Results 1 to 17 of 17
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    Where is the interior (cabin) air temperature sensor?
    My heater is driving me insane. I has two settings:
    Lo - blows ambient outside temp air into the car
    64 and higher - hot as the sun, regardless of fan speed
    I've been reading about this in the archives this morning and I know its a somewhat common problem. Im going to try swapping out the climate control unit to see if it helps. I'd like to change the interior air temp sensor as well, but am unsure where its located. Is in in the CC module behind the little slits? Or by the sunroof switches?
    Anybody know? I cant go on driving with the windows cracked b/c my car can only blow the hottest of hot air when it's set to 64 degrees. This must be fixed!
    Thanks for any help or suggestions!
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Veteran Member Three Rings passatkid's Avatar
    Sep 19 2006
    ND
    Re: Where is the interior (cabin) air temperature sensor?
    I thought it was in the head unit itself, I could be wrong though.
    Veteran Member Four Rings BNZ TOY's Avatar
    Oct 29 2006
    1G FX35, 03 R6, B6 A4 MT6
    Vancouver
    That sounds unbearable, sorry to hear.
    The climate control unit sounds $$$. Maybe it's worth it to just have the dealer diagnose it for you first before you go buy a climate control unit
    Another silver B6
    Go/Stop: K04-015 ~ Intake/TIP ~ Forge Splitter ~ Neuspeed turboback ~ B&M SS ~ H&R Sport w Bilsteins ~ S4 Sways ~ Eurocode FMIC ~ 245 Rotors/18z ~ FX300 240mm LWFW ~ Snow Meth Inj ~ EURODYNE tune
    Flair: USP Front ~ Cupra R ~ S4 Trunklip ~ Euro Roof Lip ~ VMR v710 235/19/35 ~ S4 doorblades ~ B7 rear valance ~ LED fogs ~ B7 DTM skirts ~ Euro RS4 Steering Wheel ~ S4 Recaros
    Sep 19 2006
    ND
    OP I have a good unit that it scuffed that you could test with, just pay shipping.
    Apr 20 2007
    Lander, Wyoming
    Quote Originally Posted by passatkid View Post
    Thanks for the offer but I know a number of local people with B6's so Im sure I'll find someone who's willing to lend me their CC unit. I just need to buy some radio keys first.
    Jon
    go > show
    Ich liebe mein Audi
    Veteran Member Four Rings aaronz's Avatar
    Jun 10 2008
    Spiders
    Chicago And NJ
    IIRC it is located near or around the cabin air intake. Does your temperature readout normal? IF its 80 outside does it read 80?
    2016 TTS Launch Edition
    SOLD!!! 2013 S4 DSG Build Thread
    VAG-COM equipped if you need help
    Apr 20 2007
    Lander, Wyoming
    Quote Originally Posted by aaronz View Post
    By the cabin air intake? Do you mean the cabin filter? That doenst make any sense. There must be one somewhere inside the cabin in the console or headliner somewhere to measure the temp being felt by the occupants.
    Yes my outside ambient temperature sensor works perfectly.
    Jon
    go > show
    Ich liebe mein Audi
    Aug 26 2005
    As mentioned already, it's inside the control head unit. Air is pulled into the sensor by a little fan, at the small grill area near the bottom edge of the face plate.
    Apr 20 2007
    Lander, Wyoming
    Are you referring to the three horizontal slots just above the fan speed screen?
    I just want to be sure I'm on the same page, as you said it's on the bottom but these are on the top of the unit. Thanks for the help! It sounds like swapping the CC unit will test both the unit and the sensor at once.
    Jon
    go > show
    Ich liebe mein Audi
    Aug 26 2005
    Yes, that is correct, I don't know why I was thinking it was elsewhare.
    Aug 26 2005
    Quote Originally Posted by lookaught View Post
    You can also try resetting the A/C adaptations by running basic setting in block 001. Wait for the displayed servo positions to all be zero. then close the controller and turn off the key for awhile, then reevaluate the problem. You have checked for DTCs right?
    Apr 20 2007
    Lander, Wyoming
    I havent run the VAG on my car recently but now that that I have thought about it there were some HVAC codes from April. I saved them in an email:
    00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
    30-10 - Open or Short to Plus - Intermittent
    01592 - Air Quality Sensor (G238)
    30-00 - Open or Short to Plus
    I'll rescan tomorrow. Thanks for the help.
    Jon
    go > show
    Ich liebe mein Audi
    Aug 26 2005
    Run basic settings too, it may help, and possibly avoid replacing the controller. BTW, the air quality sensor is different from the temp sensor FYI. (deleted on '03s up. )
    Oct 29 2005
    10speed
    San Francisco, CA
    dude my air quality sensor has been going off forever lol
    - Clint
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Try wearing a new t-shirt when you work on cars
    -Doug
    Veteran Member Three Rings A4twin's Avatar
    Jun 02 2007
    2016 SQ5 2021 VW Tiguan
    Pasadena, Tx
    i have the same problem when i vag-com it i get:
    01274 - Air Flow Flap Positioning Motor (V71)
    41-10 - Blocked or No Voltage - Intermittent
    i was going to change this sensor out (#14 on the link below) but 100 bucks
    http://www.trademotion.com/partlocat...layCatalogid=0
    2016 SQ5 APR OBD11
    Apr 20 2007
    Lander, Wyoming
    Update:
    So this was happening intermittently but wasn't horrible enough to really put energy into fixing the problem....
    My coolant temperature sensor failed and I kept getting a CEL... once I replaced this, my heat has been functioning SUPERBLY. It's quite amazing, I have temperature modulation.
    I have no idea why this happened, perhaps its just coincidence, but before I forget I wanted to post it for the archives. The temp sensor was ~$26 and took about 20 minutes to replace, it's on the rear coolant flange.
    Jon
    go > show
    Ich liebe mein Audi
