Results 1 to 12 of 12
    Veteran Member Four Rings Beelzeebub's Avatar
    Oct 08 2008
    B7 S4
    Moisture in tail light
    I've done a search on this but nothing really came up to answer my question. So here goes, it was warm out today after some unseasonally cool weather the past few days. I noticed some moisture in the right tail lamp right by the lens of the reverse light. I have never been involved in any accident in the two months i've owned the car. the tail light has no visible cracks. what could be causing this? the other tail light has no moisture inside. how can i fix this? is this something that i could claim under warranty since its CPO?
    Veteran Member Three Rings Bpitz15's Avatar
    May 07 2008
    Hartford County, CT
    Re: Moisture in tail light
    i took my car to the stealership for the headlamps getting moisture inside and they claim this is "normal" and that if the dealership fixes the issue they will be fined by AOA.
    Now the taillamp is a lesser known issue so I dunno if it is covered. To fix it you would have to create a better seal around the electrical panel that holds the bulbs w/ silicone or a new o-ring ? if there is one?
    Items for sale PM me for details:
    A6/Allroad 4.2 V8 top end
    Oct 08 2008
    B7 S4
    i hope you argued your case with the stealership regarding the moisture in your car's headlamps. Im set to take the car in on tuesday anyway for a check on it's fuel pump (strange rattling sound just before ignition), so i might as well ask if they will do something about the tail lamp moisture. i do know for a fact that if i leave it as it is, over time, rust and corrosion will build up in the metal contacts for the bulbs causing additional problems.
    Veteran Member Four Rings Justincredible's Avatar
    Jul 24 2008
    chicago
    I would pull the tail light out and look at it. The water actually goes in between the tail light and the body when It drains.
    To remove the tail light is easy.
    open the trunk.
    look to where the light and the trunk molding meet up. then look back 3in you will see a circle of carpet. pull the carpet back to expose a phillips screw head. remove the screw and now the tail light YA it is that easy. I was thrown as to how easy removing the tail lights are.
    Any way after you remove the light look to see if there is any area for water to get in. If you see nothing remove the lights and check the wire seals that seal the light bulbs in the housing. Still see nothing remove the lights and take the housing in the house and fill it with water to see if there is a spot where water can weep in.
    Oct 08 2008
    B7 S4
    thanks. i'll check it out tomorrow.
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    Quote Originally Posted by Bpitz15 View Post
    I had both my headlights replaced under warranty due to moisture getting in. It is a common problem with Audi that they just can't seem to fix. I know the headlights are vented from the factory to let some of the condensation out but I don't know if the taillights are.
    Veteran Member Three Rings charliemike's Avatar
    Jul 24 2008
    Virginia
    They get fined for replacing the headlights? Really?
    Maybe if Audi didn't charge $800 for one I'd be willing to go halfsies.
    Veteran Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    Headlight is a known issue and Audi knows about it but it is not covered by any kind of warranty. I've seen a TSB on how to fix it and they specifically state that this is not covered in any way.
    I'm sure they will say the same about the tail lights as well.
    Established Member Two Rings DucatiTorrey's Avatar
    Aug 16 2011
    2004 Subaru Forester XS, 2004 A4 Avant USP
    West Michigan
    sorry super old thread, i know (hey, at least i'm using search!!!) I ahve the exact problem, right light, moisture / condensation in reverse light area.
    im scared.... :-P
    2004 Arctic White A4 Avant USP 6MT
    *WTB: B5 Spring Seats / Perches*
    Veteran Member Four Rings SuperAvant's Avatar
    May 30 2007
    MA
    I have the same problem with my tailights. The Headlights are an easy fix (o-ring replacement) but I cant really figure out where the condensation is dripping into the tailight from.
    2014 R8 V10 - Gated
    2005 S4 Avant 6 Speed - JHM Stuff
    2017 TRDoffroad 4 Runner
    Senior Member Three Rings rjkotler's Avatar
    Jul 09 2010
    2020 Audi S3 (Wife's DD)
    MD, USA
    I also have the tail light moisture problem.
    If you pull the tail light assembly on your Avant you will see a rubber seal that keeps water out. On mine the seal was pulling away from the assembly. I put a bead of silicone down the length of the light where the seal is and it solved the problem. This is on the top edge of the light assembly.
    The light actually has a couple of layers of plastic on the inside and where the rubber seal is 2 of the layers meet. The seal is supposed to protect this area but as they get older the adhesive on the seal fails. Try the silicone route and you will probably be ok.
    2024 RS 6 Avant - Stock car, Modified driver
    Established Member Two Rings Levinoss08's Avatar
    Feb 28 2011
    Cape Cod Massachusetts
    Same problem, drivers side reverse its only the rectangle around the reverse light.
