Page 1 of 3 123 LastLast
Results 1 to 40 of 97
    Mar 11 2008
    B7RS4 & e46Ms
    power steering fluid flush DIY
    I did a search and only came up with a flush for an A8... I used that to do mine, but there are a few differences...
    If I create a write-up w/pics on a doing a ps flush on a B6 3.0L... would anyone use it? Or has everyone just used the A8 flush as a start...
    Update:
    Okay I'll update this with new info as I need to take one or two better pics...
    This was done on a 04.5 B6 3.0L with 32k miles on it. It began making noise when I started it up after thanksgiving... When I checked the fluid, it was low, but after looking at how dirty it was...I couldn't sit idle, especially after hearing about folks replacing pumps/racks/etc... I'd rather just flush it with clean fluid
    Materials/tools needed:
    Pliers
    Flathead screwdriver
    10mm socket & ratchet
    T40 (I'll have to check which one exactly) torx bit (for socket driver)
    4' of clear 3/8" hose
    Male/male 3/8" hose barb adapter
    Golf tee
    Electrical tape
    Milk jug (or some receptacle for the old fluid)
    Small plastic bowl/lid (I used the plastic lid from a can of bondo)
    Brake cleaner
    Paper towels/rags for cleaning any mess
    2 Liters of OEM power steering fluid (part #G-004-000-M2) $18/liter
    (I didn't realize this was so blurry...I'll take another one)
    Procedure:
    First, remove the single screw holding the plastic shroud on the driver's side of the engine.
    Next, remove the two top screws that hold the driver's side headlight in place, and then loosen (don't need to remove) the two lower screws holding the headlight in place (4 total for headlight). There are two plugs directly behind the headlights held by a plastic clip, they'll pop right out. You should be able to pull the headlight out a few inches to make some room. You don't need to unplug anything.
    Once the headlight is out, you’ll have access to a blue reservoir underneath. Pull out the plug assembly going directly into that container. Be careful since the hoses are hard plastic, but the plug in the reservoir should pop straight up, and out.
    Now, take a 10mm socket and remove the two bolts holding the top of the p/s reservoir in place. (For ref: the one with the large rubber spacer is closest to the firewall) Once those are removed, the reservoir should be able to wiggle a bit... If you look at the bottom of the reservoir toward the firewall side, you'll see the last mounting point for it. It's basically just pressed into a rubber mount. Wiggle the reservoir and it'll pop out.
    Now that it's free, you'll need to carefully wiggle the reservoir toward the front of the car, so the p/s hoses are no longer underneath the steel structure...continue moving it toward the front of the car, and move the hoses (going to the blue container) underneath the p/s lines... be careful when you do this part, as the hoses are hard plastic. You should now be staring at something like this:
    Now, locate the smaller hose (closest to the firewall) and use pliers to move the hose clamp down. You should have an idea now of how much open space is below the reservoir...use a dish/pan/tray/something small enough to fit under there, yet hold at least a pint of fluid. (I used the plastic top from a bondo can) Position this directly under where that hose feeds the reservoir. This will catch all the extra fluid in your reservoir. Now pull out the supply hose and drain everything out...should look disgusting...mine looked like this: (with only 32k miles on the clock)
    Now once everything's drained out, take a look inside the reservoir, you'll see the filter in its filthy glory:
    Take your can of brake cleaner and clean the filter, basically just spray it down, and let the excess drain into the collection pan you still have in place. When it's clean, it'll look like this:
    Now grab your golf tee, and your electrical tape. Wrap the tapered (top) portion of the golf tee with about 3-4 layers (winds) of electrical tape. This will help hold it in place, and create a seal to keep fluid from leaking out while you're flushing. Shove that tee into the supply hole of the reservoir so it's nice and snug:
    Next, grab your clear tubing, and your 3/8" hose barb. Insert one end into the clear tubing so it's past at least 2-3 of the barbs (if not all the way) and then insert the other end of the barb into the supply line of your p/s system. Use your pliers to move the hose clamp back up to its original location on the hose to keep it in place:
    Run the other end of the hose into a bucket/jug/something to gather the old fluid:
    You're just about ready to start flushing, fill the reservoir up all the way (not quite to the edge or it could splash out from startup vibration)
    Now you're going to repeat this procedure a few times... Start the engine, from the time it turns over, count to two quickly and kill the engine on two. After a count of 1, it will consume most of the fluid in the reservoir. In your clear hose, you'll see nasty fluid like this:
    Top off the reservoir again and repeat. You'll most likely get more black fluid coming out. On the third cycle, I started seeing green fluid. I also didn't kill it quite soon enough and got some air bubbles along with it:
    I did it quickly, one last time to get all the air out and make sure I was only pushing clean fluid. A total of 4 cycles and all is well.
    Clean-up/Re-assembly
    Now do your best to get all the fluid you can out of the clear hose. Position your plastic tray/cup/etc...Underneath where the two hoses are adjoined. Use your pliers to slide down the hose clamp, disconnect the hoses and collect the extra in your tray. Pull the golf tee out of the reservoir and collect all of that fluid as well. Re-attach the supply hose to the reservoir, move the clamp back up, and re-install everything in reverse order of above. Wait until you have the reservoir mounted before you fill it with fluid again, this time, only fill it to the 'full' mark. Run the car for a minute or so just to make sure you get all the air out of the system and everything’s working okay. Turn the steering wheel back and forth a few times to make sure it works through the rack. Check the fluid level again, add more if necessary, and then continue re-assembly. When re-installing the headlight, pay attention to the body-lines where the headlight lines up with the bumper, as you have some adjustment room with the lower two screws.
    FYI: Here's an excerpt from the Bentley manual on flushing various parts of the system:
    Power steering system, bleeding Different bleeding procedures are required after repairs to the steering system, depending on which components have been removed or replaced.
    After replacement of the entire steering system or steering gear:
    - Check hydraulic fluid level and top off if necessary.
    -Raise vehicle until front wheels are free.
    - Start engine briefly (max. 2 seconds)
    -Pump must not draw in any air; steering wheel must not be turned.
    - Wait approx. 30 seconds each time before starting engine again.
    -Check hydraulic fluid level and top off if necessary.
    -Keep repeating this procedure until fluid level remains constant.
    -With engine switched off, turn steering wheel 10 times from lock to lock.
    -Start engine. Turn steering wheel 10 times from lock to lock.
    -Any air remaining in the steering system will dissipate when the vehicle has been driven 10 to 20 km.
    When other steering components (except steering gear) have been removed or replaced (e.g. pump, hoses, etc.):
    - Pump must not draw in any air; steering wheel must not be turned.
    - Keep repeating this procedure until fluid level remains constant.
    - Start engine and allow to run for 2 - 3 minutes; do not turn steering.
    - Any air remaining in the steering system will dissipate when the vehicle has been driven 10 to 20 km.
    That should be everything. You now have clean fluid, and a smooth running steering system. I used around 1.5 liters total, so you should have 1/2 bottle left for later on. If any of this isn't clear, or you'd like further explaination, please let me know and I'll update it. Gracias.
    Veteran Member Four Rings Dylan's Avatar
    Mar 28 2008
    Re: power steering fluid flush DIY
    kinda strange that there are several people posting about p/s fluids in B6's these days, don'tcha think?
    i'd love a DIY too.
    BRING BACK GCC REP!!
    jason1st: If you just want a good job and to be able to take care of your family with a lot of security etc. Canada is a great place for that.
    If you want to crush your enemies, see them driven before you, and hear the lamentations of their women, then the United States is where you should be.
    (_|_) 4
    Veteran Member Four Rings Boosted3.0's Avatar
    Jul 27 2008
    02 A4 3.0, 08 M5 5.0
    Miami, FL
    Go for it I'll be the first tester once it's written.
    High speed Ferrari movement...
    Junior Member Two Rings K1200GT's Avatar
    May 10 2007
    I'd like to properly flush mine as well.
    2017 A4 Quattro CYMC
    2022 Audi A5 Sportback 40 Miller cycle (Wifes car)
    2011 Audi A4 Quattro stock SOLD
    2002 Audi A4 1.8turbo Quattro Tiptronic SOLD
    APR 93 chipped
    BKR7E's, 710N
    Bilstein HD dampers (struts)
    K&N panel filter, modified stock airbox
    Veteran Member Three Rings Trev's Avatar
    Nov 25 2007
    b6 a4tq, 95 Eagle Talon (Rip)
    British Columbia, Canada
    Might as well.
    Ill be replacing my steering rack in the next week or two, and flushing the ps system will be on my list of things to do.
    Some Go, No show
    02 Qtip, Apr II+ 93Oct, tt-225 injectors, Ecode fmic, W/M Injection, Magnaflow 16601,TT225 Down Pipe, VMR test pipe, APR TIP, Forge 007, Vag-Com, Podi V2, RS4 LSB, ECS Snub, USP front lower, S4 Front Brakes, Slotted/Dimpled Rotors f/r, SS Lines f/r, 19x8.5 & 19x9.5 RPM 505's, RNS-E
    Wish List
    Custom fab intake heat shield, Custom fab system in trunk, Adjustable Coilovers, S4 blades, DTH side skirts
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    Yea im a 3.0 ...go for it....
    Veteran Member Four Rings Frey7190's Avatar
    Feb 27 2008
    is fulla audi parts!
    PLEASE!! You'd make my month! I have 65k on the clock and I REALLY REALLY want to do this, but dont want to hurt my car. So please enlighten us AZ'ers with a b6 P/S DIY
    (as you can tell, I am very excited your doing this... I really want to flush mine!)
    - 2016 VW MK7 GTI Performance Pkg. DSG/Nav/Light pkg/cloth seats.
    - SOLD 2012 Audi TT 2.0T DSG Quattro RNS-E, S-Tronic, Volcano Red, 35% Tint, HID Fogs
    - SOLD 2005 BMW E46 330ci 6mt, K&N intake, //M3 strut brace, SS brake lines, ccfl angel eyes, Stoptech brakes... and more!
    - SOLD 2004 Audi A4 3.0LSport, Automatic CVT, RS4 Sway, Drilled and Slotted Brakes, SS brake lines, RNS-E, E-Codes, Hi-Flo Resonator, Tint 35%, S4 spoiler, HID Fogs, APR Snuby
    Senior Member Two Rings Dopefish's Avatar
    Apr 13 2007
    2003 Audi A4 1.8T
    Orlando, FL
    I'd be willing to do a write-up as I'm due for this service, I just need to pick up some more fluid. From what I remember, it is actually quite an easy task on the B6.
    I need to do my transmission fluid too, then I should be 100% up on my services for at least another 30,000 miles; spark plugs, oil and filters aside.
    1982 Signal Green VW Scirocco
    2004 Tornado Red Triumph Speed Triple : Barracuda CF Exhaust : Woodcraft Clip-Ons : Ermax Undertail
    Audiwissen : Coming soon
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    Nice....Get back to us
    Mar 11 2008
    B7RS4 & e46Ms
    Okay, updated...
    Pos/Neg feedback appreciated.
    May 10 2007
    Oohh that fluid was nasty! Good job!
    APR 93 chipped
    BKR7E's, 710N
    Jul 27 2008
    Miami, FL
    Need more pictures when you pop off the resavoir (spelling). Also which hoses to tap into.
    Mar 11 2008
    B7RS4 & e46Ms
    Quote Originally Posted by Boosted3.0 View Post
    Yeah, those were the ones I realized I was missing... I have placeholders for em
    Veteran Member Three Rings Ultra B6's Avatar
    Sep 05 2007
    New Jersey
    great write up.... looks like i have something to do this weekend!!!
    -James-
    04 Dolphin A4 USP CLUB MEMBER #84 3.0 QUATTRO TIP
    MODS:
    Pics:http://s231.photobucket.com/albums/ee167/ultrab6/
    Apr 13 2007
    2003 Audi A4 1.8T
    Orlando, FL
    Good write up, how much was the mineral oil from the dealer? I have a small container (pint) of G-002 which I think is the non-synthetic used in the B5's but I'll pick up a larger tank of the new fluid from my local dealer. I prefer to go from the PS cooler lines under the car to keep from spilling anything in the engine bay.
    Mar 11 2008
    B7RS4 & e46Ms
    Quote Originally Posted by Dopefish View Post
    It was $18 and some change/liter from the dealer. I really didn't spill anything. A couple drops here and there that wiped up pretty easily.
    Feb 27 2008
    Do u notice the car turning easier and does the P/S system whine/moan when the wheel is turned all the way?
    Feb 27 2008
    Also, instead of having to start and stop the car every two seconds to check the p/s level and top it off, couldn't u just like take the hose insert where you shoved a golf tee and run a hose from it to the p/s fluid in the bottles that way u run the engine once, never worry about the resivour getting air in, and u stop the process the moment you see clean p/s fluid coming out of the pipe?
    Love the DIY, im doing it this weekend for sure! Just thought id put my two cents into the loop hehe
    Senior Member Two Rings Eyerate's Avatar
    Aug 19 2007
    Quote Originally Posted by Frey7190 View Post
    well if the P/S pump still whines, you need a new one. Just wait until it gets really loud lol
    Feb 27 2008
    Oh man I hate my local dealer.. I call asking for 2 liters of P/S fluid and they tell me the price is $26.86/liter! God I hate Socal, everything is so fing over priced.. So now ill have to wait for ECS to ship me some..
    Also I took the dip stick in the PS and took a drop or two and put it on a paper towel and the fluid still looked yellowish.. Like it wasnt at all brown/black like yours..
    Sep 14 2006
    did you go to Walter's in Riverside?
    -Thomas
    Current: /S3
    Previous: B6 A4/B8A4 Avant
    Jun 01 2008
    Apopka, FL
    gave me some ideas for my b5. bookmarked, and good job!
    Feb 27 2008
    Nope, went to Pacific Audi in Torrance...
    Senior Member Two Rings collegedude10's Avatar
    Jan 06 2008
    A5 3.2 6MT, B6 A4 3.0
    wow this is a really good write up.
    2009 Audi A5 3.2 6MT
    hopefully this list grows...
    Jul 08 2009
    Richmond
    Awesome write up! I wouldn't have had the confidence to try this if it wasn't for your step by step.
    Want to add that it is a T30 Torx bit that holds the headlight in, atleast in my case ('02 3.0L), not a T40.
    Oh and for me at least, the 3/8" barb adapter was much too small even with the clamp over it, it would drop in and out with no resistance what so ever, I wrapped it in some electrical tape as well to make it thicker and it held, but still leaked and spurted out quite a bit. I'd recommend the next size up barb if that isn't too large.
    Feb 22 2008
    03 A4 3.0 6MT
    The Meadows, NV
    thanks for the how-to. i'll be doing this myself in the near future, either after steering rack replacement or ps pump replacement (or both).
    Registered User Four Rings greg@podi.ca's Avatar
    Jun 21 2008
    Good writeup
    Jul 27 2009
    Cleveland
    excellent write up
    I bought the fluid and Sunday is p/s flush day
    thanks
    nikola
    Veteran Member Four Rings HotSauce's Avatar
    Jul 26 2004
    Madison
    Curious to hear the results of this. My pump made some god awful sound the other day. Hoping to stop its whining in its tracks.
    Jul 27 2008
    Miami, FL
    If your fluid is really really bad do the flush, wait a few weeks and do it again.
    Veteran Member Four Rings Synthetik's Avatar
    Aug 26 2009
    03 A4 3.0L V6 04 YZF600R
    Colorado
    Just wanted to say this was a great DIY and should be added to the DIY section. Thanks!
    Aug 26 2005
    The transmisson fluid will be dirty black like that too. It needs to be drained/filled a couple of times to get most of the old fluid out. The pan will have l lot of wear particles that settled out of the fluid, the second drain/refill should not have nearly as much. (Pentosin ATF-1 FTW) I need about 8 liters to drain/refill my tip.
    Feb 17 2004
    Liberty Hill, TX
    thanks for this, did this last night on my car and my buddy's. switched over to M1 ATF at the same time too. steering response feels much better now
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    May 21 2007
    Florida
    bringing this back up...is it any different for a 1.8t? also...am i just removing the lines that are attached to the resivoir, blocking one off, and making one longer? theres really no clear pics of the lines that were disconnected. thanks
    2018 Navarro Blue Q5
    Jul 16 2008
    Finland
    You disconnect 1 line from the reservoir and lengthen that line so that once the pump turns it'll pump fluid out of that line into your old oil container or whatever instead of pumping it back into the reservoir.
    Dec 19 2007
    York, PA
    yep...i agree, though, it is tough to see what is going on in the pics.
    May 21 2007
    Florida
    Quote Originally Posted by TDIaholic View Post
    ok thanks, that makes sense. so what line is he sticking the golf tee into to plug?
    and that hose looks like 3/4" not 3/8"...anyone have any insite on this? is it really 3/8"?
    Jun 01 2008
    Apopka, FL
    Quote Originally Posted by doublezero30 View Post
    you plug up the smaller of the hoses obvisully, since a tee wouldn't fit in the larger of the hoses.
    May 21 2007
    Florida
    ohh ok im the idiot as u figured out. i didnt realize he was plugging the resivoir. so take line off, extend line, and plug resivoir where line connected. right?
    Jul 16 2008
    Finland
    Yeah, that's right. Allows you to circulate the fluid into the spare container instead of going back into the reservoir.
