Results 1 to 11 of 11
    Veteran Member Four Rings GTMRS4's Avatar
    Sep 14 2006
    New York, NY
    Map Sensor and Boost Pressure Sensor
    I've read many places and it refers to it differently. The Dealership is telling me the MAP sensor is built into the MAF, but can someone clarify this for me?
    I'm getting weird boost spikes and did a pressure test and no leaks. I either hit 22-20 psi or 19-20psi and no its not the weather. When it got cold i got back to the 21-22 but during the summer I was at 19-20
    BetaAlphaTau # 18
    2007 Q7 4.2 Premium
    2007 997 Midnight Blue
    2005 Lotus Elise Magnetic Blue
    2004 B6 APR STGIII+ (SOLD but not forgotten)
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    Re: Map Sensor and Boost Pressure Sensor
    map and maf are 2 seperate things.
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    I believe the MAP sensor is located right next to the thottle body, and the boost sensor is obviously located on the intercooler
    -Sami-
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    MAP sensor is in the intercooler piping going to the throttle body.
    I think APR gives you a different one to use with the Stage III+
    Mar 31 2004
    CA
    Quote Originally Posted by 400HPA4 View Post
    correct.
    look just below your driver headlight and you will see it plugged into the piping.
    Sep 14 2006
    New York, NY
    so I'd have to contact APR for a new boost sensor?
    BetaAlphaTau # 18
    2007 Q7 4.2 Premium
    Mar 31 2004
    CA
    give em a quick call and ask them. Im sure they will be pretty helpful
    Sep 14 2006
    New York, NY
    so where is the boost sensor?
    BetaAlphaTau # 18
    2007 Q7 4.2 Premium
    Mar 31 2004
    CA
    same thing... located on the IC piping behind driver headlight.
    Sep 14 2006
    New York, NY
    thanks!!!
    BetaAlphaTau # 18
    2007 Q7 4.2 Premium
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    or use a diode on the map wire and a mbc or ebc
    barrett
    2019 SQ5 Prestige
