Results 1 to 23 of 23
    Senior Member Two Rings BryMFL's Avatar
    Apr 20 2007
    '02 Audi 1.8T Quattro
    Winter Haven, FL
    Unhappy Code P0012 How serious is this?
    I'm 800 miles from home and got an engine light on. I had Advanced check it and they gave me: Code P0012" Camshaft Position Actuator A-Bank 1 Timing over Retard". I called Audi service and they said something about the camshaft tensioner chain was loose. How bad is this and is it something I can fix? I did the entire timing belt/water pump service back in Spring time so I should be able to get this. Please feel free to put in your two cents. Thanks
    "BryMFL"
    Bryan Meeks
    "Quattro- It's like having your very own roller coaster ride!"
    Veteran Member Three Rings fitch303's Avatar
    Jan 03 2008
    Columbus, Ohio
    Re: Code P0012 How serious is this?
    You could bend a valve(s) I wouldn't drive it until it's fixed. Why on gods earth did Audi use a slave setup for the cams?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    The purpose of the camshaft adjuster is to advance the intake valve opening during a cold start. This allows for the intake to scavenge more of the exhaust gasses and generate heat in the intake faster, thus reducing emissions. This is an integral part of the 1.8T meeting the ULEV standards. If the cam adjuster doesn't work properly the intake cam will not advance on a cold start and you will get a code P0012. After the car is up to temperature the intake cam returns to its normal operating offset. For a more detailed explanation read section 2.1.3Clicky click I would recommend just resetting the code and see if it comes back. As long as you are not hearing a lot of cam chain rattle your car should be OK to drive.
    Cheers!
    Apr 20 2007
    Winter Haven, FL
    Thanks Old Guy, I believe I already have chain rattle or something. At idle some is rattling but it goes away after about 1000-1200rpm's. There don't seem to be any other problems with the car as of now. I have driven about 300 miles since the check light came on and nothing has changed except the rattle starting. What parts am I looking at having to replace and how bad is the job?
    "BryMFL"
    Bryan Meeks
    Dec 28 2006
    Western Maryland
    Here is a DIY for replacing the cam chain tensioner. It is for a Passat but the procedure is essentially the same.Clicky click. Here is another one. Clicky click Unfortunately the part is rather expensive. Clicky click
    Apr 20 2007
    Winter Haven, FL
    So hands down this is the only thing possible for it to be? Could I have a bent valve? While I'm in there for this job is there anything else I should do as a preventative maintenance thing?
    "BryMFL"
    Bryan Meeks
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by BryMFL View Post
    I doubt you have a bent valve if your motor appears to be running OK. What you are describing (rattling accompanied with the P0012) is a pretty strong indication of a problem with the cam adjuster. While you are in there you obviously will replace the front and rear cam seals along with the valve cover gasket. That is really about it.
    Good luck!
    Apr 20 2007
    Winter Haven, FL
    Got it done today. Pretty simple install took me about 5 hours (Yes I know I'm slow). Have to wait till tomorrow to run it, but it started fine. I'll give an update after tomorrow....well on second thought I have to drive 1200 miles over the next 5 days so I'll do it afterward.
    "BryMFL"
    Bryan Meeks
    Dec 28 2006
    Western Maryland
    Nice job! You just saved yourself hundreds of $$$!!
    Senior Member Three Rings Hotel Guy's Avatar
    Oct 07 2007
    Chicago
    So whats the official outcome? I believe I have this same issue (tin-like rattle from 2k-3k rpms) and was told that its most likely the Cam Chain Tensioner. I was also told that this would be approximately $1,900 to fix at a local european service store. Anyone have any input?
    What was your total cost for the DIY? Difficulty on a scale of 1-10?
    May 23 2008
    Denver
    Hell yea Hotel Guy.... I'm a Spartan Alum
    (sorry for the thread jacking)
    Apr 20 2007
    Winter Haven, FL
    Quote Originally Posted by Hotel Guy View Post
    My cost was about $550 in parts and the difficulty level was probably about an 5 or 6. I found a website that carried the chain tensioner for $350 after buying it for $460 http://www.mjmautohaus.com/catalog/p...oducts_id=2180
    "BryMFL"
    Bryan Meeks
    Mar 28 2007
    Arlington, WA
    After changing the Chain Tencioner
    I have recently changed my chain tencioner and right after I did it the noice went away. However, i keep on getting the code p0012. I reset it but it came back on again after making a 10 mile trip. What can it be? Where should I try to troubleshoot?
    Jun 27 2010
    US
    Quote Originally Posted by fitch303 View Post
    You could NOT bend a valve. The range of adjustment on a cam adjuster (even a failed one) does not reach that point at either end of it's travel...it makes advances and retards of the intake cam in relation to the exhaust cam well within mechanical limits of piston clears....not the effect of T-belt breaking.
    Jun 27 2010
    US
    The purpose of the camshaft adjuster is to advance the intake valve opening during a cold start. This allows for the intake to scavenge more of the exhaust gasses and generate heat in the intake faster, thus reducing emissions. This is an integral part of the 1.8T meeting the ULEV standards. If the cam adjuster doesn't work properly the intake cam will not advance on a cold start and you will get a code P0012. After the car is up to temperature the intake cam returns to its normal operating offset. For a more detailed explanation read section 2.1.3 (Clicky click). I would recommend just resetting the code and see if it comes back. As long as you are not hearing a lot of cam chain rattle your car should be OK to drive.
    Cheers!
    Very odd system, cosidering Audi V6 and V8 engines with VVT start locked in the most retarded cam position, until more oil pressure is built up...then only advances slightly. Max advance is used under heavy torque at the higher rpms, to help maintain max torque curve...much like ignition timing advances as rpms go up, all the way back to early vacuum advance point ignition distibutors, which started the car at maximum spark retard position (they would not even start if timing was a little to advanced).
    I can inder stand wht Audi had to fight rough running at such advanced settings on the 1.8T system.
    Dec 28 2006
    Western Maryland
    Fixed the link( from the 2 year old post): Clicky click Read section 2.1.3.
    cheers!
    Sep 15 2010
    massapequa ny
    Can you change the cam seals without any special tools? I know they came with timing belt kit but never changed them. If you definately need a tool do you know which one. Not for b6 but for a b5 1.8 aeb with 296k miles
    Aug 26 2005
    The cam chain wears too. Should be changed at the same time as the VVT adjuster/tensioner.
    Vorsprung durch Technik
    Senior Member Three Rings tamaneri's Avatar
    Apr 02 2007
    New Jersey (Northern)
    i have a weird rattle, but the heck could i know if it's the cam chain tensioner?
    Taylor A. Maneri
    2003 A4 1.8TQ B6 Black/Black
    Unitronic Stage 2 | TT 386cc injectors | RAI test pipe | Magnaflow 16601 | Milltek downpipe | Forge 007 DV | rs4 rear sway | vent pod boost gauge | JHM short throw | 034 engine mounts | ARP snub | ECS RA4 stage 1 clutch/flywheel | Bilstein / H&R
    tamaneri (AIM)
    Jun 19 2013
    supercharged nissan Xterra, 3g taco
    Chicagoland
    I've this same code pop up on me but I do not hear any chain rattle. Are there any other possibilities?
    Senior Member Three Rings Kodymfk's Avatar
    Jun 07 2012
    Black B6 A4 416whp e85 5 spd, Black AllRoad Static (tip)
    Lansing Michigan
    I got this code after replacing a cam chain tensioner. It was fine to begin with, just had a horrible tensioner gasket leak and it looked worn so I replaced it with a cheap cam chain tensioner on ebay (car has 202000miles, figured why buy expsensive. its for my winter beater a4). May just swap new guides off ebay one onto older one and reinstall the old one. I assume it may have something to do with it only costing $80 lolz.
    e85, meth, 30psi, 1.8T All the Way Check my build out! http://www.audizine.com/forum/showth...-build-on-methI'm also on the FB Kody K
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by Kodymfk View Post
    Unfortunately that seem to be a common theme lately. Aftermarket cam tensioners going out rather quickly.
    Senior Member Two Rings CaribGrunt's Avatar
    Feb 05 2014
    2011 A4 2.0 MT TI
    Washington D.C.
    I got a cam shaft timing code, abnoxious rattle at idle. Going to mechanic tomorrow. Hope it's not too expensive, it's my daily driver.
    11' TI // Brilliant Black// MT, P+, Sports Package, NAV, Back Up Cam // 19" S-Line Rotors // Black Optics
    Mods: aFe Pro-Dry S, Muffler Delete, de-badged, 35% Tint, Hoen Endurance Fogs
    Coming: Tune2Air, LEDs license plate
