Originally Posted by
bass_lover1
Any particular reason why?
I ask because I refuse to use Mobil 1, as it's the only oil in my 60k miles of ownership that my motor has burned a noticeable amount off. By noticeable I mean about 1.5-2 quarts. I've had zero issues with Castrol, particularly the 0w30 variety.
I don't like the detergents Castrol uses. Some may not believe me, but oil has different detergents based on the area it's shipped to, or at least some companies do this. Castrol is one of them. The midwest and specifically shops in this area have had issues with customers that live in the South over winter and this are in the summer. Sludge, oil breakdown and poor performance was the result. Besides the lifestyle of the "old people" the one thing they found in common was the Castrol oil.
Oil has given ratings based on lubricity, "weight"/viscosity, and API standards. Outside of those parameters the company can choose to put in additives or not.
Have you ever pulled off an oil cap to find some caramel, beige, or yellow substance all over the bottom of it? That's the additives in your oil, they separate from the oil a lot of times from short trips and incomplete heat cycles.
I use Mobil 1 for a couple of reasons. #1 it's readily accessible #2 I have been happy with their products in everything I've owned #3 I know a handful of race teams that only use their products and are 100% happy with them #4 I haven't had any issues with my vehicles to raise any concern of what oil I have been putting in them.
Example, My truck. I changed the oil every 3000 miles. I use Mobil 1 oil and a WIX filter. After the 4th oil change(using M1) I checked my oil level 2800 miles into that oil change. The oil was still as clean as new.
Current example. My 1.8T. In the last 2 months we've had a couple customers come in with 105-120K 1.8T A4's similar to mine (except without performance mods) with oil pressure issues. These cars couldn't hold 15psi of oil pressure at idle, and had records of their oil changes every 3-4K. I have >177K on all stock internals. I purchased the car with 154K on it and have been running nothing but M1 0W-40 since then. I installed an oil pressure gauge to keep an eye on it, but I maintain 100% oil press specs. I've tried a couple different filters and so far my top 3 fav filters are the M1, Mann and WIX.
