Anyhow, my research will start by searching and Ill post what I find, but I know many people are running some type of aftermarket fuel pump.
A good pic I found;
General information:
This from websearching and quoted from APR:
If the 130 was causing the fplv to stay almost constantly open, the fuel pump would be working like mad to make pressure and there would be all kinds of fluctuations in the rail pressure. When you lift, the injector on time goes to zero and therefore pressure in the rail spikes untill the valve opens. You would be able to see fp logs with a lot of spikes and dips as the fplv opens and closes. The solenoid on the pump is very busy regulating the fp in the rail. When the fplv opens, its like running over a fire hydrant in comparison to its effect on releasing the pressure in the rail. The solenoid on the pump is doing the work of regulating all of the fp in the rail. - Keith@APR
" 1. Our fuel pump is capable of supporting over 500hp (see the graph on the APR website). None of our fuel pump tunes are making near 500hp due to OEM turbo, OEM injector, and OEM knock limitations. So for our fuel pump files where the APR fuel pump is used, we are actually using less pump solenoid duty cycle than an OEM pump because of our increased flow rates.
2. The non-fuel pump tunes actually put more stress on your OEM pump solenoid based on the fact that it is running closer to max flow capacity during the mid-range. This is dictated by marketing demands for good torque and power. However, we have tuned our non-fuel pump files with specific attention to not running the pump at its very limit. This is the reason why there is more area under the curve for the fuel pump file when compared to the non-fuel-pump file. The area under the curve comes from the fact that the APR pump is capable of supporting demand without coming near its absolute flow limit.
3. Fuel rail pressure is mechanically limited by the pressure relieve valve located in the rail. This is a “pop-off” relief valve that will bleed off rail pressure that goes beyond factory specifications. Therefore, give that we are running fuel pressures within this factory limit, and the fact that our pump has more flow for every stroke, this is another reason why our pump is running at less duty cycle than an OEM pump. Fuel pressure is what creates the majority of the load in this system. You can forget about spring pressure and the mass of the piston when you have 120+ bar on the other side of the piston. Since we are running OEM pressures, the chambers of the pump, pump solenoid, pump pulsation damper, etc. are all just fine. " - Mike@APR
----- Things to look for are cam lobe wear, it appears that no matter what fuel pump you use, you will experience cam lobe wear. I have been reading a thread and chris from revo has been commenting about cam lobe with high fuel pumps. Will post more after I am done.
Brands that are out there (no specific order):
APR (APR FSI Fuel Pump)
(from reading) - it appears that APR software in combination their fuel pumps are requesting 130 bar, which can cause excessive cam lobe and failure to pumps.
Stasis (requires bt, dont think they will sell separate)
AWE (requires bt, dont think they will sell separate)
VF (believe they have one and selling with bt)
KMD (KMD FSI Internals upgrade)
This is information quoted from phill@bsh (link to original post)s:
KMD has been very good about sharing information with me about thier new pump offerings.
First and foremost, this is not an AT pump in any way shape or form. This is a 100% KMD pump rebuild kit.
KMD has used hardened tool steel for the construction of its pump, the material and finishing decisions were to made to specifically combat expansion.
KMD will be offering a 1 year warranty on all the parts included in their kit.
In order to achieve the best possible performance from your fuel pump kit, its is important that you have the most updated factory fuel pump and also have your cam lobe inspected for any unusual wear.
The most updated part numbers for the factory fuel pump is 06F 127 025 J, pumps ending with H will also be ok. No warranty claims for earlier pump revisions will be accepted.
This part number is located on the black plastic sensor on the pump itself.
APR customers should be warned that APR's fuel pump programming is extremely aggressive and may lead to a failure of the fuel pump. This is an "at your own risk" scenario. the non fuel pump specific software is not as aggressive and therefore can be used with the same confidence as other programs.
KMD has also released 40% larger FSI injectors, these injectors have currently supported over 400whp on an FSI motor and will very shortly be making there way into my car.
My opinion...I still dont know what to think. No matter what we are all going to guinea pigs on some level. Theyve got 8 months and thousands of miles on their test cars. Ive uploaded the parts to the site, theres no way to know for sure without trying.
-Phill
http://www.bshspeedshop.com/store/home.php?cat=833
Autotech (AutoTech Fuel pump)
I also know that various other companies sell the internals which you could use your stock fuel pump and make it into a high fuel pump.Another thing I know is any FSI fuel pump will work, which makes Audi/VW fuel pumps interchangeable.
Anyhow, hopefully this thread will turn into something positive and anyone who is interested in one can learn.
(Yes, I will search as well and post what I find, also many updates will be added/removed when new information is found or corrected)
-Randy +1 for the community and a great thread =)
