Results 1 to 10 of 10
    Veteran Member Four Rings audikid66's Avatar
    Jun 13 2007
    Belmar,NJ
    Conical or ball seat lugs?
    ok i am putting the 17" sport wheels on for winter.. im gonna do 15mm spacers in the back and 10mm in the front... what type of lugs do i need to fit? i am also going to be using the 10mm spacers on the rear after winter with my iforged wheels... from what i hear you shouldn't be using the same bolts for both wheels? but i have polished bolts that i bought and i have used them in both my iforged wheels and my oem wheels but they seem to have less threads go in when i an using them on my iforged.. is there a need to use a certain type of bolt for each one or will i be able to use whatever type safely on either? thanks
    Current car: Stage 3+ 2002 Audi allroad 6 speed
    Past cars:
    imola b6 avant 5spd/URS4 avant Big turbo aan/B7 RS4/k04 b5 Avant /BAT B5 Rally car/B6 Ultrasport/TT / multiple B5 A4 /5 speed ford f-150
    Jun 13 2007
    Belmar,NJ
    Re: Conical or ball seat lugs?
    anyone?
    Past cars:
    Veteran Member Four Rings Condo's Avatar
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    You'll need ball seat for stock wheels and most aftermarket wheels use a cone seat. Just make sure you order the correct length bolts for your spacers.
    Veteran Member Three Rings agart's Avatar
    Mar 20 2008
    Belmont MA
    Ball seat. Lugs are 14 x 1.5. As far as length goes the stock lugs are 28mm long. You wanna add on the length of the spacer to get the length that you would need. You always want minimum of 4 threads going in when you tighten them. So chances are that adding the 10mm in the rear after would make it so that you need new lugs. I just went through this process this week as I did a B5 S4 brake upgrade and needed spacers to fit them behind my USP wheels. Typically aftermarket wheels are conical seat. If you use ball seat lugs on conical seat wheels you will see that the lug does not make contact on the whole portion that it is supposed to. I made this mistake and was running ball seat lugs when I should have been running conical seat. I ran into no complications but when I found out I changed them for peace of mind. I'm assuming that if they care enough to carry both lugs that it is probably a good idea to buy the correct lugs. Also make sure to tighten your wheels in the air when you do so. This will help reduce vibrations caused from spacers.
    DG '02 A4 1.8TQM
    My Build Thread
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Should that be the other way around? Most people that get the stud kits for stock wheels order the conical, while most that have after market get the ball seat. My OZ SL's use ball seat.
    OP, just test the lug bolts you have now to see they sit in the wheels correctly.
    Conical on the left and ball seat on the right.
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Nope. Stock wheels use ball seat as well as some aftermarket wheels. Most aftermarket wheels use conical seat bolts. If people are ordering conical stud kits for stock wheels, they're ordering the wrong kits.
    Check out the ball seat section on ECS.
    Jul 07 2004
    socal
    Must be a B5 vs B6 thing.
    Jun 13 2007
    Belmar,NJ
    ok thanks guys...so for my stock wheels i will need ball seat...iforged cone seat
    Past cars:
    Registered Member Three Rings ILikeBigBrakes's Avatar
    Sep 27 2008
    2002 Audi A4 1.8 Q&A
    Orlando, FL
    Glad I came across this and apologize to thread jack but quickly should I be using OEM lug nuts on my VMR 708s? I was using the latter on my Axis MODS.
    Veteran Member Four Rings aaronz's Avatar
    Jun 10 2008
    Spiders
    Chicago And NJ
    Quote Originally Posted by agart View Post
    Something is not right then if they don't fit behind your wheels. I have the Stock 17's and just did the upgrade yesterday. Unless your mistaken, or I am missing some details there is no need for spacers.
    2016 TTS Launch Edition
    SOLD!!! 2013 S4 DSG Build Thread
    VAG-COM equipped if you need help
