Results 1 to 9 of 9
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    How do you clean an Oiled Air Filter?
    I have the EVOMS intake and i have no idea how to clean it. It's an oiled filter and was told it can be reused. Anyone have an idea?
    Veteran Member Four Rings AWDTURBO's Avatar
    Oct 28 2008
    '14 Allroad
    Newark, NJ
    Re: How do you clean an Oiled Air Filter?
    i heard our MAF don't go well with oiled filters ??
    Senior Member Three Rings Muck_and_Grind's Avatar
    Jun 09 2008
    2001.5 Audi S4 (on stands), 1989 Grand Wagoneer, 2007 B9 Tribeca
    Lodi
    is it anything like a K&N? if so just go buy their stuff
    Veteran Member Four Rings Jibberific's Avatar
    May 21 2008
    az
    with my K&N panel filter i just took it out and sprayed it really good with my air compressor. it got all the dirt off and the more i sprayed it the more oil came out of it. so i kept going until it was just about dry
    {99.5 Avant}
    Oct 28 2008
    '14 Allroad
    Newark, NJ
    Isn't the EVOMS intake oiled ?
    Nov 15 2007
    yeah it is.. unless you get the dry filter option with a 40 dollar foam sock.
    Oct 28 2008
    '14 Allroad
    Newark, NJ
    is that what you did?
    Veteran Member Four Rings p1nk50ck's Avatar
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    k&n sells a filter recharge kit. you can check amazon or ebay, or do a google search to find the best price. it will come with degreaser to clean, and oil.
    basically, you take your filter off, spray the crap out of the filter with the degreaser, rinse off with water, and let it dry completely. i used a hair dryer to get most of it off, then it got really hot, so i let it sit for about 5 hours to dry. then, lightly oil the outside of the filter. when you have a nice, light even coat, blot dry with a clean towel.
    just make sure you blot out the extra oil. your filter should be lightly oiled, not drenched. the reason is because dirt and small particles will stick to the oil. in turn, the particles stick to the filter, and will assist with filtering the air, making the holes in the filter smaller. but you don't want the filter to be so drenched with oil that it sucks into your intake tube, and get all over your MAF.
    Veteran Member Four Rings vtracer20's Avatar
    Apr 14 2008
    Milton VT
    ^ yea what he said
    also agree with blotting out excess oil, if you dont it will just get sucked down into the intake and all over your maf and could cause problems.
    2007 A4 S-Line / Ti Pkg / Quattro / Bilstein Pss9 / JHM Short shifter / GIAC X+ chip / RS4 rear sway bar / 20% rear tint / 10mm front 15mm rear spacers / Forge DV / DTM CF replica rear lip spoiler / DTH CF roof spoiler / Cupra R front spoiler (not on) / Infinity BasslinkII sub
    looking for: CF front lip / S4 alum mirror hosing
