Originally Posted by
MacDaddy
to the best of my knowledge the 6hp's outside dimensions are the same as the 5hp's. bell housings will depend on the application, but being an audi i bet all the bell housings are the same
RS-MAD
MacDaddy - Well the rumour is the RS6 doesnt use the standard 5HP24 bellhousing, the same people say the V8 5HP24 from the S6 wont bolt up. But I would like to know if this isnt the car I can use the 6HP26 as the A8 2004 4.2 used it and that previously used the 5HP24.
Anywhere you think I can find out?
Not a rumor the W12 and RS6 bell housings are quite different.
The dimensions on the 6hp32 are different as well (the trans is mounted differently).
The 6HP26 is probably your best bet if you must use an auto but you'll have to deal with the electronics differences between the engine ECM and the 6HP26 TCM.
IPT and level 10 all claim that their transmissions will hold up to 700 ft/lbs...
So what kind of project it this? Do tell...
