Results 1 to 26 of 26
Thread: frozen block
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    frozen block
    Left a friend's house Sunday afternoon and the water pump belt made a hell of a noise and went up in smoke. There has been a little coolant leak somewhere so distilled water was added every week or two. On Friday I picked up some UV coolant dye and a black light bulb but went to a gallery opening instead of tearing into it.
    Now the space heater is running full blast in an effort to thaw the garage. I left a few Nalgene bottles full of distilled water around the garage last night to act as melt indicators. The car's temp gauge showed 27f so it might not be too bad.
    Jim
    I Do Werk.
    Jan 25 2006
    A4 2.0T
    MD
    Re: frozen block
    So, no damage?
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: frozen block
    Did you upgrade to the metal impellar water pump? If you're rockin a plastic one it's possible that some ice got in there and cracked the impellar blades.
    Best of luck dude, I'll help if I can, you have my number.
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: frozen block
    I love the bottles as melt indicators... Small things like that are what set aside an engineer from a tech... Anyway good luck man, I'm sure you'll be fine. Its the beauty of working on your own car that lets you understand what happened when something goes wrong
    - Clint
    Jan 25 2006
    A4 2.0T
    MD
    Re: frozen block
    indeed.
    Mar 09 2004
    nw michigan.
    Re: frozen block
    I can't remember which pump is in there. The heater has been running about a half hour with the new propane tank. It looks like I'll pull the bumper and ac condenser off and use my heat gun to warm the radiator core.
    The block should be empty. It was steaming as we coasted home. At least I've got the UV dye and blacklight now so after wiping it down and checking it over I can leak test it. A friend just dropped off a new belt and jug of coolant. I should have picked up a water pump too but there is no easy way to do that now. If it is bad I'll ride my bike to get one tomorrow morning. That is, unless Dan wants to bring one over and help me wrench tonight.....
    I hope the impeller is ok. The pump was frozen and the pulley didn't move so hopefully the ice didn't crush it.
    Jim
    I Do Werk.
    Mar 09 2004
    nw michigan.
    Re: frozen block
    The slush bombs are working like a charm.
    Jim
    I Do Werk.
    Mar 09 2004
    nw michigan.
    Re: frozen block
    Vents had some coolant residue from the steam.
    Jim
    I Do Werk.
    Mar 09 2004
    nw michigan.
    Re: frozen block
    Here is a clean pic to tide you over while I venture back out to survey the situation.
    Jim
    I Do Werk.
    Oct 21 2004
    99 A4 74 3.0L widebody 911
    Burlington, VT
    Re: frozen block
    I have the same issue... Sucks, I thought I had enough coolant but definetly not! Going home to thaw it now
    Mar 09 2004
    nw michigan.
    Re: frozen block
    It takes a lot of heat. It is very warm in there now and things are still slushy. I'm going to go back out and put the little ceramic furnace in the footwell and aim it at the recirc intake. Then get the defroster blowing on low with the recirc on it becomes a nice little recirculating hotbox. This blows the warm air through the heater core to thaw it.
    Jim
    I Do Werk.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: frozen block
    I wish I would have read this earlier. I gotta run into G-Ville in <1hr and I was busy dealing w/ school crap since I got up (1pm).
    Yea, I'm going back to school. I finally got the balls and motivation to do it.
    Mar 09 2004
    nw michigan.
    Re: frozen block
    Congrats on getting balls. That must make a lot of things easier.
    My neighbor was running errands and picked up a water pump for me. The whole thing too, housing and all.
    It is fully thawed and now I'll pull the bumper, move the ac condenser to the side, and remove the radiator. I can spin the water pump with a cordless drill to see if it does anything. Might as well replace it at this point.
    Jim
    I Do Werk.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: frozen block
    Quote Originally Posted by onemoremile View Post
    When an animal is cornered and given one reasonable option, what outcome would you expect?
    The debt is the only thing I'm worried about though. School payments in 4-5yrs are going to be BIG. Ah what the hell right? By that time I'll be a genius(with at least 2 degrees), and be doing cool stuff.
    Mar 09 2004
    nw michigan.
    Re: frozen block
    Nice. Man with a plan.
    Got it apart and drained. It was just above freezing this morning which will really help. Got the heater going now and will do some work in a moment.
    Jim
    I Do Werk.
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Re: frozen block
    Shitty that this happened. How about an oil pan or engine block heater for the winter nights?
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: frozen block
    Quote Originally Posted by Nebone View Post
    Fixing the coolant leak and therefore not running distilled water would have solved the issue.
    BUT as we all know, there are times where issues that seem small need to be ignored for a task at hand. Sometimes it bites us in the ass, and other times it's not a big deal.
    Like my half moon seal on the timing chain tensioner. I have it, it's like $6-7, I just don't feel like putting it in. It's not really leaking that bad yet.
    Feb 27 2005
    North Wales, PA
    Re: frozen block
    i had a good amount of distilled in my coolant and it froze over one winter. Luckily it was just the heater core that was frozen. It took about 9 hours to defrost.
    Senior Member Three Rings Spykce's Avatar
    Aug 06 2008
    Indiana
    Re: frozen block
    Wow man, hope everything goes smoothly from here on out. I had to drain my girlfriend's cabriolet and put coolant in before winter because of the same leak issue.
    Current Car: 2000 A4 1.8TQ Frankenturbo Build | 2012 Passat TDI
    History: C6 A6 4.2, B7 S4, Mk V GTI, Mk IV GTI Vr6, Audi 80, Audi 4000 Q, B5 A4 1.8TQ x 5, B5 A4 V6, Mk II Cabriolet x 4, B5 Passat 1.8T, Mk II Scirocco, Audi TT 1.8TQ, Mk III GTI Vr6, C5 Allroad 2.7T x 3, '86 VW Quantum Wagon
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: frozen block
    Quote Originally Posted by TomRitt18944 View Post
    your posts are always so random Tom ha. Hows the B5?
    - Clint
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Re: frozen block
    Do those coolant mix testers from AutoZone work on G12 (should). My girls car (12V VR6) has a slow leak and a mix was being added for a few months now.
    Mar 09 2004
    nw michigan.
    Re: frozen block
    I found the leak is at the back of the block. It is where several hoses and connections are in a small area so this kinda sucks. It almost looks like one of the metal retaining clips is missing. That UV dye is some good stuff.
    The car has been running fine for about 5 hours now. I returned the water pump. Total cost was about 35 bucks for a belt and coolant.
    Jim
    I Do Werk.
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    Re: frozen block
    i'd like to know too. im in the exact same boat
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: frozen block
    That coolant flange is a PITA on facelift cars, you might be lucky b/c you're an AEB though(easier).
    Do you have a mirror to look around back there? I've seen those flanges crack, O-rings leak and the plastic clips holding the CTS in break.
    I forget how much I paid for mine, but they're not unreasonable. Make sure you save or replace the O-ring for the CTS if you pull it out. Otherwise you'll have a bigger mess than you had before. I did that myself once.
    Oct 21 2004
    Burlington, VT
    Re: frozen block
    Hahah yea been busy as hell lately, b5 is good, not much new, needs a tune bad as usual
    It warmed up to about 20 yesterday afternoon and that was enough to melt all my frozen water/coolant. Good to go now
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Re: frozen block
    Mr Ritt in tha hoouuusssee!!!
