Results 1 to 40 of 46
    Jul 16 2008
    05 Avant 1.8t Qtip
    Toronto, On
    traction control (ESP) light came on today....WTF
    just came on today after driving for like 5 min, any idea what it could be, has this happened to anyone else, and what was the reason.
    also just wanna make sure that the yellow triangle with ! inside it and a yellow arrow goin counter clockwise around it is infact the ESP light
    thanks
    Veteran Member Three Rings dak360rt's Avatar
    Apr 17 2008
    Sacramento, Ca
    Re: traction control (ESP) light came on today....WTF
    Yeah thats the ESP light,
    mine comes on when it cuts my throttle and applies brakes when i have too much fun but other than that i havent seen nor heard of that happening before. What does it do when you press the button? Could it have accidentally gotten turned on? and after you turn the car off and then turn it on again does the light come back?
    Light Silver Metallic - 2001.5 S4 - APR Stage 2+
    Piggy Pipes --- CC Mod --- Darintake --- Samco TBB
    AWE Boost Gauge --- 1 touch rear windows up
    JHM Weighted Shift Knob --- JHM Solid Short Throw Shifter --- Custom Straight Pipes
    Active Member One Ring heath22's Avatar
    Oct 19 2007
    Atlanta GA
    I believe one reason is a bad brake sensor or a "blip" with the sensor. I know that it will happen if your alignment is off, at least that's been my experience.
    2004 1.8T QMT USP
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    Were you sideways when it came on?
    Veteran Member Four Rings OneBadAudi's Avatar
    Feb 25 2008
    02 A4 Quattro, 09 Yami YZ250f
    Cape May, NJ
    yeh i was about to say, were u having some fun with esp on?
    02 A4 Quattro stage 1+ (Giac Tuned)
    Siemens 380 injectors
    APR R1 DV
    K&N Air Filter
    5% tint
    STACKS boost gauge W/ Podi Column Mount
    Lip Spoiler
    Complete JL Audio sound system
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    Could be electrical as well.
    Ex: Your battery voltage exceeds standing voltage of 16v
    Or, you just pulled the battery
    Maybe you decided to slap on a FMIC or a intake, that will cause your ESP light to come on solid for a few cycles. If nothing is seriously wrong, it will disappear.
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Jul 16 2008
    05 Avant 1.8t Qtip
    Toronto, On
    Good answers guys! I wasnt sideways or in slippery conditions. I was driving slowly and it just came on out of nowhere. One time my dad pressed it by accident and he didnt know. I easily pressed the button and turned it off. But today, after it came on, I pressed the esp button a couple of time and it didnt turn off. Any reason why this would happen?
    Veteran Member Three Rings B6480Avant's Avatar
    Jul 11 2008
    B6 A4 Avant
    Gilbert AZ
    esp is on when the light is off
    esp is off when the light is on
    give it a day it might go away it happened to me once when it was raining and also when i changed my battery
    Senior Member Two Rings sti4now's Avatar
    Oct 21 2008
    Turbo M3
    NC
    where do you cut the ESP on and off?....sorry for the extremely noob ?
    Jun 11 2005
    I don't think the light will persist. but if it does, I suggest you get a VAG.
    Or you can play roulette and guess which one of the possible faults belongs to your car at the moment. Check Below
    P-code
    Description
    16394
    P0010
    -A- Camshaft Pos. Actuator Circ. Bank 1 Malfunction
    16395
    P0020
    -A- Camshaft Pos. Actuator Circ. Bank 2 Malfunction
    16449
    P0065
    Air Assisted Injector Control Range/Performance
    16450
    P0066
    Air Assisted Injector Control Low Input/Short to ground
    16451
    P0067
    Air Assisted Injector Control Input/Short to B+
    16485
    P0101
    Mass or Volume Air Flow Circ Range/Performance
    16486
    P0102
    Mass or Volume Air Flow Circ Low Input
    16487
    P0103
    Mass or Volume Air Flow Circ High Input
    16489
    P0105
    Manifold Abs.Pressure or Bar.Pressure Voltage supply
    16490
    P0106
    Manifold Abs.Pressure or Bar.Pressure Range/Performance
    16491
    P0107
    Manifold Abs.Pressure or Bar.Pressure Low Input
    16492
    P0108
    Manifold Abs.Pressure or Bar.Pressure High Input
    16496
    P0112
    Intake Air Temp.Circ Low Input
    16497
    P0113
    Intake Air Temp.Circ High Input
    16500
    P0116
    Engine Coolant Temp.Circ Range/Performance
    16501
    P0117
    Engine Coolant Temp.Circ Low Input
    16502
    P0118
    Engine Coolant Temp.Circ High Input
    16504
    P0120
    Throttle/Pedal Pos.Sensor A Circ Malfunction
    16505
    P0121
    Throttle/Pedal Pos.Sensor A Circ Range/Performance
    16506
    P0122
    Throttle/Pedal Pos.Sensor A Circ Low Input
    16507
    P0123
    Throttle/Pedal Pos.Sensor A Circ High Input
    16509
    P0125
    Insufficient Coolant Temp.for Closed Loop Fuel Control
    16512
    P0128
    Coolant Thermostat/Valve Temperature below control range
    16514
    P0130
    O2 Sensor Circ.,Bank1-Sensor1 Malfunction
    16515
    P0131
    O2 Sensor Circ.,Bank1-Sensor1 Low Voltage
    16516
    P0132
    O2 Sensor Circ.,Bank1-Sensor1 High Voltage
    16517
    P0133
    O2 Sensor Circ.,Bank1-Sensor1 Slow Response
    16518
    P0134
    O2 Sensor Circ.,Bank1-Sensor1 No Activity Detected
    16519
    P0135
    O2 Sensor Heater Circ.,Bank1-Sensor1 Malfunction
    16520
    P0136
    O2 Sensor Circ.,Bank1-Sensor2 Malfunction
    16521
    P0137
    O2 Sensor Circ.,Bank1-Sensor2 Low Voltage
    16522
    P0138
    O2 Sensor Circ.,Bank1-Sensor2 High Voltage
    16523
    P0139
    O2 Sensor Circ.,Bank1-Sensor2 Slow Response
    16524
    P0140
    O2 Sensor Circ.,Bank1-Sensor2 No Activity Detected
    16525
    P0141
    O2 Sensor Heater Circ.,Bank1-Sensor2 Malfunction
    16534
    P0150
    O2 Sensor Circ.,Bank2-Sensor1 Malfunction
    16535
    P0151
    O2 Sensor Circ.,Bank2-Sensor1 Low Voltage
    16536
    P0152
    O2 Sensor Circ.,Bank2-Sensor1 High Voltage
    16537
    P0153
    O2 Sensor Circ.,Bank2-Sensor1 Slow Response
    16538
    P0154
    O2 Sensor Circ.,Bank2-Sensor1 No Activity Detected
    16539
    P0155
    O2 Sensor Heater Circ.,Bank2-Sensor1 Malfunction
    16540
    P0156
    O2 Sensor Circ.,Bank2-Sensor2 Malfunction
    16541
    P0157
    O2 Sensor Circ.,Bank2-Sensor2 Low Voltage
    16542
    P0158
    O2 Sensor Circ.,Bank2-Sensor2 High Voltage
    16543
    P0159
    O2 Sensor Circ.,Bank2-Sensor2 Slow Response
    16544
    P0160
    O2 Sensor Circ.,Bank2-Sensor2 No Activity Detected
    16545
    P0161
    O2 Sensor Heater Circ.,Bank2-Sensor2 Malfunction
    16554
    P0170
    Fuel Trim,Bank1 Malfunction
    16555
    P0171
    Fuel Trim,Bank1 System too Lean
    16556
    P0172
    Fuel Trim,Bank1 System too Rich
    16557
    P0173
    Fuel Trim,Bank2 Malfunction
    16558
    P0174
    Fuel Trim,Bank2 System too Lean
    16559
    P0175
    Fuel Trim,Bank2 System too Rich
    16566
    P0182
    Fuel temperature sender-G81 Short to ground
    16567
    P0183
    Fuel temperature sender-G81 Interruption/Short to B+
    16581
    P0197
    Engine Oil Temperature Circuit Low Input
    16582
    P0198
    Engine Oil Temperature Circuit High Input
    16585
    P0201
    Cyl.1, Injector Circuit Fault in electrical circuit
    16586
    P0202
    Cyl.2, Injector Circuit Fault in electrical circuit
    16587
    P0203
    Cyl.3, Injector Circuit Fault in electrical circuit
    16588
    P0204
    Cyl.4, Injector Circuit Fault in electrical circuit
    16589
    P0205
    Cyl.5 Injector Circuit Fault in electrical circuit
    16590
    P0206
    Cyl.6 Injector Circuit Fault in electrical circuit
    16591
    P0207
    Cyl.7 Injector Circuit Fault in electrical circuit
    16592
    P0208
    Cyl.8 Injector Circuit Fault in electrical circuit
    16599
    P0215
    Engine Shut-Off Solenoid Malfunction
    16600
    P0216
    Injector/Injection Timing Control Malfunction
    16603
    P0219
    Engine Overspeed Condition
    16605
    P0221
    Throttle Pos. Sensor -B- Circuit Range/Performance
    16606
    P0222
    Throttle Pos. Sensor -B- Circuit Low Input
    16607
    P0223
    Throttle Pos. Sensor -B- Circuit High Input
    16609
    P0225
    Throttle Pos. Sensor -C- Circuit Voltage supply
    16610
    P0226
    Throttle Pos. Sensor -C- Circuit Range/Performance
    16611
    P0227
    Throttle Pos. Sensor -C- Circuit Low Input
    16612
    P0228
    Throttle Pos. Sensor -C- Circuit Hight Input
    16614
    P0230
    Fuel Pump Primary Circuit Fault in electrical circuit
    16618
    P0234
    Turbocharger Overboost Condition Control limit exceeded
    16619
    P0235
    Turbocharger Boost Sensor (A) Circ Control limit not reached
    16620
    P0236
    Turbocharger Boost Sensor (A) Circ Range/Performance
    16621
    P0237
    Turbocharger Boost Sensor (A) Circ Low Input
    16622
    P0238
    Turbocharger Boost Sensor (A) Circ High Input
    16627
    P0243
    Turbocharger Wastegate Solenoid (A) Open/Short Circuit to Ground
    16629
    P0245
    Turbocharger Wastegate Solenoid (A) Low Input/Short to ground
    16630
    P0246
    Turbocharger Wastegate Solenoid (A) High Input/Short to B+
    16636
    P0252
    Injection Pump Metering Control (A) Range/Performance
    16645
    P0261
    Cyl.1 Injector Circuit Low Input/Short to ground
    16646
    P0262
    Cyl.1 Injector Circuit High Input/Short to B+
    16648
    P0264
    Cyl.2 Injector Circuit Low Input/Short to ground
    16649
    P0265
    Cyl.2 Injector Circuit High Input/Short to B+
    16651
    P0267
    Cyl.3 Injector Circuit Low Input/Short to ground
    16652
    P0268
    Cyl.3 Injector Circuit High Input/Short to B+
    16654
    P0270
    Cyl.4 Injector Circuit Low Input/Short to ground
    16655
    P0271
    Cyl.4 Injector Circuit High Input/Short to B+
    16657
    P0273
    Cyl.5 Injector Circuit Low Input/Short to ground
    16658
    P0274
    Cyl.5 Injector Circuit High Input/Short to B+
    16660
    P0276
    Cyl.6 Injector Circuit Low Input/Short to ground
    16661
    P0277
    Cyl.6 Injector Circuit High Input/Short to B+
    16663
    P0279
    Cyl.7 Injector Circuit Low Input/Short to ground
    16664
    P0280
    Cyl.7 Injector Circuit High Input/Short to B+
    16666
    P0282
    Cyl.8 Injector Circuit Low Input/Short to ground
    16667
    P0283
    Cyl.8 Injector Circuit High Input/Short to B+
    16684
    P0300
    Random/Multiple Cylinder Misfire Detected
    16685
    P0301
    Cyl.1 Misfire Detected
    16686
    P0302
    Cyl.2 Misfire Detected
    16687
    P0303
    Cyl.3 Misfire Detected
    16688
    P0304
    Cyl.4 Misfire Detected
    16689
    P0305
    Cyl.5 Misfire Detected
    16690
    P0306
    Cyl.6 Misfire Detected
    16691
    P0307
    Cyl.7 Misfire Detected
    16692
    P0308
    Cyl.8 Misfire Detected
    16697
    P0313
    Misfire Detected Low Fuel Level
    16698
    P0314
    Single Cylinder Misfire
    16705
    P0321
    Ign./Distributor Eng.Speed Inp.Circ Range/Performance
    16706
    P0322
    Ign./Distributor Eng.Speed Inp.Circ No Signal
    16709
    P0325
    Knock Sensor 1 Circuit Electrical Fault in Circuit
    16710
    P0326
    Knock Sensor 1 Circuit Range/Performance
    16711
    P0327
    Knock Sensor 1 Circ Low Input
    16712
    P0328
    Knock Sensor 1 Circ High Input
    16716
    P0332
    Knock Sensor 2 Circ Low Input
    16717
    P0333
    Knock Sensor 2 Circ High Input
    16719
    P0335
    Crankshaft Pos. Sensor (A) Circ Malfunction
    16720
    P0336
    Crankshaft Pos. Sensor (A) Circ Range/Performance/Missing tooth
    16721
    P0337
    Crankshaft Pos.Sensor (A) Circ Low Input
    16724
    P0340
    Camshaft Pos. Sensor (A) Circ Incorrect allocation
    16725
    P0341
    Camshaft Pos.Sensor Circ Range/Performance
    16726
    P0342
    Camshaft Pos.Sensor Circ Low Input
    16727
    P0343
    Camshaft Pos.Sensor Circ High Input
    16735
    P0351
    Ignition Coil (A) Cyl.1 Prim./Sec. Circ Malfunction
    16736
    P0352
    Ignition Coil (B) Cyl.2 Prim./Sec. Circ Malfunction
    16737
    P0353
    Ignition Coil (C) Cyl.3 Prim./Sec. Circ Malfunction
    16738
    P0354
    Ignition Coil (D) Cyl.4 Prim./Sec. Circ Malfunction
    16739
    P0355
    Ignition Coil (E) Cyl.5 Prim./Sec. Circ Malfunction
    16740
    P0356
    Ignition Coil (F) Cyl.6 Prim./Sec. Circ Malfunction
    16741
    P0357
    Ignition Coil (G) Cyl.7 Prim./Sec. Circ Malfunction
    16742
    P0358
    Ignition Coil (H) Cyl.8 Prim./Sec. Circ Malfunction
    16764
    P0380
    Glow Plug/Heater Circuit (A) Electrical Fault in Circuit
    16784
    P0400
    Exhaust Gas Recirc.Flow Malfunction
    16785
    P0401
    Exhaust Gas Recirc.Flow Insufficient Detected
    16786
    P0402
    Exhaust Gas Recirc.Flow Excessive Detected
    16787
    P0403
    Exhaust Gas Recirc. Contr. Circ Malfunction
    16788
    P0404
    Exhaust Gas Recirc. Contr. Circ Range/Performance
    16789
    P0405
    Exhaust Gas Recirc. Sensor (A) Circ Low Input
    16790
    P0406
    Exhaust Gas Recirc. Sensor (A) Circ High Input
    16791
    P0407
    Exhaust Gas Recirc. Sensor (B) Circ Low Input
    16792
    P0408
    Exhaust Gas Recirc. Sensor (B) Circ High Input
    16794
    P0410
    Sec.Air Inj.Sys Malfunction
    16795
    P0411
    Sec.Air Inj.Sys. Incorrect Flow Detected
    16796
    P0412
    Sec.Air Inj.Sys.Switching Valve A Circ Malfunction
    16802
    P0418
    Sec. Air Inj. Sys. Relay (A) Contr. Circ Malfunction
    16804
    P0420
    Catalyst System,Bank1 Efficiency Below Threshold
    16806
    P0422
    Main Catalyst,Bank1 Below Threshold
    16811
    P0427
    Catalyst Temperature Sensor, Bank 1 Low Input/Short to ground
    16812
    P0428
    Catalyst Temperature Sensor, Bank 1 High Input/Open/Short Circuit to B+
    16816
    P0432
    Main Catalyst,Bank2 Efficiency Below Threshold
    16820
    P0436
    Catalyst Temperature Sensor, Bank 2 Range/Performance
    16821
    P0437
    Catalyst Temperature Sensor, Bank 2 Low Input/Short to ground
    16822
    P0438
    Catalyst Temperature Sensor, Bank 2 High Input/Open/Short Circuit to B+
    16824
    P0440
    EVAP Emission Contr.Sys. Malfunction
    16825
    P0441
    EVAP Emission Contr.Sys.Incorrect Purge Flow
    16826
    P0442
    EVAP Emission Contr.Sys.(Small Leak) Leak Detected
    16827
    P0443
    EVAP Emiss. Contr. Sys. Purge Valve Circ Electrical Fault in Circuit
    16836
    P0452
    EVAP Emission Contr.Sys.Press.Sensor Low Input
    16837
    P0453
    EVAP Emission Contr.Sys.Press.Sensor High Input
    16839
    P0455
    EVAP Emission Contr.Sys.(Gross Leak) Leak Detected
    16845
    P0461
    Fuel Level Sensor Circ Range/Performance
    16846
    P0462
    Fuel Level Sensor Circuit Low Input
    16847
    P0463
    Fuel Level Sensor Circuit High Input
    16885
    P0501
    Vehicle Speed Sensor Range/Performance
    16887
    P0503
    Vehicle Speed Sensor Intermittent/Erratic/High Input
    16889
    P0505
    Idle Control System Malfunction
    16890
    P0506
    Idle Control System RPM Lower than Expected
    16891
    P0507
    Idle Control System Higher than Expected
    16894
    P0510
    Closed Throttle Pos.Switch Malfunction
    16915
    P0531
    A/C Refrigerant Pressure Sensor Circuit Range/Performance
    16916
    P0532
    A/C Refrigerant Pressure Sensor Circuit Low Input
    16917
    P0533
    A/C Refrigerant Pressure Sensor Circuit High Input
    16935
    P0551
    Power Steering Pressure Sensor Circuit Range/Performance
    16944
    P0560
    System Voltage Malfunction
    16946
    P0562
    System Voltage Low Voltage
    16947
    P0563
    System Voltage High Voltage
    16952
    P0568
    Cruise Control Set Signal Incorrect Signal
    16955
    P0571
    Cruise/Brake Switch (A) Circ Malfunction
    16984
    P0600
    Serial Comm. Link (Data Bus) Message Missing
    16985
    P0601
    Internal Contr.Module Memory Check Sum Error
    16986
    P0602
    Control Module Programming Error/Malfunction
    16987
    P0603
    Internal Contr.Module (KAM) Error
    16988
    P0604
    Internal Contr.Module Random Access Memory (RAM) Error
    16989
    P0605
    Internal Contr.Module ROM Test Error
    16990
    P0606
    ECM/PCM Processor
    17026
    P0642
    Knock Control Control Module Malfunction
    17029
    P0645
    A/C Clutch Relay Control Circuit
    17034
    P0650
    MIL Control Circuit Electrical Fault in Circuit
    17038
    P0654
    Engine RPM Output Circuit Electrical Fault in Circuit
    17040
    P0656
    Fuel Level Output Circuit Electrical Fault in Circuit
    17084
    P0700
    Transm.Contr.System Malfunction
    17086
    P0702
    Transm.Contr.System Electrical
    17087
    P0703
    Torque Converter/Brake Switch B Circ Malfunction
    17089
    P0705
    Transm.Range Sensor Circ.(PRNDL Inp.) Malfunction
    17090
    P0706
    Transm.Range Sensor Circ Range/Performance
    17091
    P0707
    Transm.Range Sensor Circ Low Input
    17092
    P0708
    Transm.Range Sensor Circ High Input
    17094
    P0710
    Transm.Fluid Temp.Sensor Circ. Malfunction
    17095
    P0711
    Transm.Fluid Temp.Sensor Circ. Range/Performance
    17096
    P0712
    Transm.Fluid Temp.Sensor Circ. Low Input
    17097
    P0713
    Transm.Fluid Temp.Sensor Circ. High Input
    17099
    P0715
    Input Turbine/Speed Sensor Circ. Malfunction
    17100
    P0716
    Input Turbine/Speed Sensor Circ. Range/Performance
    17101
    P0717
    Input Turbine/Speed Sensor Circ. No Signal
    17105
    P0721
    Output Speed Sensor Circ Range/Performance
    17106
    P0722
    Output Speed Sensor Circ No Signal
    17109
    P0725
    Engine Speed Inp.Circ. Malfunction
    17110
    P0726
    Engine Speed Inp.Circ. Range/Performance
    17111
    P0727
    Engine Speed Inp.Circ. No Signal
    17114
    P0730
    Gear Incorrect Ratio
    17115
    P0731
    Gear 1 Incorrect Ratio
    17116
    P0732
    Gear 2 Incorrect Ratio
    17117
    P0733
    Gear 3 Incorrect Ratio
    17118
    P0734
    Gear 4 Incorrect Ratio
    17119
    P0735
    Gear 5 Incorrect Ratio
    17124
    P0740
    Torque Converter Clutch Circ Malfunction
    17125
    P0741
    Torque Converter Clutch Circ Performance or Stuck Off
    17132
    P0748
    Pressure Contr.Solenoid Electrical
    17134
    P0750
    Shift Solenoid A malfunction
    17135
    P0751
    Shift Solenoid A Performance or Stuck Off
    17136
    P0752
    Shift Solenoid A Stuck On
    17137
    P0753
    Shift Solenoid A Electrical
    17140
    P0756
    Shift Solenoid B Performance or Stuck Off
    17141
    P0757
    Shift Solenoid B Stuck On
    17142
    P0758
    Shift Solenoid B Electrical
    17145
    P0761
    Shift Solenoid C Performance or Stuck Off
    17146
    P0762
    Shift Solenoid C Stuck On
    17147
    P0763
    Shift Solenoid C Electrical
    17152
    P0768
    Shift Solenoid D Electrical
    17157
    P0773
    Shift Solenoid E Electrical
    17174
    P0790
    Normal/Performance Switch Circ Malfunction
    17509
    P1101
    O2 Sensor Circ.,Bank1-Sensor1Voltage too Low/Air Leak
    17510
    P1102
    O2 Sensor Heating Circ.,Bank1-Sensor1 Short to B+
    17511
    P1103
    O2 Sensor Heating Circ.,Bank1-Sensor1 Output too Low
    17512
    P1104
    Bank1-Sensor2 Voltage too Low/Air Leak
    17513
    P1105
    O2 Sensor Heating Circ.,Bank1-Sensor2 Short to B+
    17514
    P1106
    O2 Sensor Circ.,Bank2-Sensor1 Voltage too Low/Air Leak
    17515
    P1107
    O2 Sensor Heating Circ.,Bank2-Sensor1 Short to B+
    17516
    P1108
    O2 Sensor Heating Circ.,Bank2-Sensor1 Output too Low
    17517
    P1109
    O2 Sensor Circ.,Bank2-Sensor2 Voltage too Low/Air Leak
    17518
    P1110
    O2 Sensor Heating Circ.,Bank2-Sensor2 Short to B+
    17519
    P1111
    O2 Control (Bank 1) System too lean
    17520
    P1112
    O2 Control (Bank 1) System too rich
    17521
    P1113
    Bank1-Sensor1 Internal Resistance too High
    17522
    P1114
    Bank1-Sensor2 Internal Resistant too High
    17523
    P1115
    O2 Sensor Heater Circ.,Bank1-Sensor1 Short to Ground
    17524
    P1116
    O2 Sensor Heater Circ.,Bank1-Sensor1 Open
    17525
    P1117
    O2 Sensor Heater Circ.,Bank1-Sensor2 Short to Ground
    17526
    P1118
    O2 Sensor Heater Circ.,Bank1-Sensor2 Open
    17527
    P1119
    O2 Sensor Heater Circ.,Bank2-Sensor1 Short to Ground
    17528
    P1120
    O2 Sensor Heater Circ.,Bank2-Sensor1 Open
    17529
    P1121
    O2 Sensor Heater Circ.,Bank2-Sensor2 Short to Ground
    17530
    P1122
    O2 Sensor Heater Circ.,Bank2-Sensor2 Open
    17531
    P1123
    Long Term Fuel Trim Add.Air.,Bank1 System too Rich
    17532
    P1124
    Long Term Fuel Trim Add.Air.,Bank1 System too Lean
    17533
    P1125
    Long Term Fuel Trim Add.Air.,Bank2 System too Rich
    17534
    P1126
    Long Term Fuel Trim Add.Air.,Bank2 System too Lean
    17535
    P1127
    Long Term Fuel Trim mult.,Bank1 System too Rich
    17536
    P1128
    Long Term Fuel Trim mult.,Bank1 System too Lean
    17537
    P1129
    Long Term Fuel Trim mult.,Bank2 System too Rich
    17538
    P1130
    Long Term Fuel Trim mult.,Bank2 System too Lean
    17539
    P1131
    Bank2-Sensor1 Internal Rsistance too High
    17540
    P1132
    O2 Sensor Heating Circ.,Bank1+2-Sensor1 Short to B+
    17541
    P1133
    O2 Sensor Heating Circ.,Bank1+2-Sensor1 Electrical Malfunction
    17542
    P1134
    O2 Sensor Heating Circ.,Bank1+2-Sensor2 Short to B+
    17543
    P1135
    O2 Sensor Heating Circ.,Bank1+2-Sensor2 Electrical Malfunction
    17544
    P1136
    Long Term Fuel Trim Add.Fuel,Bank1 System too Lean
    17545
    P1137
    Long Term Fuel Trim Add.Fuel,Bank1 System too Rich
    17546
    P1138
    Long Term Fuel Trim Add.Fuel,Bank2 System too Lean
    17547
    P1139
    Long Term Fuel Trim Add.Fuel,Bank2 System too Rich
    17548
    P1140
    Bank2-Sensor2 Internal Resistance too High
    17549
    P1141
    Load Calculation Cross Check Range/Performance
    17550
    P1142
    Load Calculation Cross Check Lower Limit Exceeded
    17551
    P1143
    Load Calculation Cross Check Upper Limit Exceeded
    17552
    P1144
    Mass or Volume Air Flow Circ Open/Short to Ground
    17553
    P1145
    Mass or Volume Air Flow Circ Short to B+
    17554
    P1146
    Mass or Volume Air Flow Circ Supply Malfunction
    17555
    P1147
    O2 Control (Bank 2) System too lean
    17556
    P1148
    O2 Control (Bank 2) System too rich
    17557
    P1149
    O2 Control (Bank 1) Out of range
    17558
    P1150
    O2 Control (Bank 2) Out of range
    17559
    P1151
    Bank1, Long Term Fuel Trim, Range 1 Leanness Lower Limit Exceeded
    17560
    P1152
    Bank1, Long Term Fuel Trim, Range 2 Leanness Lower Limit Exceeded
    17562
    P1154
    Manifold Switch Over Malfunction
    17563
    P1155
    Manifold Abs.Pressure Sensor Circ. Short to B+
    17564
    P1156
    Manifold Abs.Pressure Sensor Circ. Open/Short to Ground
    17565
    P1157
    Manifold Abs.Pressure Sensor Circ. Power Supply Malfunction
    17566
    P1158
    Manifold Abs.Pressure Sensor Circ. Range/Performance
    17568
    P1160
    Manifold Temp.Sensor Circ. Short to Ground
    17569
    P1161
    Manifold Temp.Sensor Circ. Open/Short to B+
    17570
    P1162
    Fuel Temp.Sensor Circ. Short to Ground
    17571
    P1163
    Fuel Temp.Sensor Circ. Open/Short to B+
    17572
    P1164
    Fuel Temperature Sensor Range/Performance/Incorrect Signal
    17573
    P1165
    Bank1, Long Term Fuel Trim, Range 1 Rich Limit Exceeded
    17574
    P1166
    Bank1, Long Term Fuel Trim, Range 2 Rich Limit Exceeded
    17579
    P1171
    Throttle Actuation Potentiometer Sign.2 Range/Performance
    17580
    P1172
    Throttle Actuation Potentiometer Sign.2 Signal too Low
    17581
    P1173
    Throttle Actuation Potentiometer Sign.2 Signal too High
    17582
    P1174
    Fuel Trim, Bank 1 Different injection times
    17584
    P1176
    O2 Correction Behind Catalyst,B1 Limit Attained
    17585
    P1177
    O2 Correction Behind Catalyst,B2 Limit Attained
    17586
    P1178
    Linear 02 Sensor / Pump Current Open Circuit
    17587
    P1179
    Linear 02 Sensor / Pump Current Short to ground
    17588
    P1180
    Linear 02 Sensor / Pump Current Short to B+
    17589
    P1181
    Linear 02 Sensor / Reference Voltage Open Circuit
    17590
    P1182
    Linear 02 Sensor / Reference Voltage Short to ground
    17591
    P1183
    Linear 02 Sensor / Reference Voltage Short to B+
    17592
    P1184
    Linear 02 Sensor / Common Ground Wire Open Circuit
    17593
    P1185
    Linear 02 Sensor / Common Ground Wire Short to ground
    17594
    P1186
    Linear 02 Sensor / Common Ground Wire Short to B+
    17595
    P1187
    Linear 02 Sensor / Compens. Resistor Open Circuit
    17596
    P1188
    Linear 02 Sensor / Compens. Resistor Short to ground
    17597
    P1189
    Linear 02 Sensor / Compens. Resistor Short to B+
    17598
    P1190
    Linear 02 Sensor / Reference Voltage Incorrect Signal
    17604
    P1196
    O2 Sensor Heater Circ.,Bank1-Sensor1 Electrical Malfunction
    17605
    P1197
    O2 Sensor Heater Circ.,Bank2-Sensor1 Electrical Malfunction
    17606
    P1198
    O2 Sensor Heater Circ.,Bank1-Sensor2 Electrical Malfunction
    17607
    P1199
    O2 Sensor Heater Circ.,Bank2-Sensor2 Electrical Malfunction
    17609
    P1201
    Cyl.1-Fuel Inj.Circ. Electrical Malfunction
    17610
    P1202
    Cyl.2-Fuel Inj.Circ. Electrical Malfunction
    17611
    P1203
    Cyl.3-Fuel Inj.Circ. Electrical Malfunction
    17612
    P1204
    Cyl.4-Fuel Inj.Circ. Electrical Malfunction
    17613
    P1205
    Cyl.5-Fuel Inj.Circ. Electrical Malfunction
    17614
    P1206
    Cyl.6-Fuel Inj.Circ. Electrical Malfunction
    17615
    P1207
    Cyl.7-Fuel Inj.Circ. Electrical Malfunction
    17616
    P1208
    Cyl.8-Fuel Inj.Circ. Electrical Malfunction
    17617
    P1209
    Intake valves for cylinder shut-off Short circuit to ground
    17618
    P1210
    Intake valves for cylinder shut-off Short to B+
    17619
    P1211
    Intake valves for cylinder shut-off Open circuit
    17621
    P1213
    Cyl.1-Fuel Inj.Circ. Short to B+
    17622
    P1214
    Cyl.2-Fuel Inj.Circ. Short to B+
    17623
    P1215
    Cyl.3-Fuel Inj.Circ. Short to B+
    17624
    P1216
    Cyl.4-Fuel Inj.Circ. Short to B+
    17625
    P1217
    Cyl.5-Fuel Inj.Circ. Short to B+
    17626
    P1218
    Cyl.6-Fuel Inj.Circ. Short to B+
    17627
    P1219
    Cyl.7-Fuel Inj.Circ. Short to B+
    17628
    P1220
    Cyl.8-Fuel Inj.Circ. Short to B+
    17629
    P1221
    Cylinder shut-off exhaust valves Short circuit to ground
    17630
    P1222
    Cylinder shut-off exhaust valves Short to B+
    17631
    P1223
    Cylinder shut-off exhaust valves Open circuit
    17633
    P1225
    Cyl.1-Fuel Inj.Circ. Short to Ground
    17634
    P1226
    Cyl.2-Fuel Inj.Circ. Short to Ground
    17635
    ssing messages
    2003 1.8T
    Jun 11 2005
    and also for your pleasure. ....
    P1227
    Cyl.3-Fuel Inj.Circ. Short to Ground
    17636
    P1228
    Cyl.4-Fuel Inj.Circ. Short to Ground
    17637
    P1229
    Cyl.5-Fuel Inj.Circ. Short to Ground
    17638
    P1230
    Cyl.6-Fuel Inj.Circ. Short to Ground
    17639
    P1231
    Cyl.7-Fuel Inj.Circ. Short to Ground
    17640
    P1232
    Cyl.8-Fuel Inj.Circ. Short to Ground
    17645
    P1237
    Cyl.1-Fuel Inj.Circ. Open Circ.
    17646
    P1238
    Cyl.2-Fuel Inj.Circ. Open Circ.
    17647
    P1239
    Cyl.3-Fuel Inj.Circ. Open Circ.
    17648
    P1240
    Cyl.4-Fuel Inj.Circ. Open Circ.
    17649
    P1241
    Cyl.5-Fuel Inj.Circ. Open Circ.
    17650
    P1242
    Cyl.6-Fuel Inj.Circ. Open Circ.
    17651
    P1243
    Cyl.7-Fuel Inj.Circ. Open Circ.
    17652
    P1244
    Cyl.8-Fuel Inj.Circ. Open Circ.
    17653
    P1245
    Needle Lift Sensor Circ. Short to Ground
    17654
    P1246
    Needle Lift Sensor Circ. Range/Performance
    17655
    P1247
    Needle Lift Sensor Circ. Open/Short to B+
    17656
    P1248
    Injection Start Control Deviation
    17657
    P1249
    Fuel consumption signal Electrical Fault in Circuit
    17658
    P1250
    Fuel Level Too Low
    17659
    P1251
    Start of Injection Solenoid Circ Short to B+
    17660
    P1252
    Start of Injection Solenoid Circ Open/Short to Ground
    17661
    P1253
    Fuel consumption signal Short to ground
    17662
    P1254
    Fuel consumption signal Short to B+
    17663
    P1255
    Engine Coolant Temp.Circ Short to Ground
    17664
    P1256
    Engine Coolant Temp.Circ Open/Short to B+
    17665
    P1257
    Engine Coolant System Valve Open
    17666
    P1258
    Engine Coolant System Valve Short to B+
    17667
    P1259
    Engine Coolant System Valve Short to Ground
    17688
    P1280
    Fuel Inj.Air Contr.Valve Circ. Flow too Low
    17691
    P1283
    Fuel Inj.Air Contr.Valve Circ. Electrical Malfunction
    17692
    P1284
    Fuel Inj.Air Contr.Valve Circ. Open
    17693
    P1285
    Fuel Inj.Air Contr.Valve Circ. Short to Ground
    17694
    P1286
    Fuel Inj.Air Contr.Valve Circ. Short to B+
    17695
    P1287
    Turbocharger bypass valve open
    17696
    P1288
    Turbocharger bypass valve short to B+
    17697
    P1289
    Turbocharger bypass valve short to ground
    17704
    P1296
    Cooling system malfunction
    17705
    P1297
    Connection turbocharger - throttle valve pressure hose
    17708
    P1300
    Misfire detected Reason: Fuel level too low
    17721
    P1319
    Knock Sensor 1 Circ. Short to Ground
    17728
    P1320
    Knock Sensor 2 Circ. Short to Ground
    17729
    P1321
    Knock Sensor 3 Circ. Low Input
    17730
    P1322
    Knock Sensor 3 Circ. High Input
    17731
    P1323
    Knock Sensor 4 Circ. Low Input
    17732
    P1324
    Knock Sensor 4 Circ. High Input
    17733
    P1325
    Cyl.1-Knock Contr. Limit Attained
    17734
    P1326
    Cyl.2-Knock Contr. Limit Attained
    17735
    P1327
    Cyl.3-Knock Contr. Limit Attained
    17736
    P1328
    Cyl.4-Knock Contr. Limit Attained
    17737
    P1329
    Cyl.5-Knock Contr. Limit Attained
    17738
    P1330
    Cyl.6-Knock Contr. Limit Attained
    17739
    P1331
    Cyl.7-Knock Contr. Limit Attained
    17740
    P1332
    Cyl.8-Knock Contr. Limit Attained
    17743
    P1335
    Engine Torque Monitoring 2 Control Limint Exceeded
    17744
    P1336
    Engine Torque Monitoring Adaptation at limit
    17745
    P1337
    Camshaft Pos.Sensor,Bank1 Short to Ground
    17746
    P1338
    Camshaft Pos.Sensor,Bank1 Open Circ./Short to B+
    17747
    P1339
    Crankshaft Pos./Engine Speed Sensor Cross Connected
    17748
    P1340
    Crankshaft-/Camshaft Pos.Sens.Signals Out of Sequence
    17749
    P1341
    Ignition Coil Power Output Stage 1 Short to Ground
    17750
    P1342
    Ignition Coil Power Output Stage 1 Short to B+
    17751
    P1343
    Ignition Coil Power Output Stage 2 Short to Ground
    17752
    P1344
    Ignition Coil Power Output Stage 2 Short to B+
    17753
    P1345
    Ignition Coil Power Output Stage 3 Short to Ground
    17754
    P1346
    Ignition Coil Power Output Stage 3 Short to B+
    17755
    P1347
    Bank2,Crankshaft-/Camshaft os.Sens.Sign. Out of Sequence
    17756
    P1348
    Ignition Coil Power Output Stage 1 Open Circuit
    17757
    P1349
    Ignition Coil Power Output Stage 2 Open Circuit
    17758
    P1350
    Ignition Coil Power Output Stage 3 Open Circuit
    17762
    P1354
    Modulation Piston Displ.Sensor Circ. Malfunction
    17763
    P1355
    Cyl. 1, ignition circuit Open Circuit
    17764
    P1356
    Cyl. 1, ignition circuit Short to B+
    17765
    P1357
    Cyl. 1, ignition circuit Short to ground
    17766
    P1358
    Cyl. 2, ignition circuit Open Circuit
    17767
    P1359
    Cyl. 2, ignition circuit Short Circuit to B+
    17768
    P1360
    Cyl. 2, ignition circuit Short Circuit to Ground
    17769
    P1361
    Cyl. 3, ignition circuit Open Circuit
    17770
    P1362
    Cyl. 3, ignition circuit Short Circuit to B+
    17771
    P1363
    Cyl. 3, ignition circuit Short Circuit to ground
    17772
    P1364
    Cyl. 4 ignition circuit Open Circuit
    17773
    P1365
    Cyl. 4 ignition circuit Short circuit to B+
    17774
    P1366
    Cyl. 4 ignition circuit Short circuit to ground
    17775
    P1367
    Cyl. 5, ignition circuit Open Circuit
    17776
    P1368
    Cyl. 5, ignition circuit Short Circuit to B+
    17777
    P1369
    Cyl. 5, ignition circuit short to ground
    17778
    P1370
    Cyl. 6, ignition circuit Open Circuit
    17779
    P1371
    Cyl. 6, ignition circuit Short Circuit to B+
    17780
    P1372
    Cyl. 6, ignition circuit short to ground
    17781
    P1373
    Cyl. 7, ignition circuit Open Circuit
    17782
    P1374
    Cyl. 7, ignition circuit Short Circuit to B+
    17783
    P1375
    Cyl. 7, ignition circuit short to ground
    17784
    P1376
    Cyl. 8, ignition circuit Open Circuit
    17785
    P1377
    Cyl. 8, ignition circuit Short Circuit to B+
    17786
    P1378
    Cyl. 8, ignition circuit short to ground
    17794
    P1386
    Internal Control Module Knock Control Circ.Error
    17795
    P1387
    Internal Contr. Module altitude sensor error
    17796
    P1388
    Internal Contr. Module drive by wire error
    17799
    P1391
    Camshaft Pos.Sensor,Bank2 Short to Ground
    17800
    P1392
    Camshaft Pos.Sensor,Bank2 Open Circ./Short to B+
    17801
    P1393
    Ignition Coil Power Output Stage 1 Electrical Malfunction
    17802
    P1394
    Ignition Coil Power Output Stage 2 Electrical Malfunction
    17803
    P1395
    Ignition Coil Power Output Stage 3 Electrical Malfunction
    17804
    P1396
    Engine Speed Sensor Missing Tooth
    17805
    P1397
    Engine speed wheel Adaptation limit reached
    17806
    P1398
    Engine RPM signal, TD Short to ground
    17807
    P1399
    Engine RPM signal, TD Short Circuit to B+
    17808
    P1400
    EGR Valve Circ Electrical Malfunction
    17809
    P1401
    EGR Valve Circ Short to Ground
    17810
    P1402
    EGR Valve Circ Short to B+
    17811
    P1403
    EGR Flow Deviation
    17812
    P1404
    EGR Flow Basic Setting not carried out
    17814
    P1406
    EGR Temp.Sensor Range/Performance
    17815
    P1407
    EGR Temp.Sensor Signal too Low
    17816
    P1408
    EGR Temp.Sensor Signal too High
    17817
    P1409
    Tank Ventilation Valve Circ. Electrical Malfunction
    17818
    P1410
    Tank Ventilation Valve Circ. Short to B+
    17819
    P1411
    Sec.Air Inj.Sys.,Bank2 Flow too Flow
    17820
    P1412
    EGR Different.Pressure Sensor Signal too Low
    17821
    P1413
    EGR Different.Pressure Sensor Signal too High
    17822
    P1414
    Sec.Air Inj.Sys.,Bank2 Leak Detected
    17825
    P1417
    Fuel Level Sensor Circ Signal too Low
    17826
    P1418
    Fuel Level Sensor Circ Signal too High
    17828
    P1420
    Sec.Air Inj.Valve Circ Electrical Malfunction
    17829
    P1421
    Sec.Air Inj.Valve Circ Short to Ground
    17830
    P1422
    Sec.Air Inj.Sys.Contr.Valve Circ Short to B+
    17831
    P1423
    Sec.Air Inj.Sys.,Bank1 Flow too Low
    17832
    P1424
    Sec.Air Inj.Sys.,Bank1 Leak Detected
    17833
    P1425
    Tank Vent.Valve Short to Ground
    17834
    P1426
    Tank Vent.Valve Open
    17840
    P1432
    Sec.Air Inj.Valve Open
    17841
    P1433
    Sec.Air Inj.Sys.Pump Relay Circ. open
    17842
    P1434
    Sec.Air Inj.Sys.Pump Relay Circ. Short to B+
    17843
    P1435
    Sec.Air Inj.Sys.Pump Relay Circ. Short to ground
    17844
    P1436
    Sec.Air Inj.Sys.Pump Relay Circ. Electrical Malfunction
    17847
    P1439
    EGR Potentiometer Error in Basic Seting
    17848
    P1440
    EGR Valve Power Stage Open
    17849
    P1441
    EGR Valve Circ Open/Short to Ground
    17850
    P1442
    EGR Valve Position Sensor Signal too high
    17851
    P1443
    EGR Valve Position Sensor Signal too low
    17852
    P1444
    EGR Valve Position Sensor range/performance
    17853
    P1445
    Catalyst Temp.Sensor 2 Circ. Range/Performance
    17854
    P1446
    Catalyst Temp.Circ Short to Ground
    17855
    P1447
    Catalyst Temp.Circ Open/Short to B+
    17856
    P1448
    Catalyst Temp.Sensor 2 Circ. Short to Ground
    17857
    P1449
    Catalyst Temp.Sensor 2 Circ. Open/Short to B+
    17858
    P1450
    Sec.Air Inj.Sys.Circ Short to B+
    17859
    P1451
    Sec.Air Inj.Sys.Circ Short to Ground
    17860
    P1452
    Sec.Air Inj.Sys. Open Circ.
    17861
    P1453
    Exhaust gas temperature sensor 1 open/short to B+
    17862
    P1454
    Exhaust gas temperature sensor short 1 to ground
    17863
    P1455
    Exhaust gas temperature sensor 1 range/performance
    17864
    P1456
    Exhaust gas temperature control bank 1 limit attained
    17865
    P1457
    Exhaust gas temperature sensor 2 open/short to B+
    17866
    P1458
    Exhaust gas temperature sensor 2 short to ground
    17867
    P1459
    Exhaust gas temperature sensor 2 range/performance
    17868
    P1460
    Exhaust gas temperature control bank 2 limit attained
    17869
    P1461
    Exhaust gas temperature control bank 1 Range/Performance
    17870
    P1462
    Exhaust gas temperature control bank 2 Range/Performance
    17873
    P1465
    Additive Pump Short Circuit to B+
    17874
    P1466
    Additive Pump Open/Short to Ground
    17875
    P1467
    EVAP Canister Purge Solenoid Valve Short Circuit to B+
    17876
    P1468
    EVAP Canister Purge Solenoid Valve Short Circuit to Ground
    17877
    P1469
    EVAP Canister Purge Solenoid Valve Open Circuit
    17878
    P1470
    EVAP Emission Contr.LDP Circ Electrical Malfunction
    17879
    P1471
    EVAP Emission Contr.LDP Circ Short to B+
    17880
    P1472
    EVAP Emission Contr.LDP Circ Short to Ground
    17881
    P1473
    EVAP Emission Contr.LDP Circ Open Circ.
    17882
    P1474
    EVAP Canister Purge Solenoid Valve electrical malfunction
    17883
    P1475
    EVAP Emission Contr.LDP Circ Malfunction/Signal Circ.Open
    17884
    P1476
    EVAP Emission Contr.LDP Circ Malfunction/Insufficient Vacuum
    17885
    P1477
    17886
    P1478
    EVAP Emission Contr.LDP Circ Clamped Tube Detected
    17908
    P1500
    Fuel Pump Relay Circ. Electrical Malfunction
    17909
    P1501
    Fuel Pump Relay Circ. Short to Ground
    17910
    P1502
    Fuel Pump Relay Circ. Short to B+
    17911
    P1503
    Load signal from Alternator Term. DF Range/performance/Incorrect Signal
    17912
    P1504
    Intake Air Sys.Bypass Leak Detected
    17913
    P1505
    Closed Throttle Pos. Does Not Close/Open Circ
    17914
    P1506
    Closed Throttle Pos.Switch Does Not Open/Short to Ground
    17915
    P1507
    Idle Sys.Learned Value Lower Limit Attained
    17916
    P1508
    Idle Sys.Learned Value Upper Limit Attained
    17917
    P1509
    Idle Air Control Circ. Electrical Malfunction
    17918
    P1510
    Idle Air Control Circ. Short to B+
    17919
    P1511
    Intake Manifold Changeover Valve circuit electrical malfunction
    17920
    P1512
    Intake Manifold Changeover Valve circuit Short to B+
    17921
    P1513
    Intake Manifold Changeover Valve2 circuit Short to B+
    17922
    P1514
    Intake Manifold Changeover Valve2 circuit Short to ground
    17923
    P1515
    Intake Manifold Changeover Valve circuit Short to Ground
    17924
    P1516
    Intake Manifold Changeover Valve circuit Open
    17925
    P1517
    Main Relay Circ. Electrical Malfunction
    17926
    P1518
    Main Relay Circ. Short to B+
    17927
    P1519
    Intake Camshaft Contr.,Bank1 Malfunction
    17928
    P1520
    Intake Manifold Changeover Valve2 circuit Open
    17929
    P1521
    Intake Manifold Changeover Valve2 circuit electrical malfunction
    17930
    P1522
    Intake Camshaft Contr.,Bank2 Malfunction
    17931
    P1523
    Crash Signal from Airbag Control Unit range/performance
    17933
    P1525
    Intake Camshaft Contr.Circ.,Bank1 Electrical Malfunction
    17934
    P1526
    Intake Camshaft Contr.Circ.,Bank1 Short to B+
    17935
    P1527
    Intake Camshaft Contr.Circ.,Bank1 Short to Ground
    17936
    P1528
    Intake Camshaft Contr.Circ.,Bank1 Open
    17937
    P1529
    Camshaft Control Circuit Short to B+
    17938
    P1530
    Camshaft Control Circuit Short to ground
    17939
    P1531
    Camshaft Control Circuit open
    17941
    P1533
    Intake Camshaft Contr.Circ.,Bank2 Electrical Malfunction
    17942
    P1534
    Intake Camshaft Contr.Circ.,Bank2 Short to B+
    17943
    P1535
    Intake Camshaft Contr.Circ.,Bank2 Short to Ground
    17944
    P1536
    Intake Camshaft Contr.Circ.,Bank2 Open
    17945
    P1537
    Engine Shutoff Solenoid Malfunction
    17946
    P1538
    Engine Shutoff Solenoid Open/Short to Ground
    17947
    P1539
    Clutch Vacuum Vent Valve Switch Incorrect signal
    17948
    P1540
    Vehicle Speed Sensor High Input
    17949
    P1541
    Fuel Pump Relay Circ Open
    17950
    P1542
    Throttle Actuation Potentiometer Range/Performance
    17951
    P1543
    Throttle Actuation Potentiometer Signal too Low
    17952
    P1544
    Throttle Actuation Potentiometer Signal too High
    17953
    P1545
    Throttle Pos.Contr Malfunction
    17954
    P1546
    Boost Pressure Contr.Valve Short to B+
    17955
    P1547
    Boost Pressure Contr.Valve Short to Ground
    17956
    P1548
    Boost Pressure Contr.Valve Open
    17957
    P1549
    17958
    P1550
    Charge Pressure Deviation
    17959
    P1551
    Barometric Pressure Sensor Circ. Short to B+
    17960
    P1552
    Barometric Pressure Sensor Circ. Open/Short to Ground
    17961
    P1553
    Barometric/manifold pressure signal ratio out of range
    17962
    P1554
    Idle Speed Contr.Throttle Pos. Basic Setting Conditions not met
    17963
    P1555
    Charge Pressure Upper Limit exceeded
    17964
    P1556
    Charge Pressure Contr. Negative Deviation
    17965
    P1557
    Charge Pressure Contr. Positive Deviation
    17966
    P1558
    Throttle Actuator Electrical Malfunction
    17967
    P1559
    Idle Speed Contr.Throttle Pos. Adaptation Malfunction
    17968
    P1560
    Maximum Engine Speed Exceeded
    17969
    P1561
    Quantity Adjuster Deviation
    17970
    P1562
    Quantity Adjuster Upper Limit Attained
    17971
    P1563
    Quantity Adjuster Lower Limit Attained
    17972
    P1564
    Idle Speed Contr.Throttle Pos. Low Voltage During Adaptation
    17973
    P1565
    Idle Speed Control Throttle Position lower limit not attained
    17974
    P1566
    Load signal from A/C compressor range/performance
    17975
    P1567
    Load signal from A/C compressor no signal
    17976
    P1568
    Idle Speed Contr.Throttle Pos. mechanical Malfunction
    17977
    P1569
    Cruise control switch Incorrect signal
    17978
    P1570
    Contr.Module Locked
    17979
    P1571
    Left Eng. Mount Solenoid Valve Short to B+
    17980
    P1572
    Left Eng. Mount Solenoid Valve Short to ground
    17981
    P1573
    Left Eng. Mount Solenoid Valve Open circuit
    17982
    P1574
    Left Eng. Mount Solenoid Valve Electrical fault in circuit
    17983
    P1575
    Right Eng. Mount Solenoid Valve Short to B+
    17984
    P1576
    Right Eng. Mount Solenoid Valve Short to ground
    17985
    P1577
    Right Eng. Mount Solenoid Valve Open circuit
    17986
    P1578
    Right Eng. Mount Solenoid Valve Electrical fault in circuit
    17987
    P1579
    Idle Speed Contr.Throttle Pos. Adaptation not started
    17988
    P1580
    Throttle Actuator B1 Malfunction
    17989
    P1581
    Idle Speed Contr.Throttle Pos. Basic Setting Not Carried Out
    17990
    P1582
    Idle Adaptation at Limit
    17991
    P1583
    Transmission mount valves Short to B+
    17992
    P1584
    Transmission mount valves Short to ground
    17993
    P1585
    Transmission mount valves Open circuit
    17994
    P1586
    Engine mount solenoid valves Short to B+
    17995
    P1587
    Engine mount solenoid valves Short to ground
    17996
    P1588
    Engine mount solenoid valves Open circuit
    18008
    P1600
    Power Supply (B+) Terminal 15 Low Voltage
    18010
    P1602
    Power Supply (B+) Terminal 30 Low Voltage
    18011
    P1603
    Internal Control Module Malfunction
    18012
    P1604
    Internal Control Module Driver Error
    18013
    P1605
    Rough Road/Acceleration Sensor Electrical Malfunction
    18014
    P1606
    Rough Road Spec Engine Torque ABS-ECU Electrical Malfunction
    18015
    P1607
    Vehicle speed signal Error message from instrument cluster
    18016
    P1608
    Steering angle signal Error message from steering angle sensor
    18017
    P1609
    Crash shut-down activated
    18019
    P1611
    MIL Call-up Circ./Transm.Contr.Module Short to Ground
    18020
    P1612
    Electronic Control Module Incorrect Coding
    18021
    P1613
    MIL Call-up Circ Open/Short to B+
    18022
    P1614
    MIL Call-up Circ./Transm.Contr.Module Range/Performance
    18023
    P1615
    Engine Oil Temperature Sensor Circuit range/performance
    18024
    P1616
    Glow Plug/Heater Indicator Circ. Short to B+
    18025
    P1617
    Glow Plug/Heater Indicator Circ. Open/Short to Ground
    18026
    P1618
    Glow Plug/Heater Relay Circ. Short to B+
    18027
    P1619
    Glow Plug/Heater Relay Circ. Open/Short to Ground
    18028
    P1620
    Engine coolant temperature signal open/short to B+
    18029
    P1621
    Engine coolant temperature signal short to ground
    18030
    P1622
    Engine coolant temperature signal range/performance
    18031
    P1623
    Data Bus Powertrain No Communication
    18032
    P1624
    MIL Request Sign.active
    18033
    P1625
    Data-Bus Powertrain Unplausible Message from Transm.Contr.
    18034
    P1626
    Data-Bus Powertrain Missing Message from Transm.Contr.
    18035
    P1627
    Data-Bus Powertrain missing message from fuel injection pump
    18036
    P1628
    Data-Bus Powertrain missing message from steering sensor
    18037
    P1629
    Data-Bus Powertrain missing message from distance control
    18038
    P1630
    Accelera.Pedal Pos.Sensor 1 Signal too Low
    18039
    P1631
    Accelera.Pedal Pos.Sensor 1 Signal too High
    18040
    P1632
    Accelera.Pedal Pos.Sensor 1 Power Supply Malfunction
    18041
    P1633
    Accelera.Pedal Pos.Sensor 2 Signal too Low
    18042
    P1634
    Accelera.Pedal Pos.Sensor 2 Signal too High
    18043
    P1635
    Data Bus Powertrain missing message f.air condition control
    18044
    P1636
    Data Bus Powertrain missing message from Airbag control
    18045
    P1637
    Data Bus Powertrain missing message f.central electr.control
    18046
    P1638
    Data Bus Powertrain missing message from clutch control
    18047
    P1639
    Accelera.Pedal Pos.Sensor 1+2 Range/Performance
    18048
    P1640
    Internal Contr.Module (EEPROM) Error
    18049
    P1641
    Please check DTC Memory of Air Condition ECU
    18050
    P1642
    Please check DTC Memory of Airbag ECU
    18051
    P1643
    Please check DTC Memory of central electric ECU
    18052
    P1644
    Please check DTC Memory of clutch ECU
    18053
    P1645
    Data Bus Powertrain missing message f.all wheel drive contr.
    18054
    P1646
    Please Check DTC Memory of all wheel drive ECU
    18055
    P1647
    Please check coding of ECUs in Data Bus Powertrain
    18056
    P1648
    Data Bus Powertrain Malfunction
    18057
    P1649
    Data Bus Powertrain Missing message from ABS Control Module
    18058
    P1650
    Data Bus Powertrain Missing message fr.instrument panel ECU
    18059
    P1651
    Data Bus Powertrain missing messages
    18060
    P1652
    Please check DTC Memory of transmission ECU
    18061
    P1653
    Please check DTC Memory of ABS Control Module
    18062
    P1654
    Please check DTC Memory of control panel ECU
    18063
    P1655
    Please check DTC Memory of ADR Control Module
    18064
    P1656
    A/C clutch relay circuit short to ground
    18065
    P1657
    A/C clutch relay circuit short to B+
    18066
    P1658
    Data Bus Powertrain Incorrect signal from ADR Control Module
    18084
    P1676
    Drive by Wire-MIL Circ. Electrical Malfunction
    18085
    P1677
    Drive by Wire-MIL Circ. Short to B+
    18086
    P1678
    Drive by Wire-MIL Circ. Short to Ground
    18087
    P1679
    Drive by Wire-MIL Circ. Open
    18089
    P1681
    Contr.Unit Programming, Programming not Finished
    18092
    P1684
    Contr.Unit Programming Communication Error
    18094
    P1686
    Contr.Unit Error Programming Error
    18098
    P1690
    Malfunction Indication Light Malfunction
    18099
    P1691
    Malfunction Indication Light Open
    18100
    P1692
    Malfunction Indication Light Short to Ground
    18101
    P1693
    Malfunction Indication Light Short to B+
    18102
    P1694
    Malfunction Indication Light Open/Short to Ground
    18112
    P1704
    Kick Down Switch Malfunction
    18113
    P1705
    Gear/Ratio Monitoring Adaptation limit reached
    18119
    P1711
    Wheel Speed Signal 1 Range/Performance
    18124
    P1716
    Wheel Speed Signal 2 Range/Performance
    18129
    P1721
    Wheel Speed Signal 3 Range/Performance
    18131
    P1723
    Starter Interlock Circ. Open
    18132
    P1724
    Starter Interlock Circ. Short to Ground
    18134
    P1726
    Wheel Speed Signal 4 Range/Performance
    18136
    P1728
    Different Wheel Speed Signals Range/Performance
    18137
    P1729
    Starter Interlock Circ. Short to B+
    18141
    P1733
    Tiptronic Switch Down Circ. Short to Ground
    18147
    P1739
    Tiptronic Switch up Circ. Short to Ground
    18148
    P1740
    Clutch temperature control
    18149
    P1741
    Clutch pressure adaptation at limit
    18150
    P1742
    Clutch torque adaptation at limit
    18151
    P1743
    Clutch slip control signal too high
    18152
    P1744
    Tiptronic Switch Recognition Circ. Short to Ground
    18153
    P1745
    Transm.Contr.Unit Relay Short to B+
    18154
    P1746
    Transm.Contr.Unit Relay Malfunction
    18155
    P1747
    Transm.Contr.Unit Relay Open/Short to Ground
    18156
    P1748
    Transm.Contr.Unit Self-Check
    18157
    P1749
    Transm.Contr.Unit Incorrect Coded
    18158
    P1750
    Power Supply Voltage Low Voltage
    18159
    P1751
    Power Supply Voltage High Voltage
    18160
    P1752
    18168
    P1760
    Shift Lock Malfunction
    18169
    P1761
    Shift Lock Short to Ground
    18170
    P1762
    Shift Lock Short to B+
    18171
    P1763
    Shift Lock Open
    18172
    P1764
    Transmission temperature control
    18173
    P1765
    Hydraulic Pressure Sensor 2 adaptation at limit
    18174
    P1766
    Throttle Angle Signal Stuck Off
    18175
    P1767
    Throttle Angle Signal Stuck On
    18176
    P1768
    Hydraulic Pressure Sensor 2 Too High
    18177
    P1769
    Hydraulic Pressure Sensor 2 Too Low
    18178
    P1770
    Load Signal Range/Performance
    18179
    P1771
    Load Signal Stuck Off
    18180
    P1772
    Load Signal Stuck On
    18181
    P1773
    Hydraulic Pressure Sensor 1 Too High
    18182
    P1774
    Hydraulic Pressure Sensor 1 Too Low
    18183
    P1775
    Hydraulic Pressure Sensor 1 adaptation at limit
    18184
    P1776
    Hydraulic Pressure Sensor 1 range/performance
    18185
    P1777
    Hydraulic Pressure Sensor 2 range/performance
    18186
    P1778
    Solenoid EV7 Electrical Malfunction
    18189
    P1781
    Engine Torque Reduction Open/Short to Ground
    18190
    P1782
    Engine Torque Reduction Short to B+
    18192
    P1784
    Shift up/down Wire Open/Short to Ground
    18193
    P1785
    Shift up/down Wire Short to B+
    18194
    P1786
    Reversing Light Circ. Open
    18195
    P1787
    Reversing Light Circ. Short to Ground
    18196
    P1788
    Reversing Light Circ. Short to B+
    18197
    P1789
    Idle Speed Intervention Circ. Error Message from Engine Contr.
    18198
    P1790
    Transmission Range Display Circ. Open
    18199
    P1791
    Transmission Range Display Circ. Short to Ground
    18200
    P1792
    Transmission Range Display Circ. Short to B+
    18201
    P1793
    2003 1.8T
    Jul 11 2008
    B6 A4 Avant
    Gilbert AZ
    the button that has ESP on it on the same row with the cup holder
    Senior Member Two Rings Peoples-2's Avatar
    Oct 24 2008
    Florida
    Mine always comes on for a few seconds when I go over a huge dip from the parking lot at my school and accelerate too fast. :$
    Senior Member Three Rings mtshank's Avatar
    Mar 26 2008
    B6A4 | 01 V70 | 73 Jeep Commando
    Salmon Creek, WA
    Bad MAF cause mine to go on^^^^^^^are we really going to read all of the VAG codes?????
    | UNITRONICS | FORGE | H&R | BILSTEIN | TECHTONICS | BORLA | BOSCH | LAMINIX | MATRIX INTEGRATED | A.S.S. |
    The Northwest's Premier Audi Group
    BLACK DOORBLADE ALLIANCE MEMBER #4
    Veteran Member Three Rings davidlizard's Avatar
    May 01 2008
    2004 A4 ultrasport 6speed
    Winter
    the owner book says that the ESP light can turn on by itself because a system error, it also says to turn off the engine and turn it on again to reboot the ESP system.
    Unitronic stage 2+ / Borg Warner K04 / Milltek / ATP 3" testpipe / Racetec FMIC / Forge TIP / Carbonio / Forge DV / 386cc / 034 25mm rear sway /Joey moded / Podi / JHM 350mm BBK & SS lines / STaSIS street sport/ Michelin Pilot Super Sport / ECS Tuning lightweight flywheel + RA4 clutch kit /
    034 engine & trans mounts / 034 snub mount / 034 front & rear link / Apikol rear diff mount / JHM solid short shifter
    Veteran Member Four Rings GO-GOTEKNO's Avatar
    Nov 06 2007
    B5 S4
    Houston
    i had the same problem before I left the states and it was a cam tensioner sensor
    Jul 16 2008
    05 Avant 1.8t Qtip
    Toronto, On
    well thank for all the help guys, especially the VAG-codes, lol. I turned the car off yesterday and it didnt come back on last night or today, so hopefully its nothin big, just a system error
    Mar 27 2005
    The Cold North
    mine sometimes comes on (stays on till i turn the car off, then back on) when i enter or exit a off camber driveway when a wheel comes off the ground. It is usually paired with the ABS light. Once i turn the car off, then back on it goes away. The system senses a wheel is not contacting the ground and puts in safe/limp mode.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Senior Member Two Rings mattiouti's Avatar
    Jul 29 2007
    2003 A4 Quattro
    Tampa/ St. Pete, Fl
    mine was doing the same thing a couple of months ago. i replaced the brake pedal switch ( 5-10 dollar part) from audi i believe
    Jul 29 2007
    2003 A4 Quattro
    Tampa/ St. Pete, Fl
    Oct 21 2008
    Turbo M3
    NC
    how do you turn off esp?
    Senior Member Three Rings jonsaudi's Avatar
    Jan 09 2008
    2003 A4 1.8T tip quattro
    California
    Could be a number of things. One quick fix is (and I'm sure someone has mentioned this) replace brake sensor. $9.00 part that could possibly fix your problem. VW dealers carry this part. I would look into this first before anything. Just have someone press the brake for you and stand in the back...if the brake lights stay on while foot is off the brake, then it's brake sensor for sure. Faulty brake sensor can kick in the ESP light for no reason. Good luck.
    • 03 A4 B6 1.8T • Tiptronic • Brilliant Black • quattro • Sport Pkg //18" RS4 style rims //35% tint //Zimmermann x-drilled //Hawk HPS //CF wrapped trim.
    Sep 27 2008
    do u have any other lights like the ABS or anything. my esp light was on constatly along with my abs light once in awhile.after using vag we replaced the clock spring and adapted the steering wheel angle sensor which fixed it.
    Jul 16 2008
    05 Avant 1.8t Qtip
    Toronto, On
    Quote Originally Posted by jonsaudi View Post
    so when i originally posted this thread that night i turned off the car and the light went off, but last night it came back, so i did this break test, and the brakes seem fine, when i let go of the pedal then lights go off, like normal. So now i gotta figure out what this could be.
    Any ideas?
    And also if i leave it could it get worse or can something else go wrong?
    Jul 16 2008
    05 Avant 1.8t Qtip
    Toronto, On
    Quote Originally Posted by 05Audi1.8T View Post
    no other lights are on. Anything else i should look out for?
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 16 2007
    2003 RS6
    Chicago Burbsss
    Could that be because of giving someone a jump?
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Jul 29 2007
    2003 A4 Quattro
    Tampa/ St. Pete, Fl
    Quote Originally Posted by sergeA4 View Post
    Any ideas?
    just because the lights come on in the rear when you press the braked does not mean that the switch is good. the switch controls a lot more than just the brake lights. like cruise control, esp, and maybe some others... personally i would try the switch, its a cheap part and it worked for me. but thats just my .02
    Veteran Member Four Rings NightRoller USP's Avatar
    Aug 23 2008
    2008 Rs4
    Quote Originally Posted by sti4now View Post
    Push the button to turn it off......a little light comes up on the screen and you go have fun!!!
    Push the button again to turn ESP on.......little light goes off and you become a responsible driver!
    Jacob
    AWE ll APIKOL ll PODI
    USPCLUBMEMBER#190
    Jul 16 2008
    05 Avant 1.8t Qtip
    Toronto, On
    well is this something i should replace right away?
    can this get worse and cause bigger problems, cause if its not ill leave it till the new year?
    Established Member Two Rings 05silvera4's Avatar
    Jul 10 2008
    2005 Audi A4 1.8T Silver
    Michigan
    dudeee the same exact thing is happening to my car.... i have nooo clue why.... it will randomly go on after like 10 or 15 minutes of driving and wont turn off even if u press the ESP button..... I was about to post this yesterday about my problem...
    Jan 09 2008
    California
    The sooner your try to replace the brake light switch the, the sooner you can possibly fix your problem. It wouldn't hurt to spend $10 on a part that can most likely fix your problem. Check your local VW dealership, they're usually cheaper than Audi for the same exact part. It also comes with install instructions. Really cheap and easy fix. I say go for it!
    See replies above about replacing brake light switch.
    Jun 26 2008
    Park City, UT
    I'm in the same boat. Been going on for a about a week now. Is constantly on now. Wasn't driving out of the norm, can't get it to go off now. I have a VAG and I'm seeing no codes come up for it. Didn't jump anyone, or do anything else, it was just normal then bam. Have no idea.
    Jun 26 2008
    Park City, UT
    bump for needing to get it fixed
    Senior Member Three Rings kastro's Avatar
    Mar 20 2008
    04.5 1.8TQ Tip A4 Black -
    Ottawa, Ontario
    if you have a faulty brake light switch (5$ part literally) it sets off the esp light. the car things the car is braking and accelerating at once so it shuts off esp.
    OEM is sexy.
    Established Member Two Rings Keithr726's Avatar
    Aug 11 2008
    Launch at Audi on demand, Audi at home
    SF
    Just for the record, my esp light stayed on when I blew a IC pipe clamp.
    Registered Member Two Rings B6AVANTUSP's Avatar
    Jun 27 2008
    i heard through the grapevine that it could alsohave sumthin to do wit your anti lock brake system ~ABS~
    Jul 21 2008
    2004 A4 1.8TQ Tip
    Auburn, NY
    my ESP light came on last year and wouldnt go off...it was the MAF sensor
    i replaced the maf and its been good ever since
    Senior Member Two Rings DavoMotor_1.8T's Avatar
    Mar 17 2009
    CLK500,FX35
    Puerto Rico
    Quote Originally Posted by chuckA84 View Post
    X2
    Active Member Two Rings Wally's Avatar
    Dec 18 2006
    Aspen, CO
    any updates here, my light started coming on in the eveings this summer when it was 100* on my way home, driving like a little old lady at 55mph, and wouldn't turn off, but every morning on the way to work it was fine when it was 65* degrees out. I figured maybe it was a heat thing, then this morning it was 39* and it popped back on 15 min into my flat land drive at 55mph? I checked the brake light thing and they work, so i guess i should order the brake light switch first? On a side note, a few times i've lost throttle response, where i'm going down the road and pushing on the pedal with no response, i push the clutch in, let it back out and the throttle is fine? This has only happened maybe 3-4 times, the ESP light has happned like 30-40 times.....the car does have 145K on it?
    Veteran Member Four Rings Tgr_Clw's Avatar
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Quote Originally Posted by mattiouti View Post
    I had the same issue and same solution a number of months ago.
    Appearance: OEM+
    Interior: B6 S4 Recaro Seats
    Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
    Suspension: Vogtland Coilovers / HSport S4 Sways
    Braking: Stoptech 332 BBK
    Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
