Results 1 to 9 of 9
    Jul 08 2007
    2018 Camaro ZL1-1LE, 2015 Toyota Tundra
    Asheville, NC
    Serpentine Belt Replacement Help (3.0L)
    My serpentine belt just popped today (fortunately it happened while in my driveway as I was about to leave for work). I've noticed some squeeling over the past week or so (since the weather has gotten colder) and fully intended to replace it this weekend...but the process has been sped up a bit now after some "strong encouragement" from my car. LOL
    Since the belt popped (and was just dangling in my engine bay) I didn't get a chance to look at how it routed. Does anyone have a diagram of the Belt-routing?
    Also...where is the tensioner release? My LS1 camaro uses a standard 3/8" ratchet head to release the tensioner for belt install/removal...but I can't seem to see it on my Audi (visibility and space is limited).
    2018 SQ5
    2018 Camaro ZL1 - 1LE
    2015 Toyota Tundra 1794
    Nov 13 2007
    02 A4 3.0QM, 84 Rabbit GTI
    Gaithersburg, MD
    Re: Serpentine Belt Replacement Help (3.0L)
    According to the manual, you have to compress the tensioner with a VAG special tool. Hopefully someone else can chime in with the garage mechanic method of removal.
    Oct 15 2006
    From a few to one...
    Arlington, VA
    when is it a good time to change this out? should i stick w/ the 1.8t guidelines and do it around 65k?
    just picked up a 3.0 so i'm still learning a few things...
    '97 A4 1.8TQ, '02 A4 1.8TQ Avant, '03 A4 1.8TQMS, '04 A4 3.0Q Cabrio - Sold
    '18 S4 Prestige - APR Stage 1 ECU/TCU, APR Intake
    Jul 08 2007
    Asheville, NC
    Quote Originally Posted by Splattj View Post
    Thanks for the diagram. That was exactly what I needed. Although I'm a little concerned about the "VAG" tool indications. Can anyone offer an alternative method?
    My other concern is why the belt snapped to start with. As I said earlier, I had developed a squeel over the past week or so (belt dressing provided no relief) and I suspect closer examination will reveal a seized pulley (I checked the A/C pulley and the P/S pulley and both spin freely. I doubt its the alternator either as I've had no charging/flickering issues). I expect to find a bad tensioner roller :-( Does anyone know if Autozone, Advanced or Napa carry Audi belts? I just don't want deal w/ the stealership if I can avoid it.
    2018 SQ5
    Jul 08 2007
    Asheville, NC
    Ok, I was able to look at the situation this a.m. in daylight. It does seem that the Tensioner is seized (assuming that it should roll freely with no belt on it).
    It's extremely difficult to see (due to sharp angle/no room), but it almost appears to utilize a standard Allen Head to release the tensioner. Can anyone confirm/deny this?
    Regardless it seems that I will need to replace the tensioner roller assembly...anyone have advice/tips on this?
    2018 SQ5
    Veteran Member Four Rings jdmnomore's Avatar
    Mar 13 2008
    Orlando
    What did the squeeling sound like and where was it coming from. Im in a b6 S4 and having similar issues, the sound is best described as a very loud bumble bee. Im not sure how similar our motors are but mines seems to be coming from the front end of the engine bay close to the drivers side wheel. It also didnt start until it got cold and at one point went away when it got warm now it is persistent. Thx for any info.
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    I really like that diagram
    Feb 22 2008
    03 A4 3.0 6MT
    The Meadows, NV
    you might find some hints in here.
    Active Member Two Rings B-Rob's Avatar
    Mar 13 2008
    Bellevue, WA
    Quote Originally Posted by Ebbsnflows View Post
    I did this a few weeks ago, it was a total PITA at first but piece of cake after I got the right equipment.
    The allen head that you're seeing is either in the middle of the tensioner roller itself (which you'll only need to pull if you actually replace the roller) or the pivot point of the tensioner roller arm/spring (the arm/spring follows more or less the path of the #6 line, down and to the left of the roller).
    There's a little silver block/square thingy an inch or two to the right of the tensioner roller, kind of above the crank. It's very difficult to see from the top, so use one of those mirrors-on-a-stick to find it. You have to grab that with the special $160 Audi tool (in case anyone was wondering why they called it a stealership, my asshole is still sore) and force it down.
    I've heard rumors that it can be done with a 19mm socket wrench, but I didn't try it. Although that spring has a LOT of force behind it, and would do some serious damage if the wrench slipped off while your hand was in the wrong place.
    Also, just get the belt from the dealer. I went to Napa and the one they gave me was an inch too short and still like $4 more expensive, and I had to return it anyways.
    '03 A4 3.0 quattro, dolphin gray on ebony
