Results 1 to 12 of 12
    Senior Member Two Rings Jayco88's Avatar
    Jun 02 2008
    2000 S4
    cracked oil pan....SOS
    i searched-
    well, i bottomed out my car at a rail road crossing, it hurt my soul.... checked to see the damage and it looked like it cracked my oil pan, well, more like annihilated it..... I ordered the part for 50 bucks through ebay... and after an hour of taking the damn thing out(two coolant lines and an anti roll bar cover the rear line of screws) I discover that my UPPER oil pan has some damage. it's cracked in two places...
    i was wondering if anyone knew how to take the upper oil pan out? i haven't really looked at it that well, but it looks like i might have to take the whole front off, i might be wrong....
    another thing is that the upper oil pan is only cracked in a couple of places and I was considering using jb-weld to fix that, but i don't know if that would work seeing as the oil pan is made of aluminum....
    any help is much appreciated.. i haven't driven my car in two whole weeks
    -It's got nothing to do with your vorsprung durch technic, you now.-
    Aug 06 2008
    Canadia
    Re: cracked oil pan....SOS
    something similar happened on my friends old XJR, as a temp fix he tried JB-welding it, but it disn't work too hot, so he had to do it again.
    2nd time around he opened up the crack a little with his dremel and drilled the ends of the crack so it wouldn't spread and used some silicone gasket sealer with JB weld on top, that held out pretty good untill he replaced the pan.
    Sep 21 2008
    Toronto, Canada
    the key to jbweld is to properly prep the surface to promote bonding. Hard to do when the pan on the car. i would give it a shot though, taking out the upper oil pan is a PITA from what i read.
    anyways, does anyone have any tips taking off the lower oil pan???
    i am about to tackle this...
    Do the coolant lines need to be disconnected? does the sway bar need to be removed as well??
    Senior Member Three Rings shadwarr1's Avatar
    Apr 16 2008
    2000 S4
    Gig Harbor, WA
    Oh crap I did the same thing to mine 7 months ago 3 days after I bought it! Plus I drove it for 2 blocks the next day with NO oil! Luckily no engine damage after I had a new pan put on. Hopefully you didn't damage anything else...
    2000 S4 6MT Brilliant Black ~Low Flyer~ Stage 3- stuff
    Jun 02 2008
    2000 S4
    well.... i prepped the upper oil pan with a full can of brake cleaner... used j-b weld to fill the cracks on the inside... installed lower oil pan (used plenty of gasket maker) and filled with mobil 1.. after warming the car up, and taking it for a test drive i noticed a leak the thing is, that some of the bolt holes on the flange didn't line up anymore.. so i'm missing around 4-5 bolts in there
    I think this is beyond my skill level...I'm considering taking it to a shop.. the sad part is that i just got quoted $1300 bucks, as this is an 8 hour job and the upper oil pan goes for around 400 bucks... after this, I'm selling the son of a bitch
    ps: to remove the lower oil pan, i moved the coolant lines and sway bar out of the way.
    Sep 21 2008
    Toronto, Canada
    Did you allow the jb weld to cure for a good 24 hours?
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    yes, front end needs to come off for upper oil pan
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Senior Member Three Rings tgiblin's Avatar
    Mar 27 2008
    2001 S4, 1957 Bel Air, 1972 CT70
    Don't Steal My Car
    lower pan was easy and you dont need to move anything (yes not even lines or sway bar), where is it leaking from?
    Jun 02 2008
    2000 S4
    Since i didn't remove the upper oil pan when i Jb welded it.. some of the upper oil pan's bolt holes on the flange shifted thanks to the cracks... so when i tried to install the lower oil pan there was 4-5 bolts that didn't fit in anymore. I thought that by adding more gasket maker this wouldn't be a problem.. but i was wrong... my leak is coming from the corner where those 4-5 bolts are missing, there's not enough clamping power between the upper and lower pan in that area.
    What i need to do now is remove the upper oil pan, re-jb weld it, and make sure the bolt holes on the flange align correctly... but here's my problem, i don't know how to do that(remove the upper oil pan)
    anybody got some pointers? i don't just want to start taking things apart that don't have to..
    Sep 21 2008
    Toronto, Canada
    Quote Originally Posted by tgiblin View Post
    i just finished replacing my lower oil pan.. i did have to unbolt the sway bar and the coolant lines to have enough play to be able to access the bolts.
    maybe the 00 and 01 are slightly different?
    anyhow, bro i think you should get get a new upper oil pan and just repalce it.
    if it got cracked to a point where the bolt holes no longer line-up, jb-welding will only be a temp fix at best, and you'll end up doing it all again in a couple of months.
    Senior Member Three Rings Bee Five's Avatar
    Jun 06 2008
    Northern California
    PM Freddie or Jason, they give expert advice and are nice to boot!
    /_/// 2000 S4 // Alcantara // Light Silver Metallic // Sport Package // 6-Speed
    APR Bi-Pipe // APR ECU // Fikse Mach V Wheels // Forged DV // JHM SS // Piggie Pipes
    ECS Stage4 BBK // RS4 Grill // SRP Pedals // ST Coilovers // UUC VM2 Exhaust // UUC Knob
    Veteran Member Three Rings mikeyvuitton's Avatar
    Mar 26 2007
    Denver
    ive broken 2 in 1 month. brian@avalon loves me haha.
    2005 S4 6SPD: Bagged, Rotiform, Bamboo, Hermes.
    Project Hoodrat: B5 RS4 Widebody/GT3071r
    Bruiser Brigade
