Originally Posted by
gointoscott
I had it happen also right after getting chipped. What I did to fix it was sent it back to person who chipped it and had them reflash it. I recommend you do the same. The car will not run right and will be a pain if you leave it like this.
On side note. Did you have the MAF sensor code before hand? You may have a faulty MAF sensor. You can check to make sure its plugged in tightly, may try cleaning it, if that dont work you can try running car with MAF unplugged. It will run better but still not correctly. But at least it will be driveable. If MAF is faulty you will probably have to replace it.
The faulty MAF could be throwing the max charge limit too but I dont think so. I personally think they have a few settings set too high and causing it to overboost throwing it in limp mode and cutting it out until you shut it off and turn back on.
If you have the 00 model S4 or early 01's they usually came with the Bosh MAF which were not as reliable and failed. If you had the newer 01's it has the Hitachi MAF and those were better and lasted longer. I have the 01.5 with HItachi and I still am using stock MAF with no problems.
Our situation seems exactly the same - but I have a 01 A6 2.7T 6spd MT. No, never had a MAF code before and I think my MAF readings used to max out around 220g/sec, now I'm around 266g/sec logged. I have a Hitachi MAF in mine, and I clean it every time I need to take it out, so it should be super clean. Car has 88k miles and I assume it is the original MAF.
This code for me is also usually accompanied with an intermittent 17963 - Charge Pressure: Maximum Limit Exceeded. And the weirdest thing, is that under heavy load and RPM (like 5th/6th gear 4k and above) my ABS and ESP lights come on, and stay on (not flashing).. and will continue to stay on while I am on the throttle. As soon as I let off the throttle and the load / RPMs go down for a couple seconds, the lights come of, get back on it, they come back on. And I am def. not braking traction on the highway at 80, so its not that.
Again all this is only after the APR 91oct chip - before the chip, no issues no codes.
I sent a note to APR to try and sort it out, because when they tried to directport flash it, it bricked the ECU, so they had to send it to APR to be flashed. So really in the end you think the fix is a reflash??
