Results 41 to 80 of 110
  1. #41
    Veteran Member Three Rings xileh's Avatar
    Nov 06 2008
    Audi A4 B8 and Audi 100 20vt q
    Norway
    Quote Originally Posted by loxxrider View Post
    I can show you what to get for about 1k USD and its a really nice setup with bilsteins. I'll go into more detail after I get home from work.
    That would be very nice. I have startet looking in your thread, and stuff realy looks nice :)
  2. #42
    Jan 18 2010
    Jupiter/Gainesville, FL
    Quote Originally Posted by xileh View Post
    Yes. The car will mostly be used on track, so that's why I wanted Mech header. Also I will start using my KKK KX600 and that turbo is a bit late compered to newer ones. And then I will need to rev a bit high :)
    I haven't made any bushings yet. But I have almost a spare car. So I will use those parts for measuring. I will talk with my friend that got the equipment, if he will make drawings,or how he does it. I guess I will make alu or something for my subframe, and then use delrin for most of the rest in the car. And 034 motorsport track bushings for engine and gearbox.
    I like your goels. A bit similar to me. Start with 600hp in the engine now first. But hope for more later. Will run the car on Ethanol and that gives me more possabilites to get more power easier :)
    I will look at your thread. I have seen pictures of your car before, and it look very beatiful:)
    I will check out motorgeek.
    Yes, info about the coilovers would be great. I have seen on 2bennet. Also a company here in my town build custom bilstein coilovers, but they will cost about 4000USD, and that is guite much I think.
    OK here is a link to everything you should need to know.
    http://vw-rings.com/viewtopic.php?f=...15d95f71c07a7a
    basically you get bilstein sports from shox.com for ~$520 shipped, then 2.5" coil springs of your choice for anywhere from $60 to $270 depending on if you order custom or get good deals on used ones, then about $180 worth of coilover sleeves, collars, etc. from A1racing.com. Its all outlined in the thread above. The only thing it needs after that is some more suspension travel. I'm working on a new upper strut mount that will take care of that.
    Thanks for the compliments on my car. Its much appreciated :) I love the color scheme on your old car. Hope you do something similar with the new one!
    I'm going to run pump gas 93 octane for as much power as I can and then maybe switch over to race fuel whenever I really want to make the big power. I don't think I'll be running around with full power all the time. I'd do E85, but there is almost nowhere to get it around here. I definitely want a set of cams with some seriously high lift. I love the sound of a nice, lopey cam. Gives is a mean sound.
    Looking forward to seeing more updates here! Keep an eye on my thread because everything is going to start happening very soon.
    200 20v - custom coils, big brakes, 67mm turbo :)
    '94 530i MT
  3. #43
    Nov 06 2008
    Norway
    Thank you for the link.
    Guess I will make my own coilovers like you did. But first I have to find a car, and start building. Good to know what weight I end up on before I order springs
    How is your suspension setup? I'm going to use my car only on the track, so I want it as stiff and much handling as possible. won't need any comfort
    Ain't many places to get E85 here. But there is one gas station close to my work that sells this. Guess I just have to get a big can that I can fill up when I'm going to the track
    My cams don't got that high lift, it runs very nice on idle. But they got higher lift than original. Sorry, that I forgot to check what cams I have. But will to this next time I'm at my garage :)
    Right now I'm going to call on a Audi V8 that I might buy for to use as body. Reason I want V8 is wider fenders and stiffer Z frame. And I think the V8 is very similar to the typ44.
  4. #44
    Jan 18 2010
    Yes, the V8 actually is a type 44 so anything you do to a V8 besides suspension will carry over to a 200 20v. They are both type 44's.
    I love the suspension setup. I have 450 in front and 500 in the rear and its pretty stiff, but the ride is nice because of the bilsteins. If you really want to get crazy with it you could do Koni struts but I don't have a parts list for that. Anything over 500lb springs will require either revalved Bilsteins or some Konis. You can get a used set of Bilsteins and send them to Bilstein to get revalved for something like $80 a piece.
    I'd imagine for a track car you might want around 600lb springs. Its hard to say what you'll like though.
    '94 530i MT
  5. #45
    Nov 06 2008
    Norway
    Thanks for the help. Guess I will aske more when I'm ready to build the coilovers :)
    Found some pictures of the car today. Miss it very much :(
  6. #46
    Jan 18 2010
    she was beautiful...I love it
    '94 530i MT
  7. #47
    Nov 06 2008
    Norway
    Thank you :)
    It seems like I won't use a V8 after all. They are much more heavier than the ordinary typ44 due to double floor and stuff like that. So now I have bought a ordinary typ44 Audi 100 with flat fenders. Will pick it up as fast as I have free from work. Much overtime working this month due to holly day.
    I will build V8 rear fenders on this car and use the V8 rear bumper, and try with an 20vt 200 front bumper to see how that looks together :)
  8. #48
    Nov 06 2008
    Norway
    Not so many updates in this thread. Much canges in my project.
    I changed the thread to be about all my cars now.
    The "tricolor" will be a avant in stead. Working on that car right now:
    Also have an Audi 100 10vt sedan quattro:
    And a S2 coupe:
  9. #49
    Nov 06 2008
    Norway
    The avant that is going to get a 20vt engine with about 600bhp:
    The coffee room in our garage ;)
    And the sedan:
  10. #50
    Veteran Member Four Rings Doctor's Avatar
    Jun 02 2008
    A4 B7 20vt Quattro,Golf MKV GT
    Greece
    Love and only Love for these old Audis .
    Audi A4 in an RS4 body
    Mike
  11. #51
    Nov 06 2008
    Norway
    Quote Originally Posted by Doctor View Post
    Agree :)
  12. #52
    Nov 06 2008
    Norway
    Bad luck on a trackday some days ago :(
    Broke the rear left axle :(
  13. #53
    Jun 02 2008
    Greece
    Shit, how did this happen . . .Due to power, or an accident of some kind ?
    Mike
  14. #54
    Nov 06 2008
    Norway
    Maybe both power and a bit bad driving.
    Got a late turn in to a corner, and hit the clutch to make the car oversteer with the diff in. Then the axle broke:(
    Think I got a short clip when this happened. But you don't se it on the video.
  15. #55
    Jun 02 2008
    Greece
    I see. I am sure you will get it sorted and make it stronger for the future. Give us any video available, it is lovely
    Mike
  16. #56
    Nov 06 2008
    Norway
    I got my hands on a original axle today. But later i might be looking for stronger axles.
    My first priority now will be to get the avant finished. Then the s2 will get a makeover i think :)
  17. #57
    Oct 30 2006
    B8 A4 Avant 6spd
    What wheels are those on that Coupe? They look amazing on that car.
    -18 718 GTS
  18. #58
    Nov 06 2008
    Norway
    Quote Originally Posted by Militant-Grunt View Post
    They are Compomotive MO 5 flatface 8x17 ET15 :)
  19. #59
    Nov 06 2008
    Norway
    The S2 is now up and running again. And the 100 avant also runs. Just have to mount the front bakc on the avant, and it is ready for periodic controll :)
  20. #60
    Jun 02 2008
    Greece
    Epic Sexiness . . . I want those wheels so much . .
    Mike
  21. #61
    Nov 06 2008
    Norway
    Just testing the alap recorder app for android.
  22. #62
    Nov 06 2008
    Norway
    Slowly, but the avant is almost ready for controll :)
  23. #63
    Nov 06 2008
    Norway
    Winter tires on the sedan. Used the S2 wintertires to start with.
    Also ordered some serviceparts for the sedan. Timing belt, waterpump and stuff like that :)
  24. #64
    Nov 06 2008
    Norway
    The cars are changed in the garage now :)
    Will have a small service on the sedan
    [ ]Timing belt
    [ ]Waterpump/roller
    [x]Joints outer front on both sides
    [ ]Heater core
    [ ]Some sensores
    [x]Lowering springs
    Lowering spring vs the original in front:
  25. #65
    Mar 10 2009
    il
    That rain dirfting video was interesting. What was your technique for getting the rear out? Was it throwing the weight with throttle, or some clutch kicks?
  26. #66
    Nov 06 2008
    Norway
    Quote Originally Posted by TipTucker01 View Post
    That was my first time testing the car on wet track, so I my technique was not that good. I used the rear diff on. And sometimes used the clutch a bit, but without to much rev.
    The car was not working 100%, so I had trouble getting the rear out with just the throttle. (My mass flow meter was defect)
    But lately I found out it is better to use the weight a bit. Not so much wearing on the clutch and axles :)
    Now it is time for winter here in Norway. No more track days for untill may :(
    But hopfully we get some nice days with driving on Ice :) Don't know if i will use the s2 or 100 tq.
  27. #67
    Nov 06 2008
    Norway
    Found some rust on the front struts. so hadd them welded and paintet :) Not very nice, but better than before.
    The front struts ready
    The rear strut ready
    Lowered in front:
    Forgot to take picture when the whole car was done. The result is 5cm lower in front, and 3 cm lover rear. Hope the last cm will come when the the springs have been on for some days :)
  28. #68
    Nov 06 2008
    Norway
    Some pictures:
    Some of my choises for the avant coilovers:
    2bennett
    Kit with coilovers rear ready to install. And have to build in front. Every part is included. Yellow koni shox. And caster/camber plates in front for good adjustment in wheel angles.
    Price is about 2100 usd
    kw
    Have to send the front struts to them. Regular kw v1 coilovers with tuv papers.
    About 1300usd
    Quattromanufactur
    Coils from eibach or bilstein
    Yellow koni shox, shortened 4 cm and with custom damping rate.
    About 2200 usd
    Build self
    Problem is the upper strut mount.
    Price will vary, depending on what coils and shox i choose. But I guess the price will be about the same as kw.
    What do you think? The car will be used almost only on track.
  29. #69
    Jan 18 2010
    What upper strut mounts do the KW's use
    '94 530i MT
  30. #70
    Nov 06 2008
    Norway
    Don't know. But I can try to send them a email and se if they got any pictures :)
  31. #71
    Nov 06 2008
    Norway
    all I got from KW is
    "Hello Marius, the suspension kit fits with the original top mounts of your car and you donīt need any modification. "
  32. #72
    Established Member Two Rings S4SHOES's Avatar
    Jan 21 2011
    Calgary
    VERY cool cars man, great work
  33. #73
    Nov 06 2008
    Norway
    Quote Originally Posted by S4SHOES View Post
    Thank you :)
    Two very poor pics from the sedan after lowering. Dark and phone is a very bad combination when taking picture. Will bring my camera and take som pics during the daylight some day soon when I have washed the car.
    Still think the car is very high on the rear. Anyone knows why? It is 4cm lower than before lowering, but still very high :o But the car got very much better to drive after lowering. Handles more well, and a bit stiffer :)
    Also still got a "knocking" sound when I drive. Have changed the wheel bearing in front, and the outer joints.
    Might have a look on the exhaust and axle to se if there is something wrong there.
  34. #74
    Nov 06 2008
    Norway
    The car realy needs a wash. Will also get a new spoiler on the front bumper, and a new foglight soon :)
  35. #75
    Nov 06 2008
    Norway
    Think I know why the car is so high rear now. I might have wrong shox. The length shown on picture below is about 24cm on my car. But some other shox I have for Audi 100 quattro is 19cm. Don't know what shox I have, but I guess they are wrong?
  36. #76
    Nov 06 2008
    Norway
    More snow:
    Tried to flip the lower spring seat this weekend, but it was not possible to get it off the damper. No problem to move it, but the damper got some kind of ring where the thicker part of the damper ends, and the spring seat did not fit over this.
    Also where going to change the wheel bearing in front, but managed to split the bearing when mounting the hub back into the bearing. Not a very good weekend :roll:
  37. #77
    Nov 06 2008
    Norway
    Also test fitted some wheels on the S2. Theese are going to be street wheels, while the compomotive rims will get some toyo r888 or something. Also mounted original brakes in front, to get the winter tires on, and to get to use rally ice wheels for the icetrack drinving later this winter :) The car is raised a bit on the coilovers now, but good to have a high car in the snow :)
    You also see the wrong tire size on the comp wheels on this picture, but that is due to offset15 on the comp wheels.
  38. #78
    Nov 06 2008
    Norway
    Bought new wheels for the sedan today :)
  39. #79
    Nov 06 2008
    Norway
    Finally changed the wheel bearing on right side. And now there is no bad sound on the car :)
    Also changed the rear dampers, and finally got the right height
    But, bad news. I managed to break one of the bolts on the rear damper. One of the three on top. With the nut number 14 on it.
  40. #80
    Nov 06 2008
    Norway
    Got a packet today :)
