The SS lines are more to increase brake pedal feel and eliminate any spongy feel, since it does not expand under high pressure (because of the braiding), the next thing you can do is upgrade you brake fluid to a high quality higher temp fluid, this type of race fluid will have a higher boiling point and thus allow you to brake harde and longer before you get any fade (unless you run cheap pads), the downside is it is recomended to flush the race fluids more often than the reg fluids.
As for the power bleeding the opinions vary, I have done both and have not seen any major diff, in both cases you will need to loosen the bleeder valves on each caliper one at a time, run the fluid until the new fluid comes thru.
Key points:
-make sure the reservoir is always full
-be careful, brake fluid is highly corrosive, IT EATS PAINT, as you have seen, so keep lots of brake cleaner spray and towels handy.
-use a small clear tube you put on the bleeder valve to see when all the air is out of the system on each caliper, and when the nes fluid has come thru.
make sure everything is as clean as possible and try to not get any brake fluid anywhere but in the reservoir.
to bleed the brakes without a pressure bleeder, fill the res, close it, pump the brakes (car off), then hold the pedal down to the floor, open the bleeder on the first caliper, wait until the fluid stops running out, close the bleeder, repeat until the new fluid has come thru, close the bleeder, remove the clear hose, clean and move to the next one, repeat for all 4 wheels, remember tyo keep the res full, and the cap on.
Hope this helps.
