
    Honolulu, HI
    Re: subwoofer box facing forward towards the trunk?
    Generally, the sub should always face the trunk, unless u have a custom enclosure that points sideways. Do a google search on it
    Current: 2019 B9 A4 Quattro
    Former: 2016 8V A3 Quattro, 2011 Mk6 GTI DSG 4-door, 2005.5 B7 A4 2.0T FWD CVT
    DUH! an Audi
    los angeles, CA
    it would depend on what subs you are running. if you position the subs towards you, you will not feel it as much as you think it would. The rattle, should be the same because the waves would come back to the trunk. Might help a bit though.
    As the above person said, most people have it facing the trunk, and when it hits, it sends the wave towards you (after whatever can escapes). in this case you can feel it more. Ported boxes should face the trunk, you dont want all that extra air going into the cabin and might not sound as good as before.
    As for that wire, go to radio shack and get some speaker wire, not sure what gauge wire you are using, but buy that and make a longer piece.
    Aug 21 2008
    A4 b7
    The OC/ Boulder, CO
    alright thanks i turned it around facing the trunk. I probably shouldnt start a new thread to ask how you guys are strapping these boxes down. I know alot of guys have built in subs. but for those who just have a box, how did you secure the box from moving around?
    Veteran Member Four Rings nadroj81's Avatar
    Feb 12 2004
    Albany
    Quote Originally Posted by jimmya4 View Post
    Straps to the rear floor hooks
    Veteran Member Three Rings Elohite's Avatar
    Jan 14 2008
    San Antonio, TX
    my box is sideways only for space reasons.
    and Velcro tape from michaels art supply stores secure our subs fine
    Garage Inc | APR | Britalman | 034| Stasis | Volk |Rotora | Deval | EuroGear | DTH | Thule | Forge | BSH | AWE | Evoms | H&R | Pioneer | JL Audio | TMA | ZiZa | KLight
    Veteran Member Four Rings harryd14's Avatar
    Jun 30 2008
    Atlanta, Ga / Norwich, England
    ya the subs should generally be facing the trunk. I also have a ford explorer with a sub in the back and its all open from the back to the front (audi has the seats blocking the way) and when the sub hits, the sound waves bounce off the trunk and then get sent forward to the front of the cabin, and this is the way to get the most from your subs. so i would say dont worry about getting the longer wire, but can always go buy and and try and it out to see how sounds and then if you dont like it as much just swap it back around. it might also not have enough space for the air to move around if its ported and facing the back seats.
    A4 2.0Tq 6spd - Dolphin Grey
    AWE Exhaust - V708 18x8.5 - Dynavin Navi - Carbonio CAI - Blacked Out Grill - Retrofit Bi-Xenons - Passport SRX
    Smoked Reflectors - 7500k Fogs - LED city lights - CF rear lip spoiler - Tint
    Aug 21 2008
    A4 b7
    The OC/ Boulder, CO
    ya i think the best way would to be to srap it down. i used velcro before and that held it so tight that i had to cut the velcro with a knife when i got a flat tire (to remove the sub box to open the hatch for the spare). plus, the velcro would alow it to move just enough to slap both sides of the car, one side has the amp so i dont want that happening. anyone have any pictures of their set ups with a box?
    Senior Member Three Rings BLACKa4QUAT's Avatar
    Mar 26 2008
    union city, ca/fort worth, tx
    the cargo net has always served me well to hold the box.
    mounted my amp to the seat back (the smaller one).
    2006 A4 2.0Tqm, S-line, tech, FH-P8000BT, 10" sub, 800 watt,
    VAG-COM mods (remote windows, no chime), revo stg 1 tweaked
    AWE pedals, HRS4 DTMs/Eagle GT, VMR TP
    193.7 awhp/232 ft/lb/91 oct pre-TP
    16MAR09DSWHTAW
    Feb 16 2008
    Honolulu, HI
    Mine is uber ghetto:
    Veteran Member Four Rings Charlescrs6's Avatar
    Sep 28 2008
    Boston, MA
    I have my sub screwed into the side of the trunk and to the spare cover (the floor of the trunk) using L brackets, then I have the amp screwed to the back of the seat. Works well for me
    Current: ISO RS4
    Past: E46 M3 Convertible 6MT, B6 A4 1.8TQM Ultrasport, B6 A4 3.0Q
    Veteran Member Three Rings festerfm's Avatar
    Feb 07 2008
    just the a4
    northeast pa
    i'll take a better pic tomorrow... they are 12" rocford fosgate punch p1's in sealed box.. box is wide enough to just barely fit between the wheel wells. no probs w/ it moving around. one great thing about the audi... a huge ass box and still plenty of trunkspace!!! i'll try putting up a better pic later!!
    Aug 21 2008
    A4 b7
    The OC/ Boulder, CO
    festerfm nice set up i think thats exaclty what ill do with the cargo net.
    Feb 07 2008
    just the a4
    northeast pa
    the net was mainly to keep stuff from pushing up against the woofers... as you can see, i had a full trunk at the time and didnt want anything rattling.. i usually have the net down.. when there's nothing in there
    Oct 27 2008
    Studio City, California
    leave the subs facing the trunk, This causes a barrier so the sound waves from the bass will bounce off the trunk giving you better sound.. the the only other way i would go would be to custom build a box then port it into the cab of the car, so it would be more like a truck or SUV when it comes to more sound waves and more bass because it has more room to move around and this method also sounds the best... :)
    Established Member Two Rings cab7a4's Avatar
    Oct 09 2008
    Southern California
    cargo net was the simplest and easy idea ...thats what i did
    Veteran Member Three Rings cyanidecologne's Avatar
    Oct 26 2006
    2006 BMW X5 4.4i Sport Package, 2006 Audi A4 2.0T Quattro
    Tustin Ranch, Ca
    Mine face inwards and sound great and yes i have minimal trunk rattle. My box is fully sealed though so i don't know how well it would work with a ported box and your sub setup.
    Built not Bought
    Custom One-Off CSL Style Trunk Lid/Rotiform 19x9.5 ET25 Kandy Purple BLQ/Toyo Proxes 225/35/19/Full Custom Interior/Hotchkis Sways/Tein Coilovers/AWE Boost Gauge/AEM Intake/Britalman Quad Tip + Test Pipe/Revo Stage 2/Custom Paint Color/One-Off Oettinger Kit/Anzo Led Tails/Infinite Auto Design Vented Carbon Hood/Carbon Interior Trim/Carbon S4 Blades/3 Arc Audio 15s /Etc...
    Aug 21 2008
    A4 b7
    The OC/ Boulder, CO
    Quote Originally Posted by festerfm View Post
    where did you attatch the net at the bottom? i see the hooks on the top but i looked in my trunk and there are 4 latches for the four corners of the trunk but none likein the middle area like where you have your net
    Feb 07 2008
    just the a4
    northeast pa
    start w/ u'r trunk empty... take u'r net and hook it at the 4 corners of the trunk. then put u'r subs in on top of the net. once the subs are in, push them back as far as they'll go, then take the front 2 clips and hook them to the roof of u'r trunk.. u'r speakers are actually sitting on top of the net then the net goes up in front of the speakers
    Aug 21 2008
    A4 b7
    The OC/ Boulder, CO
    thanks for that
    Feb 07 2008
    just the a4
    northeast pa
    np... i kinda thought that was a poorly thought way of doing it at first but the elasticity of the net keeps stuff from hitting the speakers and vibrating..
    Feb 16 2008
    Honolulu, HI
    word, I might just try this, since my net is just sitting in that side storage thingy.
