Originally Posted by
400HPA4
$120 is fair for a oil change...
You use nearly $60 worth of oil and filter, 1/2 hour labor to change the oil. At the dealership, it takes several people to do the job.
~You pull into the dealer and talk to the service advisor, he writes up your order (10-15 min)
~The porter comes and gets your car and parks it (5min)
~The service advisor takes the work order to the dispatcher (5min)
~The dispatcher gives the work order to a tech and he calls to the porter to get the car and bring it in (5min)
~The car is either racked or driven over the pit (5-15min)
~The tech goes over to the parts counter and picks up the filter and crush washer (5min)
~The tech drains and changes the oil (15min)
~The tech looks over all of the fluids and inpects everything known to be an issue (5-10 min)
~The tech finishes the car, parks outside and gives the keys and work order to the service advisor (5min)
~The service advisor enters the service and prepares the bill for the cashier (5-10min)
~The cashier takes your money and calls the porter to bring up the car (5-10min)
~The porter washes your car and brings it up (10min)
You then leave..
Typical shop rate is $120hr, they just used 90 minutes of labor and $60 worth of oil on your car.
Total cost to the dealership is $240 and they charged you $120...seems like a pretty good deal to me.
doesn't sound good deal to me at all.
It is SLOW and time consuming for such a small job. (time is money)
jiffylube etc.. do the EXACT same thing for under $60. (also very quick usually finish in less than 30min) including FULL SYNTH oil.
half the price and half the time it takes.
do it in front of your eye.
now that is a better deal.
http://www.jiffylube.com
