Results 1 to 11 of 11
    Established Member Two Rings Bart-Man's Avatar
    Aug 19 2008
    06 audi a4 2.0T
    Removing ashtray cover?
    How do I go about removing this cover, I use the ashtray to store change and some type of coin fell behind it and now the cover won't go all the back.
    Anyone know how to remove it
    Veteran Member Three Rings grizzles's Avatar
    OC, CA
    Re: Removing ashtray cover?
    I used to store change there until this happened, hopefully someone will answer soon. Mine shuts but there is still change down there.
    Established Member Two Rings cab7a4's Avatar
    Oct 09 2008
    Southern California
    x3 anyone?
    Veteran Member Four Rings apatchin's Avatar
    May 28 2008
    PDX/DEN
    search....
    http://www.carboncopydesigns.com/Ins...on.aspx?type=3
    just go about 1/4 down the page....its can be a bitch so u kinda have to pull harder than u think. good luck
    Veteran Member Three Rings golfvdude's Avatar
    Mar 11 2008
    2006 Audi A4 2.0T
    Abbeville, LA
    Quote Originally Posted by Bart-Man View Post
    That's funny! Same thing happened to me. I'm going to rip it out tonight and get it out. My cover still works the same though, it was just a penny.
    Veteran Member Four Rings eskimopunk's Avatar
    Mar 26 2008
    63 Ford Falcon Futura Convertible
    Las Vegas
    haha i did the same thing... fuckin annoying cos not everything can plug into the lighter down there anymore lol
    flickr
    "ALL I REMEMBER IS ARGURFIN WITH DRCURITY AND THEM KICKING me out of neptunes i ve had like 6 LIT's biches is crazy my backj fucking hurts" - El_Chapusca
    SBSC Designer
    For awesomeness. Thanks Pat.
    Nov 07 2008
    San Francisco
    I pulled up the shifter surround and then iirc there are a couple of torx screws to undo to pull out the entire ashtray.
    notes:
    use both hands at the front of the shifter surround (3 fingers from each hand), and just pull up with some constant force.
    Be careful not to let any of the clips fall off into the shifter area.
    When taking out the ashtray keep it horizontal, otherwise the bits will fall out into the shifter area.
    btw, there's a small plug on the ashtray for the light / power.
    Mar 11 2008
    2006 Audi A4 2.0T
    Abbeville, LA
    Quote Originally Posted by McBadger View Post
    notes:
    Great notes. That actually goes for many cars.
    Veteran Member Four Rings B6bomber's Avatar
    Jan 05 2009
    05 B6 S4; 98 Nissan Altima
    LA area, Back in Simi
    x4 I will try again tonight to pull it up. I have tried before but I feel like I am going to break it.
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    The usual things!!
    Resistor Install
    Veteran Member Three Rings itzjonjon69's Avatar
    Apr 12 2007
    Los Angeles, CA
    well... this happened to me day in my B8 s4 the cover still closes however you can hear the loose change rattling and clanking when driving
