Results 1 to 26 of 26
    Veteran Member Four Rings CONTROL ONE's Avatar
    Sep 19 2008
    2014 BMW M235i 6MT, 2010 Audi S4 6MT
    Toronto, Canada
    Any B5 S4 Specific Boost Leak Test DIY?
    Searched the usual sites but couldn't come up with anything specific to the B5 S4, or even with a twin turbo setup?
    I've boost leak tested my DSM a billion times but the setup was much more convenient, just pull off the air filter and cover the actual turbo inlet with the tester to diagnose.
    I can only imagine that since we do not have access to the turbos that the only method would be through the Y-pipe opening?
    Thanks.
    Feb 09 2007
    00 S4
    MA
    Re: Any B5 S4 Specific Boost Leak Test DIY?
    yep, thru the y-pipe, and plug the hole for the pancake valve on the right.
    Buy tools, not labor....
    00 Audi A4, 1.8TQ avant, 6-speed swapped (from auto), s4 brakes, uprights, cluster, grill, OEM bmw style 162 wheels, slammed.
    95 BMW M3 drift car: OBD1 S52, gutted, tubed, flares, angle.
    Sep 19 2008
    Toronto, Canada
    Anyone know off hand what size diameter I would need to make one?
    What would be a 'safe' value to pressure test to? 25 psi?
    I'm currently running a GIAC X chip, so I would definitely want to test up to 20 psi.
    Would this method find leaks in the DV's specifically?
    Veteran Member Three Rings VinNyS4's Avatar
    Nov 07 2007
    New York City
    20psi Is To Much Try Around 10-15psi The Most If You Have A Leak Somewhere You Will Here A Hissing Sound From Where The Leak Is Coming From
    10 b8 s4 6MT sprint blue / black & silver
    Established Member Two Rings 2000 A6 2.7t 6m's Avatar
    Jul 27 2007
    PA
    Here's a write-up on how to make and use a leak tester, courtesy of AWE.
    http://www.awe-tuning.com/media/pdf/...ure_tester.pdf
    Click for Photo Album
    Upgrades:
    APR 93 ECU -=- H&R Coilovers -=- H-Sport Swaybars -=- VMR B7 RS4 Reps in Onyx Black -=- Upgraded Sound System
    Sep 19 2008
    Toronto, Canada
    Quote Originally Posted by 2000 A6 2.7t 6m View Post
    Cheers, that's just about perfect.
    May 18 2007
    01 Laser Red 6MT, 13 Touareg TDI
    Baytown, TX
    if you can't find the cap specified in the awe write-up, just get a 1" rubber chair leg nub thingy. worked for me.
    Jul 04 2007
    00 s4
    danbury
    i make them all the time, they are so easy to make, costs 7 bucks to make. home depot or lowes u can go to make one instead of spending 20 bucks. 3 in rubber cuppler, pvc cap, pvc glue, 2 clamps, dont know the name but where u fill air in tires, lol.
    Sep 19 2008
    Toronto, Canada
    Just made one myself from Home Depot today for $13.32 CDN.
    Veteran Member Three Rings NogaroWonda00's Avatar
    Jun 13 2008
    Rocky Mountains
    Quote Originally Posted by VinNyS4 View Post
    well i put 25ish thru mine, (stage 3 thou) so for you id say do a few psi higher than you peak at just in case
    By the way i still have all the stock hoses, the only thing ive had to replace was the throttle body boot......Which brings me to my next point
    open the butterfly ;)
    '00 Nogaro Blue S4
    Established Member Two Rings dfaudi's Avatar
    Sep 19 2005
    michigan
    Check out turboboostleaktesters.com
    ________________________
    2019: B6 2.1L stroker, 01e, gtx35, 2200cc e85, AEM Infinity - 629 wheel
    2020: B6 K-Swap in progress, 01e, Borg Warner s369 - goal: 1000 wheel
    Nov 06 2010
    Modesto/California/US
    had the same problem, step by step instructions on how to test a 1.8T for leaks. Cheap and fast way
    http://www.younanplex.com/engine/car...t_audi_tt.html
    cheers!
    Nov 06 2010
    ^^ if that links doesnt work...heres the direct link
    Veteran Member Four Rings JackalS4's Avatar
    Mar 01 2008
    Toronto, ON, Canada
    Quote Originally Posted by dfaudi View Post
    Ah yes, I got mine from them, T-bolt kit, gauge & all! A great kit!
    Here are a couple of pics, i'll try and do a specific pressure test write-up with this kit since i've been meaning to...
    Here's our kit (2.7T/S4):
    http://www.turboboostleaktesters.com...dsh-Kit/Detail
    They had great customer service too!
    I'll do the write-up when I get the chance.
    Brilliant Black 2001 S4 - 6MT <3
    Sep 19 2005
    michigan
    Theres also a writeup on the kit with a tire valve stem.
    http://www.turboboostleaktesters.com...101/Categories
    Active Member Two Rings camlacen's Avatar
    Apr 30 2011
    Wichita, Ks
    Sorry to bring back an old thread but not finding much information. I made my little tester with a gauge and what not. The system doesn't build any pressure at all. I have the oil fill cap off and can here the oil bubbling? Does this mean that I'm low on compression?
    Jan 29 2007
    08 S4 00 S4
    MD
    It's not supposed to build pressure. You run a sustained pressure through the intake to expose any leaks. The bubbling is normal.
    EDIT: I just reread that you aren't getting any pressure at all. What's your air source?
    08 S4- Stock SOLD
    Apr 30 2011
    Wichita, Ks
    I large compressor with a regulator set to 15 psi.
    Jan 29 2007
    08 S4 00 S4
    MD
    Maybe the gauge on your tester isn't working? It sounds like pressure is going through the intake from your description.
    08 S4- Stock SOLD
    Apr 30 2011
    Wichita, Ks
    I'm going to get plugs for the charge pipes and pressurize it to there and see if it holds anything; If the guage still isn't reading I will try a different one. There was quite a large hole in one of the charge pipes (maybe 1.5 inches by .5 inches) that was fixed but only brought me up maybe 2 psi.
    Mar 01 2008
    Toronto, ON, Canada
    Make sure you've plugged the PCV port (see my above pic) - just in case you missed this detail.
    Veteran Member Three Rings BADRVCA's Avatar
    Aug 02 2012
    b5/b6/b7
    virginia beach , VA
    When i do a Boost leak the Air stays in the intake system...any ideas why ??
    Senior Member Three Rings toolo4sno's Avatar
    Apr 29 2008
    MI
    I just bought the turbo boost leak testers device. I have used my DIY version a few times, but the PVC part frequently popped out. It hasn't been very useful, and this thing isn't that much more than the DIY parts.
    I like the gauge and valve fitting to hold the pressure and then check for leaks. I haven't checked the pressure yet, but with an OTD approaching I should. Ironically, it shipped from right down the road from here.
    I would hear the bubbling noise when using my DIY unit. I never felt very confident it told me anything. The bubbling is kinda loud and makes air leaking sounds hard to find. That or i don't have any. We'll see if seeing gauge movement helps.
    http://www.youtube.com/user/2lo4sno
    2002 Audi S4 Santorin Blue [*S4 Phoenix*] - Daily Driver/Winter Car - 2100 miles traveled to purchase and bring home (x2 trips MI to MD) [3rd set of turbos]
    2000 Audi S4 Nogaro Blue Widebody - Track day car - 4600 miles traveled to purchase (MI to CA); 2615 miles car traveled on hauler [SOLD]
    Senior Member Three Rings ETFS4's Avatar
    Oct 04 2011
    '01 Nogaro S4, '07 Honda Pilot EX-L
    The Beaches, Toronto
    Quote Originally Posted by CONTROL ONE View Post
    I see you're in Toronto control one, any time to run a check on my car?
    Dodging potholes since '91
    Apr 29 2008
    MI
    I have done some pressure tests now with the turboboost... device. I seem to be getting less loss than the 1PSI/s the guide above describes (http://www.turboboostleaktesters.com...101/Categories).
    I timed my air loss at about 16 psi per minute. I could not hear any air noises aside from the bubbles in my oil. I'm going to call it and say I don't have a leak.
