Results 1 to 12 of 12
    Veteran Member Four Rings aytheory's Avatar
    Oct 28 2006
    A4 1.8tqm 99.5 aeb ndbw
    Los Angeles / Santa Barbara
    wiring diagram request from ecu to fuel pump relay *updated with car won't start*
    car won't start - not the pump, fuse, possibly not even the relay - could be ecu problem
    thank
    Oct 27 2006
    Pearl 98.5 Audi A4 1.8T
    Fargo, ND
    Re: wiring diagram request from ecu to fuel pump relay
    Are you asking for the electrical schematic? If that's the case, then I have a Bentley that should have everything.
    Which one's do you want
    1998.5 1.8TQT (SOLD)
    Joined the Dark Side
    2008 Honda Pilot SE
    Oct 28 2006
    can i get the ECM diagram
    57/5 and 57/8
    thank
    Oct 27 2006
    Fargo, ND
    Good luck - PM me if you need any others
    2008 Honda Pilot SE
    Veteran Member Four Rings D's Avant's Avatar
    Oct 03 2007
    02 BMW 330i
    Illinois
    Same type of situation happened to me a few years ago. One thing to consider is looking at the connection at your chip. I ended up getting it re-soldered. Problem solved...
    Current '08 A6 Avant S-Line
    Former '99 A4 Avant 1.8t
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    If the car wont start the ECU should throw codes telling you where to look for the issue. Did you also check to see if the CEL light comes on when you first turn the key on?
    Oct 28 2006
    check the connection on my ecu it is good - so a history of the problems
    the car wouldn't start - first thing i checked was fuel pump and there was no pressure going into the lines
    so i replaced the fuel pump - with a walbro and the car still won't start
    i put a 12 v source to the fuel pump and it works perfectly fine and same with the old one (dohhhh)
    next step was the fuse that i checked before it is good
    next was relay it works just fine it opens and close - and has a 12v going through it
    last step was to overide it and the fuel relay engages and the pump turns on - but the car still won't start -
    the problem now is the ecu will not send a signal to the relay for it to close
    there is no cel light either
    Jul 07 2004
    socal
    Re: wiring diagram request from ecu to fuel pump relay *updated with car won't start*
    No CEL at all, including when you first turn the key on?
    Did you check all of the ECU fuses and vag to look for codes?
    Oct 28 2006
    yip no cel before start or after start - doing vag scan now
    Jul 07 2004
    socal
    Quote Originally Posted by aytheory View Post
    If you have no CEL when you turn the key on then you will most likely not be able to connect to the ECU with the vagcom. This will point to a ECu/Chip issue.
    Oct 28 2006
    yah - vag com kept freezing
    final diagnostic can i use someone else ecu that is ndbw - and plug it into my car to try starting it - even if it isn't the correct tune
    Jul 07 2004
    socal
    I would check the solder points on the chip, you can do a continuity test on them to see if one of the solder joints are bad.
