Results 1 to 6 of 6
    Senior Member Three Rings TverRus69's Avatar
    Sep 02 2008
    98.5 2.8 A4 QM
    NYC, Penn State, Tver Russia
    Codes... Throttle Valve Controller Malfunction
    Finally got the alpha-bid VAG-COM to work on a friends laptop and got a code for Throttle Valve Controller Malfunction:
    1 Fault Found:
    17953 - Throttle Valve Controller: Malfunction
    P1545 - 35-00 - -
    Readiness: 0110 1101
    Its pretty dark already so i didn't want to start taking things apart. In general what am i looking at and for? Is the problem electrical or to i just need to do some TBA? General symptoms are rough idle, stalling on start up unless i press the gas, stuttering around 2k rpm. Also is it something that can be fixed or am i going to wind u throwing 300 bucks for a throttle body? What could cause this?
    I tried searching for it but most threads in different forums seem to go the "replace it and forget about it" way which is certainly not my first option. TIA
    Feb 27 2005
    North Wales, PA
    Re: Codes... Throttle Valve Controller Malfunction
    sounds like a bad throttle body. Try a TBA first with vag-com. My buddy is parting out his a4 so i'm sure he'll part with a throttle body for cheap if you need it.
    Sep 02 2008
    98.5 2.8 A4 QM
    sorry bout the post flooding but is this valve controller directly on the TB or something separate?
    Sep 02 2008
    98.5 2.8 A4 QM
    anybody??
    Veteran Member Three Rings drunknmunky408's Avatar
    Sep 26 2006
    2001 A4 1.8T FWD - SOLD
    San Jose, CA
    my bro replaced his MAF
    2001.5 Nogaro Blue S4 6spMT l Sports Package l Blue Alcantara Seats l APR Chip l Neuspeed Exhaust l Eclipse AVN6620 l AWE Boost Guage l AWE Pedals l NRG 230g Shift Knob l
    TEAM|AXION
    Sep 02 2008
    98.5 2.8 A4 QM
    already did that. didnt help.
