Results 1 to 16 of 16
    Veteran Member Four Rings Rommulus's Avatar
    Aug 29 2007
    '03 1.8TQM
    Portland, OR
    S-line badge placement (doors)
    I have some s-line badges that i want to put on the rear door moldings of my B6. Can any of you B7 guys take a quick measurement and let me know where exactly OEM placement is? I'm looking for the dimension from the end of the door molding (closest to the rear wheel) to the start (front) of the badge. I want to get the badge placement as close to factory as possible. Thanks for your help fellas!
    Veteran Member Three Rings Larson7.62's Avatar
    May 22 2008
    2008 Audi A4
    Bellevue, WA
    Re: S-line badge placement (doors)
    Do you have a USP? I'll try to get the measurement later tonight
    Brilliant Black 2008 Audi A4 6MT S-Line/APR Tuned/Carbonio Intake
    Veteran Member Four Rings whitevdub's Avatar
    May 10 2007
    Long island
    i sold you those badges didnt i? haha
    Aug 29 2007
    '03 1.8TQM
    Portland, OR
    Indeed you did! Now can you help a brother out with a measurement? Haha
    Aug 29 2007
    '03 1.8TQM
    Portland, OR
    Bump! Come on guys, someone please step outside with a tape measure and give me a hand.
    Veteran Member Four Rings A4A4A4's Avatar
    Jun 02 2008
    Victoria, Canada
    Its kind of awkward to measure because the end of the door blade is diagonal, but measuring from the middle of that diagonal to the start of the badge is 1 7/8" and 4 5/8" to the end of the badge.
    Hope this helps
    -Cam
    New: MK6 Volkswagen GTI
    Old: E92 BMW 335i
    Older: B7 Audi A4 2.0T Quattro
    Jun 02 2008
    Victoria, Canada
    just to make sure you know what I was measuring from
    -Cam
    Old: E92 BMW 335i
    Established Member Two Rings cjnesher's Avatar
    Oct 31 2008
    DG 05 A4 2.0T 07 Passat 2.0T
    Tampa, FL
    What about the trunk badge? I can't find an image of that anywhere. Does the factory sline come with a trunk badge?
    Thanks
    Jun 02 2008
    Victoria, Canada
    there is no sline badge on the trunk, just the grille and side moldings.
    -Cam
    Old: E92 BMW 335i
    Oct 31 2008
    Tampa, FL
    Perfect, that would explain the lack of images. Lots of auctions on ebay selling aline badges.
    Aug 29 2007
    '03 1.8TQM
    Portland, OR
    A4A4A4 - Thanks for the help!
    Jun 02 2008
    Victoria, Canada
    not a problem
    -Cam
    Old: E92 BMW 335i
    Veteran Member Four Rings EMAXX's Avatar
    Jul 12 2008
    If I may ask, why are you putting these badges on? I think the 3rd day I owned the car I took those off.
    2015 Audi S4 Prem+ Sepang Blue/Magma, 6MT, Eurocode Alu Kreuz, Eurocode Transmission Brace, Eurocode Sway Bars and Endlinks, RocEuro Intake, AWE Touring Exhaust
    Jul 14 2009
    Pasadena
    a4a4a4 can u rehost this pic? or rommulus do you have it?
    IG: @matthewee
    Jun 02 2008
    Victoria, Canada
    Quote Originally Posted by itsmatt33 View Post
    Sorry Matt, looks like I've deleted it from my computer. I'll try to recreate it from memory and an old pic though.
    -Cam
    Old: E92 BMW 335i
    Jun 02 2008
    Victoria, Canada
    The greenish line would be the 1 7/8" and the orange line would be the 4 5/8", though make sure you're measuring both from the middle of the side blade diagonal to the middle (height wise) of the badge. I.e. the green line will moved slightly higher towards the orange line in real life, I just wanted to make sure it showed up in the picture so I left some space between them.
    -Cam
    Old: E92 BMW 335i
