Results 1 to 10 of 10
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    Technique for cleaning door jams to avoid getting water inside the car?
    Detailing masters, I need advice:
    How do you clean the door jams without getting soap/water into the car's interior? Washing them is simple enough with a mitt, but how do you get the suds off? I definitely avoid cleaning the jams on a regular basis b/c of this problem. Its especially problematic on the rear hatch on an avant. In the past I've basicaly just turned down the water pressure for a very slow stream and removed the nossle, so that I have just a little water pouring out. Even then, I still manage to get water in the car.
    Thanks for any tips!
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Veteran Member Four Rings heateris's Avatar
    Aug 16 2004
    08 A4 2.0TQM6 ~ 08 Highlander Sport
    SE PA
    Re: Technique for cleaning door jams to avoid getting water inside the car?
    no tips, but if you scrub up the jambs once really good, you should be able to just wipe/dry them when you wash the car. i've ownd my car for over 5 years and only used soap in my jambs twice. they look showroom new.
    Veteran Member Three Rings Twista616's Avatar
    Oct 27 2005
    '14 Ibis White SQ5
    Los Angeles, CA
    i very rarely "wash" the door jambs...i only do it if its pretty nasty...otherwise, i'll just wipe them clean witha damp microfiber towel, or spay a mild degreaser if you have caked on dirt or grime. No need to go overboard with steam or spraying it with a hose...keep it simple..
    "I'm right 60% of the time, all the time!"
    2005 A4 QT-SOLD // 2006 A4 QT-SOLD
    '14 SQ5 | Ibis White | 21" Stockies | More goodies in the works
    Insta: @imgarretthess Tweetness: @imgarretthess
    Veteran Member Three Rings Alan's Avatar
    Jan 22 2007
    1998 2.8QM 1988 Corvette
    Pittsburgh, PA
    Turn down the water pressure, a small amount of water wont hurt anything...just lay down towels if you're worried.
    I use a firehose nossle which allows me to adjust pressure also
    Veteran Member Four Rings will175's Avatar
    Apr 25 2007
    Las Vegas..Hawaii..Nor Cal
    Twista has some good advice. For me I would not use a hose. But like alan said the fire hose nozzle would be okay with it turned almost all the way off with just a little spraying out. Or use a waterless car wash if you are very paranoid.
    Train Hard, Go Hard, But always be Humble.
    Oct 27 2005
    '14 Ibis White SQ5
    Los Angeles, CA
    Quote Originally Posted by will175 View Post
    As will stated about a waterless carwash...one i recommend, which isnt really waterless, you just use limited amount of water...Optimum No Rinse-I use this in winter when its freezing out. Everyone praises this stuff...as do it!
    Registered Member Two Rings TSC17's Avatar
    Sep 09 2008
    2007 TL Type S
    Columbus, OH
    Like has been said...clean it thoroughly once, and after that it's just maintenance. I keep a spray bottle of pre-mixed Optimum No Rinse on hand and use this for door jams and in the trunk lid area. I use it on every detail job.
    Todd
    Esoteric Auto Detail
    Perfecting Auto Finishes in Columbus, OH
    Apr 20 2007
    Lander, Wyoming
    Thanks for the advice guys. It sounds like there is no easy way to wash the jams using actual soap and water, and that wiping them down between thorough detailings is the norm.
    As usual, there is no magic secret. Oh well.
    Thanks everyone!
    Jon
    go > show
    Ich liebe mein Audi
    Senior Member Three Rings snowbird's Avatar
    Nov 20 2007
    '04 S4, '11 Q5, '90 Corrado, '96 911 C4S
    Toronto ON
    I wash my jambs every second wash or so. I wring out my wash mitt so it's not flinging soap around while I'm washing. Then I use a dribbling hose to rinse, letting the water trickle over the jambs. I only get water inside if I twitch or something , but I keep a MF towel handy to dab any splashes or drips that might get in.
    May 13 2007
    Northern VA
    I use ONR.
    - Dan
