Results 1 to 16 of 16
    Veteran Member Four Rings 'mk4-turbo's Avatar
    Oct 02 2007
    Montreal
    Question How Does The Headlight Washers Activate?
    My front end got replaced and i wanted to make sure that they work (cause i don't trus the dealers work anymore). I pul my washer fluid handle for 2+ seconds...the windshield washers work but nothing comes out for the headlights...and yes i do hve this option
    is there something i'm not doing right?
    thanks
    Established Member Two Rings dmott11's Avatar
    Jan 28 2008
    MA.USA
    Re: How Does The Headlight Washers Activate?
    headlights on?
    "slow is smooth and smooth is fast"
    Oct 02 2007
    Montreal
    the xenon has to be on?
    Senior Member Three Rings Allan T's Avatar
    Sep 28 2006
    Audi a4 b7 2.0 Tfsi quattro avant sline
    Sweden
    Get a friend to stand outside the car and look at the front when you pull the washer fluid handle to check that is works, this is they way to activate headlight washers. And like the others say, the headlights has to be on.
    Mod list = To long to write.
    http://www.garaget.org/?car=118660
    Veteran Member Four Rings chrislane31's Avatar
    Mar 24 2007
    They only work with the headlights on.
    Oct 02 2007
    Montreal
    ok...so i tried it and yes the headlights have to be on in order for the sprays to activate
    thanks
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    so how much did it end up costing you? did the girls dad end up paying?
    The usual things!!
    Resistor Install
    Veteran Member Three Rings rpmfoundation's Avatar
    Aug 25 2008
    2012 Toyota Highlander Hybrid Limited (wtf)
    Hollywood Hills, CA
    I didn't even know that was possible lol.
    my car is still on AZ... someone else is just driving it (BMO).
    Senior Member Two Rings DOBERMAN@UA's Avatar
    Sep 15 2008
    A6 c6 3.0 Tdi (300hp)
    Ukraine, Kiev
    Quote Originally Posted by Allan T View Post
    HOw is it possible to turn off washers when the headlight is on?
    A6c6 3.0 tdi(300hp), koni sport shocks, eibach pro kit springs, q5 4pot brake calliper, a8d3 sport seats
    Oct 02 2007
    Montreal
    Quote Originally Posted by cstarky15 View Post
    no i had to pay out of my own pocket $4300...you could imagine how many punches i would've loved to give that girl in the face
    Feb 16 2008
    Oakdale, MN
    Quote Originally Posted by 'mk4-turbo View Post
    WOW that is terrible. I'm glad you got it fixed pretty quick and everything seems to be working just fine!
    The usual things!!
    Resistor Install
    Sep 28 2006
    Sweden
    Quote Originally Posted by DOBERMAN@UA View Post
    The washers activate when you pull the washer fluid handle, when the headlights is on. And when you let go of the handle it deactivates.
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    If you twist the passenger side headlight washer nozzle 30 degrees to the right you can blast people on the sidewalk while driving.
    Veteran Member Four Rings KareemA4's Avatar
    May 04 2008
    B6 A4, C6 A6, 08 TT
    Miami, FL
    ^^haha
    Sep 28 2006
    Sweden
    Quote Originally Posted by [email protected] View Post
    LOL
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    haha too funny
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
