Results 1 to 10 of 10
    Senior Member Two Rings jab3style's Avatar
    Mar 18 2004
    03 1.8t/ 04 Armada LE
    NorCal
    Rattling noise from engine or under car... HELP!
    So last night driving home from Reno, I pull into a gas station and realized there is this annoying loud rattling sound comming from underneath the car. My first thoughts is that it might be exhaust rattle becuase upon reving her a bit the noise goes away. It had no affect on the performance. She runs like a champ.
    This morning I go start her up and the noise is gone. I figure it might only rattle if car is warmed up. Took her out on the highway and still no rattle, but now there is a check engine light...WTF.
    This is the first time I ever had any problems with her. She has over 100k miles and regularly maintained. Any thoughts or ideas will be appreciated.
    2003 frnt trash, 1.8t, manual. Revo stage 1,
    Veteran Member Four Rings alexza4's Avatar
    Apr 23 2007
    19-S5||22-GV70||14-RAM1500Hemi
    Re: Rattling noise from engine or under car... HELP!
    Sure does sound like it could be exhaust related, maybe a loose bolt... i'd say get her Vagged for starters.
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
    2003 A4 QM Uni EFR 6758 on meth - SOLD :((
    2003 A4 GIAC KO4 - SOLD
    Senior Member Three Rings Hotel Guy's Avatar
    Oct 07 2007
    Chicago
    Ive got the same issue. Havent gotten it scanned for codes yet. I get an intermittent CEL and think that its my CAT/O2 sensors. Im over 100k as well. Not looking forward to getting this fixed as I hear that CATs are pricey, but maybe I could find one in the classifieds because Im not looking to get a test pipe or do any non-OEM exhaust modifications.
    Mar 18 2004
    NorCal
    Well it can't be my cat. I have a test pipe. I do recall having a check light right after I had the timiing belt replaced. A week later it went away. Tech said the car adjust itself. I guess I'm gonna have to get her Vag'd.
    Veteran Member Four Rings krew53's Avatar
    2023 RS6 - 2013 B8.5 S4 - 2003 B6 1.8BT quattro
    Simi Valley, CA
    Check your bolts on the test pipe... I had one come loose before causing a rattle.
    Veteran Member Four Rings FireWire's Avatar
    Sep 22 2007
    03 Q1.8T B6
    San Jose , CA
    heatshield?
    Typ 8E 03 1.8t Quattro
    2006 600RR
    my photos
    Mar 18 2004
    NorCal
    Just figured it out... Ouch!!! Camshaft Tensioner. The rattle is comming from the back side of the head near the firewall. Spoke to a couple friends that had the same probs and the owner of the shop that cured it. Man this is about G to fix.
    Veteran Member Four Rings yoogene83's Avatar
    Apr 27 2004
    2017 Pacifica Limited / 2014 BMW M5
    Seoul
    shitty!!!
    Veteran Member Three Rings 05A$SE's Avatar
    Feb 12 2008
    05 A4 1.8T Special Edition
    Dirty Jersey / Phoenix
    flywheel?
    2005 DG On Black Special Edition 1.8T 6MT
    Built 2.0L Stroker, ETC
    2012 C63 AMG - 600HP and counting
    2006 Corvette - GTR (1 of 7) - Blue One on GOOGLE
    1998 H1 - AM General 4dr Hardtop
    1992 M998 - Slantback Project
    1990 240SX - big turbo drift missile
    1989 K1500 - LQ4 6L90 Swap
    1986 RX7 - Truck conversion, LS1, 72* angle kit
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    A grand to fix with installation included I hope. I got a new vvt cam tensioner for under $350. Install should take no longer than 3-4hrs.
