Page 1 of 3 123 LastLast
Results 1 to 40 of 117
    Established Member Two Rings dfaudi's Avatar
    Sep 19 2005
    michigan
    Soon to be a GT3076r BAT Member - Q about T3 Treadstone Manifold
    Has anyone used the treadstone manifold? It seems like a really nice manifold and has symmetrical runners, ill assume are better for flow...the price is also not too bad for $309.
    I have the Eurocode/REVO 550 GTRS file (mafless) so im just going to run a cone filter right off the turbo and eventually send my ecu in for the GT30 file when the head is built.
    The problem is that im worried i wont be able to clear the headlight housing.
    http://www.treadstoneperformance.com...Turbo+Manifold
    BAT members please chime in...
    ________________________
    2019: B6 2.1L stroker, 01e, gtx35, 2200cc e85, AEM Infinity - 629 wheel
    2020: B6 K-Swap in progress, 01e, Borg Warner s369 - goal: 1000 wheel
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: Soon to be a GT3076r BAT Member - Q about T3 Treadstone Manifold
    Chris (dirtybrd) runs this manifold with no problems. I believe you need to turn the WG but other than that its fine
    - Clint
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    I'm the only one that runs it other then Dougyfresh. But his is the ASP version with no ext. WG provision and he has an internally gated 28 series on his. I don't see how a filter will fit on there without a 90* down putting the filter right behind the radiator.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Here are some images on placement. Keep in mind this is a 2871R so a 30 series will be much larger.
    This is the best top-down view I have with the headlight installed (single xenon)
    -Doug
    Mar 21 2006
    Lakeland, FL.
    It's funny how much different a 30 series fits.
    I'm back bitches!
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by dirtybrd View Post
    Do you have a picture? I'd like to see how much closer the compressor housing is to the frame rail. My gut feel is that a 3076 will be extremely tight.
    -Doug
    Mar 21 2006
    Lakeland, FL.
    These are all I have.
    I'm back bitches!
    Veteran Member Four Rings DenverNoob's Avatar
    Feb 15 2005
    Other Peoples' Cars
    Dayton, OH
    i know im not running a 30 series turbo (in fact mine is a bit larger on the compressor side) but the treadstone didn't even come close to working for me. The drilled manifold mounts were not precise, the mani would have required alteration to fit my AEB head (some grinding), and overall I was not thrilled with it. Just me, but SPA is a better mani plus top-mount for looks, ease of access and exhaust plumbing.
    USP CLUB MEMBER #26
    2019 SQ5 Prestige - 034 ECU Stage 1, TCU Stage 2
    - a few Golf Rs in-between -
    2004.5 QMT6 Ultrasport Loaded (retired)
    Sep 19 2005
    michigan
    Power/spool wise, what are your opinions on the ATP vs. the Treadstone? Im not trying to squeeze every single pony out of the BAT setup but i dont want to be missing out on 25+ whp by going with the ATP.
    Looking at the treadstone, cyl's 1/4 have equal length runners so the exhuas pulses hit the turbine at the same time with strong blow, and same with 2/3. In contrast, the ATP runners are all different in lenght and seems like cyl 1 will hit and shortly after cyl 4. Same with 2/3. Could that possibly be a favorable pulse distribution?
    I also like where the ATP mani places the turbo, nice and tucked beside the motor.
    What do you all think?
    Sep 19 2005
    michigan
    Quote Originally Posted by DenverNoob View Post
    Vital information. Thanks.
    Mar 21 2006
    Lakeland, FL.
    Odd, it bolted right up for me.
    I'm back bitches!
    Feb 15 2005
    Other Peoples' Cars
    Dayton, OH
    tried 2 even....possibly a bad batch but either way it didnt work.
    USP CLUB MEMBER #26
    Saint Cloud, Fl
    I would reccomend the SPA Manifold also. It is excellent and very easy to install. Plus it places the turbo in a perfect spot for the plumbing
    instagram ------------> low_enforcement
    Jun 29 2007
    Raleigh, NC
    Quote Originally Posted by dfaudi View Post
    the ATP isn't the BEST... but it's certainly not bad. it hasn't let me down and i've had zero problems with it. the T3 ATP mani is much easier to work with than the old eliminator manifold, and i've had no problems with snapped studs or anything like that.
    SPA looks nice, and ATP works well, Full Race is the best performance wise, and to be perfectly honest - if i could do this all again i'd have just gotten a full race and a 35r from the get go. I'm not hte only one with that mindset either...
    do yourself a favor and just go balls out with it now. even if you're not looking to squeeze every last drop out of your setup - you'll still have something to squeeze when you get thirsty again... the rest of us are left with having to buy (very expensive) new fruit.
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by B6Lovin View Post
    interesting setup you speak of
    - Clint
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Equal length of pairs is not the same as having all 4 the same equal length to each other. 2 long and 2 short means the pulse could still hit each other as they enter the inlet of the turbo. You also want the pluse to come in straight which is why a collector tends to be used on high performance manifolds, most of the cast manifolds just turn 90 degs right at the flange.
    Cut-out of a Full-race manifold.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Now that we have had most of the manifold options thrown out on the table lets take a step back and determine what your goals are.
    Your signature says 3076 is your turbo of choice along with a high-rev big port head. Aftermarket camshafts? What do you want to get out of this? Maximum Power? Driveability? etc...
    Having said that one could argue that any of these manifolds work. Everyone has their opinions and everyone has their thoughts on each. Everyone is also hard pressed to push what they have chosen for their own vehicle. I would consider turbo intake routing and downpipe routing in choosing your manifold.
    Charlie. That PagParts manifold looks nice. Reminds me of an APR. I think a fellow B6 on this forum is or will be running that manifold. I can not say who though...
    -Doug
    97 A4 2.0TQM
    Rochester, NY
    Do it!
    Honestly, I didn't notice much of a difference when switching from the ATP to the Full-Race manifold, but the tests they've done prove otherwise. Probably just needs to be re-tuned a lot. The ATP did have a much harder hitting torque peak though, and way lower under hood temps. It (the ATP) didn't fit my huge (extra long) Holset turbo very well though.
    Feb 15 2005
    Other Peoples' Cars
    Dayton, OH
    a pic of the final setup with SPA. As you can see, the turbo sits on top and well forward. Though there is a stainless steel heat shield there, that is how the exhaust pluming runs, so it is a straight shot to an existing exhaust system. In my case, the thermal downpipe was cut and refitted with a 3in DP to a 3in flow race-cat, then mated to the remaining thermal exhaust system (the OE thermal was 2.5in DP, with a 2.25 flow-through flex-joint). Now 3in DP to 3in Flow-through flex to 3in mid-pipe, then the 2.25in split mid-chassis.
    anyways the point here is that the SPA mani puts just about everything in the easiest possible spot to access with one exception (external WG), which if necessary can be accessed via under the car with the belly pan off.
    USP CLUB MEMBER #26
    Registered Member Two Rings b6-sr20det's Avatar
    Dec 27 2007
    Looks awesome guys! I run a gt3076r .63 on my sr20det 240sx track car and jesus! does it hit hard :)
    2002 b6 a4 1.8t - daily driver
    1994 240sx convertible - track/drift weapon!
    Sep 19 2005
    michigan
    [QUOTE=7speed;3215304]I would reccomend the SPA Manifold also. It is excellent and very easy to install. Plus it places the turbo in a perfect spot for the plumbing
    Yeah that does fit pretty nice. Is that compressor housing a 4" on that 3071? Looks like theres plenty of room for a normal-sized cone to go in front of that.
    Is the compressor on the 3076 pretty much the same size/depth?
    Also, does the manifold runner allow for the compressor housing to be clocked so the oulet is facing down a little more?
    Sep 19 2005
    michigan
    Im in the process of determining what cams would go good with the setup (cat 3658s, recommended by chris), but in reading some other threads seems the bugs are not worked out. I have to call Eurocode to see if i can run without vvt and also figure out the warm start issues some are having. I got the head torn apart rigth beside me on my desk and i need to make a move on it. AEB intake manifold and 3076 have been ordered and on the way.
    What are the "best bang for the buck" valve springs/retainers out there?
    My goal is to have a fun daily driver that has a good amount of power to smoke most cars on the road. I rarely go to the track/dyno (however this might change) and im not looking for every bit of horsepower either unless its cost effective.
    I have considered the plumbing of intake/exhuast. Exhaust i currently have is 3" custom to dual 2.25. So im going to fab up the new exhaust to 3076. Intake plumbing: I called eurocode about their GT307r file and they recommend running a maf, (vr6...a restriciton imho) but im going to call them again to verify i can run mafless or at least something bigger...s4? MY goal is to throw a cone filter on the inlet and be done with it.
    Feb 15 2005
    Other Peoples' Cars
    Dayton, OH
    nothing wrong with a MAF...in fact most people worth their salt who actually know what they are talking about would tell you that a MAF is in fact preferable for MANY reasons. Those same people will also tell you that a MAF can be a challenge, more so than running without one. The benefits outweigh the hassle of running one, take my word for it. Any tuner worth what a person would pay them can and should be able to tune around a MAF and give you far better ECU adaptability and part-throttle control. Without a MAF, the maps are the maps, they are largely non-adaptive and can likewise be problematic. Lastly, there is not really any inherent restriction in running a MAF setup. I'm sure someone could certainly dispute that, but I would love to see a tangible difference based upon "restriction" alone. I'm guessing somewhere between slim and none. Believe me when I tell you that the compressor can and does get all of the air it needs.
    just my $.02
    USP CLUB MEMBER #26
    Sep 19 2005
    michigan
    Advice taken.
    However with a VR6 2.75" id maf sufficient? Thats what ECode is tuning with. Is it worth goint to a S4 3" id MAF?
    What i always go back to thinking is this...that if Audi set up a car for X horsepower and is using a 2.75" (VR6 for example) then if im running near double the power, how is that not going to a restriction? Im not saying running double the MAF size, but something larger.
    S4 MAF?
    Sep 19 2005
    michigan
    That turbo shield is a nice piece. You make that yourself?
    You doing lines on your manifold? lol..
    Feb 15 2005
    Other Peoples' Cars
    Dayton, OH
    well if you are going to run a MAF, and again, I would argue the turbo is not being choked in any way, the combination of the sensor and its housing BOTH are part of the load calculation the ECU is seeing. Load calculation is critical to both fueling and part-throttle mapping. There are numerous MAF sensors and housings out there, lord knows on my setup I have tried about four of each to get it right! I have yet to see any data supporting the theory my turbo is not getting enough air. Moreover, I have yet to see another car pull past me thus far! hehehe (I know my days are numbered...but on the kill list in the current state of tune are catless and dinan exhaust e46 m3, several 335is in various states of tune (i.e. vishnu with cat delete and exhaust), a few b5 s4s (none stage 3....still on the prowl for one of those), a number of sti's and evo's, etc etc etc.
    USP CLUB MEMBER #26
    Feb 15 2005
    Other Peoples' Cars
    Dayton, OH
    hahahaha...no....had just finished trimming a few other hoses...forgot it was there!
    USP CLUB MEMBER #26
    Sep 19 2005
    michigan
    DenverNoob,
    Check your PM
    Dec 03 2005
    2 pedals 1FG
    connecticut
    What warm start issues?
    Running without VVT is fine. VVT is only used for cold starts and/or idle.
    just my $.02
    correct - in bold
    For daily drive-ability and part throttle response... Put a MAF in and run all the sensors the engine is designed to use. The software should be written for those sensors anyway and everything is there for a reason.
    Advice taken.
    S4 MAF?
    If you plan on using the REVO software that is currently being developed by EuroCode (the stuff David and Greg are doing) then I suggest you run the MAF sensor and housing that they recommend. The software will be written for a specific set-up and David knows what that is. Contact him before you go buying various MAF housings and sensors...
    -Doug
    Mar 21 2006
    Lakeland, FL.
    The hot start could be related to be Mafless. I can deal with it, a little gas and it fires right up and purrs like a tiger.
    I'm back bitches!
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    my car ever since the 2.0 rebuild, cams, etc. takes a little extra effort to start. Gotta hold the key and turn it over for 2 or 3 seconds half the time, it then idles perfect though.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Sep 19 2005
    michigan
    What exactly is the issue with the hot start? Does it just crank and not fire unless you give it some throttle? And is it an intermittent thing or happen every single time?
    I guess ill be running a maf.
    Sep 19 2005
    michigan
    I guess you just answered that.
    Mar 21 2006
    Lakeland, FL.
    The flash programming just isn't made for adding cams, etc. Adding, cams, P+P head, 2L with no MAF, the ECU doesn't have anything to base start up off of. It's assuming everything is stock still. Adding a BT like the files are designed for doesn't affect cold/hot start up at all. I think this is the reason you can run Mafless on stock motors and get away with it, but motors flowing more air won't.
    I'm back bitches!
    Apr 24 2005
    E55 AMG, CTS-V
    couldnt run mafless on mine stock or built
    ~David~
    CTS-V 9.6@148
    Mar 21 2006
    Lakeland, FL.
    Freak.
    I'm back bitches!
    Apr 24 2005
    E55 AMG, CTS-V
    homo
    ~David~
    CTS-V 9.6@148
    Mar 21 2006
    Lakeland, FL.
    That'd be the pot calling the kettle black, don't you think?
    I'm back bitches!
    Apr 24 2005
    E55 AMG, CTS-V
    lmao, go fly a kite.....
    ~David~
    CTS-V 9.6@148
    Apr 24 2005
    E55 AMG, CTS-V
    There is also the 034 motorsport manifold.
    http://www.034motorsport.com/popup_i...ID=712&invis=0
    ~David~
    CTS-V 9.6@148
