Results 1 to 23 of 23
    Veteran Member Three Rings xileh's Avatar
    Nov 06 2008
    Audi A4 B8 and Audi 100 20vt q
    Norway
    How to remove grill on A4 B8?
    Hello.
    Anybody here that have removed the grill on the new A4? Going to take the grill to have it painted black. Do I have to remove the whole bumper?
    Veteran Member Four Rings oatzel's Avatar
    Jun 02 2004
    LA
    Re: How to remove grill on A4 B8?
    i've only glanced at it, but it looks like it's similar to the b7 and you have to pull the bumper
    Current: '14 allroad, Premium +, Sport, Black on Black, H&R c/o, Magnaflow exhaust, Hotchkis swaybars, Neuspeed Gunmetal RSe102, CR-15
    '19 s4, P+, Quantum Grey on Black
    Old: '12 4dr GTI Autobahn, Black on Black
    07 s4 avant, ibis, stasis exhaust, vogtland c/o, h-sport rs4 sways, vmr gunmetal v710s, 50/35% tint
    09 A4 2.0t
    03 a4 3.0qms
    00 1.8TQ
    Nov 06 2008
    Norway
    Quote Originally Posted by oatzel View Post
    Thats right, hadd to remove the whole bumper Much work just to remove the grill
    Established Member Two Rings erickim080387's Avatar
    Dec 31 2008
    is there a DIY on this forum?
    Nov 06 2008
    Norway
    Quote Originally Posted by erickim080387 View Post
    Couldn't find any DIY, so I just tried. And it ain't that difficult
    Dec 27 2009
    Orland Park, IL, USA
    Quote Originally Posted by xileh View Post
    Could you post a DIY ? With/ without photos ? would be appreciated
    Veteran Member Four Rings Ryan_T's Avatar
    May 11 2009
    09 A4 2.0T
    T.O - Canada
    Once you remove the grille, it's held in by tabs.
    Ryan - flickr
    Veteran Member Four Rings ItsDubC's Avatar
    May 26 2009
    Houston, TX
    I followed a german DIY (translated w/ Google Translate) to try to remove the grille w/out removing the bumper, and concluded that it'd definitely be easier to just remove the bumper to get at the grille. There's a DIY on removing the front bumper on A5OC; I'll see if I can find the link when I have more time.
    OEM+ '09 Meteor Gray A4 2.0T Tip Quattro Prem+ Sport Saloon
    All-Weather Mats • Hüper Optik Stark 30 • APR Stage I • A5 S-line Y-spokes • Hankook Ventus V12 evos • S-line Stone Guards • VAG-COM'd
    Bilstein PSS10s • Eurocode IC Pipe • Avant Dual Exhaust • StopTech Pads • Lamin-X'd • Smoked Ambers • Blesk 5000ks • 034 Trans Mount
    Dec 27 2009
    Thanks bro.
    Veteran Member Four Rings inNout's Avatar
    Jul 22 2009
    IL->WA
    May 26 2009
    Houston, TX
    ^Yup, that's the one. Thx for saving me the legwork
    The "2nd" method I alluded to in that post is indeed pretty hard after having tried it a few weeks ago.
    Jun 20 2012
    Front Grille replacement
    Hi All,
    I might be in the wrong thread, but I want to know if it is possible to replace just the chrome trim that goes around the front grill on a B8. And if so where can i get it. I found the entire front grille at ECS tuning but it seems silly to replace the whole grill just to replace the chrome.
    thanks in advance for any help.
    Senior Member Two Rings simplicity's Avatar
    Aug 24 2011
    SF Bay Area
    I don't think it has its own part # so it wont be sold separately. Your best option is to check your local junk yard for a grill with chrome surround and remove it from that....Otherwise fork out the money to replace the entire grill. FWIW it's a PITA to remove the chrome trim around the grill and it might be worth it to just replace the grill. The OEM grill itself from Audiusaparts is $200.
    2011 Brilliant Black A4 Sedan Quattro | 8 speed tiptronic | P+ | Sports Package
    APR Stage 1, EuroCode Alu Kreuz, Hotchkis F&R Sway Bar, Blesk license plate LED, Hoen Endurance fogs, Reiger Style Trunk Spoiler, RS4 Replica Grill, Podi Boost Gauge
    Nov 21 2016
    WA
    https://www.youtube.com/watch?v=lzqBzJUnx7k
    I'd just mask and plasti dip the chrome portion. No part removal, and less than $10 in cost. Use clear coat if you want it to be glossy.
    Established Member Two Rings Maximoose001's Avatar
    Aug 24 2018
    18' VW Passat R-line, '88 Porsche 911 Carrera (Turbo), '17 Mercedes GLS450, '18 Infiniti QX60
    Lauderdale By The Sea Florida
    Hey,
    I'm going to order a honeycomb RS4 style grill for my 2011 B8 S4 and I found one for a good price on Amazon but in the description, it says for A4 B8. Does the S4 have the same size grill as the A4? It seems like they are the same size; I just wanted to make sure before I order it. Here is the link to it on Amazon ( https://www.amazon.com/Quattro-Plast...=audi+b8+grill)
    If anyone could help it would be much appreciated. Thanks.
    - Max
    Aug 24 2018
    Hey,
    - Max
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    Quote Originally Posted by Maximoose001 View Post
    Hey,
    yes, if its just the grill then itll fit.
    damn 65 bucks?? good find!
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Aug 24 2018
    Quote Originally Posted by JeriQo View Post
    Thank you and yes I was looking at some gloss ones for around $100 or so but then I came across this one and I was like it doesn’t look quite as good as gloss but I figured I’d just wrap the frame gloss black with some extra 3m wrap I have laying around so it all works out.
    - Max
    - Max
    Veteran Member Three Rings Peter.dupuis's Avatar
    Jun 28 2015
    2018 Atlas
    Bend, OR
    There’s a diy link thread in the stickies and it’s in there
    Aug 24 2018
    Hi,
    I’m in the middle of installing an rs4 style grill on my B8 s4 and it didn’t come with mounts for my homelink sensor and the stock mounts don’t fit. Should I just attach it to somewhere else? Or should I just unplug and remove it since I don’t use it (or will that give me an error code?) thanks,
    - Max
    - Max
    Nov 05 2020
    Indiana
    Hi,
    - Max
    What did you end up doing with the homelike sensor?
    Veteran Member Four Rings Spawne32's Avatar
    Nov 20 2016
    zipties dude
    Senior Member Two Rings J.kaseno's Avatar
    Jul 08 2016
    Central Wisconsin
    Hi,
    - Max
    I used some of that 3M 2 sided tape that people use to attach trunk lips and whatnot. Designed for automotive applications. Attached to the back of the crash bar and its Been solid for a year now. make sure surface is clean before attaching.
