Results 1 to 11 of 11
    Established Member Two Rings A4donkey's Avatar
    Sep 24 2005
    Anywhere
    Looking for refrigerant recharge DIY
    Anybody done that before?
    How many PSI (low pressure pipe) should it be? between 25-40 psi?
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    Re: Looking for refrigerant recharge DIY
    That sounds about right for the low pressure pipe. I'd need to check the Bentley to make sure though. You do not want to overcharge it, this can cause damage. Make sure you are using the exact same refridgerant, you do not want to mix different types. If different, evac the whole system and refill. You can pick up those refill kits at your local auto parts store but not sure if the refridgerant they use is oem type or not.
    Sep 24 2005
    Anywhere
    any idea of the Audi oem refrigerant for 2005 A4 or any R134a will be fine, I think as long as they are same spec, like dot 4 for brakes.
    Feb 12 2004
    Everywhere
    Any R134a will be fine
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    Quote Originally Posted by CO AVANT View Post
    +1
    I recharged mine while on the road in West Virginia this past summer. Had to do it b/c I was going to pass out from heatstroke. I bought a standard r134a recharge with the integrated nossle/gauge and when I hooked it up, it was just at the bottom of the green on the gauge (no idea what psi that is). I filled until is was about 3/4 the way through the green "recommended" pressure.
    Ice cold AC ever since. I highly recommend it. Total cost =$25 and 10 minutes of work. Thank goodness it worked too, b/c it was 95 degrees and humid and my car had been baking in the sun for 5+ hours when got in... 30 minutes later an Autozone was on the road, and 15 minutes after I stopped we were chilling in like 66 degree low humidity air. Aaaaahhhhhhh....
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Sep 24 2005
    Anywhere
    Just recharged (R134a) from 22 to 34 psi, cool cool air and the funny smells no longer chime in..
    I am a happy man again!!!
    DIY FTW
    Senior Member Three Rings rocketheavy's Avatar
    Mar 21 2008
    A4, Explorer, YZ250
    Connecticut
    anyone have a picture of where the recharge nozzle is?
    03' 1.8T Tiptronic
    Baileys DV, 15% tints
    Ziza yellow Fogs
    Blacked out grills/trim, De Badged
    Apikol snub mount, clear corner mod
    A6 engine mounts
    Sep 24 2005
    Anywhere
    bigger diameter with smaller nozzle is the low side (charge pipe), usually very cool.
    Established Member Two Rings Teratorn's Avatar
    May 30 2008
    Ashburn, VA
    Quote Originally Posted by rocketheavy View Post
    If I remember correctly, it's behind the firewall, passenger side. You have to remove the entire top cover where the battery is. The low side and high side have different fittings, and the recharge kit will only fit the correct side (low side) so it's pretty much fool proof.
    Apr 20 2007
    Lander, Wyoming
    It is indeed the nipple that is aft of the firewall. And yep, the recharge kit only fits on that one, so you can't mess it up if you tried.
    Jon
    go > show
    Ich liebe mein Audi
    Oct 01 2007
    S. Florida
    I found this video on Youtube very useful:
    https://www.youtube.com/watch?v=lWulSsLlBFg
