Results 1 to 7 of 7
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    How do you convert Mbar to PSI?
    What does mbar stand for? is it milibar?
    How do you convert mbar to psi?
    I'm logging block 115 on vag with my car and it says the requested boost is around 1800 mbar. what is that when converted to psi?
    I tried googling it and its saying 26psi. but that cant be right. my gauge is saying around 12psi for 1800 mbar. just wanted to make sure its accurate
    the requested boost compared to actual boost is pretty close. Anyway if someone knows what 1800 mbar is converted to psi that would be great.
    or even better what 1810, 1820, 1830 are converted as well.
    Thanks
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Established Member Two Rings RenegadeEngr's Avatar
    Jun 15 2008
    San Francisco
    Re: How do you convert Mbar to PSI?
    1 millibar = 0.0145037738 pounds per square inch ...do you have a calculator? make sure you subtract relative atmospheric pressure ~900mbar or ~14psi ....I thought I'd answer your question before you get flamed.
    2001:Silver:S4:DarIntake:ABT Chip
    Mechanical/Fluids Engineer
    Feb 09 2007
    00 S4
    MA
    iirc one bar= 14.5 PSI... but I dont know exactly what a millibar is.
    Buy tools, not labor....
    00 Audi A4, 1.8TQ avant, 6-speed swapped (from auto), s4 brakes, uprights, cluster, grill, OEM bmw style 162 wheels, slammed.
    95 BMW M3 drift car: OBD1 S52, gutted, tubed, flares, angle.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Veteran Member Three Rings hoosierchemist's Avatar
    Apr 12 2008
    2000 Nogaro S4
    Indiana
    Quote Originally Posted by Blake260 View Post
    milli is the prefix, like in milliliter and millimeter, so milli = 0.001
    also, 1000 mbar = 1 bar. you can finish up from here.
    Jan 25 2006
    A4 2.0T
    MD
    return (millibar - 1000) * 0.0145037738;
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Quote Originally Posted by Don Supreme View Post
    This was very helpful:
    1830 - 1000 * .0145037738 = 11.89 psi
    So my guage seams pretty accurate to what the actual boost it is being requested.
    Thanks and flame away. I used to be good at math. Ok maybe not.
