Originally Posted by
Cristisor
For sure that a bad wire can cause this code because the code get's thrown whenever the behavior of the sensor is not as the ECU expects it to be.
ok thanks for the help!! i was inspecting the area today morning, and i noticed an oil hose wasnt connected right, it was extra loose... its the right hose coming from the engine to the plastic intake housing, the plastic part of the intake that connects directly to the throttle body with 2 hex bolts, this hose was leaking oil also so i fixed the plastic connector and reinstalled it..
i dont know if that could have caused the code?? also, yes a noob question here maybe i didnt look hard enough. but i cant find where the tps is!!
i removed my entire intake piping up to the throttle body, i see the throttle body inlet... but no sensor around it. its in a tight spot and im very tall hehe so its kinda hard to get in and find it from above. where exactly on the throttle body is it?
im new to audis or European cars for that matter, so any help is greatly appreciated!
