Results 1 to 20 of 20
    Jul 03 2007
    2017 Highlander Hybrid
    Question Headlights cause hum with aftermarket head unit
    Okay, so here's a strange one. I just installed a Kenwood DDX5120 head unit in my '06 A4, and I'm getting a hum whenever the parking lights or headlights are on. No hum when the lights are off.
    The deck is wired to the factory harness (Bose amp, etc) using the metra adapters. Do I need to run a new ground wire? Add some kind of filter on the 12v DC input to the deck?
    This is strange, since I installed the exact same deck in my wife's B6 avant a few months ago, and she doesn't have this problem. She doesn't have Bose, tho...
    Anyone seen (well, heard...) this before? Thanks!
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Re: Headlights cause hum with aftermarket head unit
    sounds like you aren't properly grounded... check your ground wire and make sure it is connected to a good strong ground (usually a screw you can find inside). Is there a ground cable included with your unit?
    Jul 03 2007
    Yeah, I just used the factory ground from the wire harness -- I didn't run another ground wire to a bolt or anything. I'll give that a shot. Just strange that it only happens when the parking lights are on...
    DUH! an Audi
    los angeles, CA
    who hooked it up? Could be ground or when you tapped into a wire for the light on the unit its creating a problem.
    Veteran Member Four Rings airbornerifleman's Avatar
    May 20 2008
    2013 Passat TDI
    Toronto Ontario, Canada
    I get the same hum when I turn my lights on, but I only hooked an amp and a couple of subs to the stock Symphony 2 head unit. I got it all done professionally.
    2006 Audi 2.0T quattro Tiptronic
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
    Established Member Two Rings Asimko's Avatar
    Apr 26 2008
    If you hooked up the orange illumination wire just disconnect it and cap it off. That wire is not needed for the deck too work. If that does not work try running your own ground. Also make sure all the wires are seated in the harness properly.
    Sep 02 2008
    Boston, MA, USA
    Just installed my Pioneer and im getting the same hum. very frustrating. I didnt have any problems like this with the pioneer in my jetta. I haven't tried disconnecting the illum wire yet, but that wont really solve the problem as that is pretty much needed on a nav unit (to dim the screen and switch the map to night colors). I also used the ground from the factory harness.
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    its called a ground loop and a new ground wire usually does the trick with some added shielding of course
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Jul 03 2007
    Quote Originally Posted by yettavr6 View Post
    Does your deck actually dim when you turn on the lights? One of the things I noticed is that the Kenwood nav unit doesn't actually dim with the lights, even though I connected the orange dimming wire through the harness. Do the B7 cars even send dimming voltage, or is it all CAN-bus these days?
    Sep 02 2008
    Boston, MA, USA
    Yes, it dims, and im convinced there is no fix for this. I've tried grounding the chasis of the HU (using the bolt on the back), grounding the RCA's, and disconnected the illumination wire. Nothing helped, and in fact grounding the RCA's made it louder. It amazes me that the factory headunit would have better noise isolation then a "high-end" aftermarket headunit. Leave it to Audi...
    Sep 02 2008
    Boston, MA, USA
    Just curious who else that is having this problem has Bose? I think it may be something to do with the amp itself. I used this harness to connect the Bose amp to the low level outputs on the Pioneer. If i unplug all 4 RCAs from HU, the noise goes away, but if i unplug only 2 (or 1 or 3) then the noise is even louder than with all 4 connected.
    Mar 03 2008
    2005.5 B7 A4 2.0TQ 6MT
    Washington
    Here you go.
    Quote Originally Posted by Car Audio Guide
    Troubleshooting Noise
    Noise is a very common problem that plages a lot of people and can be a real pain to troubleshoot. Typically noise only happens with systems with an amplifier. If you have noise and no amp, your head unit is at fault and you shold reground it.
    Steps to solving noise:
    1) Set boost to 0 and your gains using this guide here
    2) unplug the rcas from the amplifier.
    - if noise doesn't stop, reground the amplifier
    - if noise doesn't stop, unplug speaker wires one at a time (leave power wires), the wire with a short will will stop the noise when you unplug it
    3) If noise stops:
    - replace the rcas
    - if noise doesn't stop, reground the head unit
    - if noise doesn't stop, ground the rcas (strip about three inches of wire and wrap it around the outside metal of the rca connectors, then run to the screw on the back of the head unit
    - if noise doesn't stop, replace the head unit
    Pionneer units are KNOWN for having the ground trace blow out, which requires you to ground the rcas. Having the nub in the middle of the rcas short out will also blow the ground trace either completely killing the rcas, or blowing the ground trace.
    Still have noise and the steps don't work? Try this:
    take a piece of wire (most wire comes in pairs - handy). Strip about three inches from each wire at one end. Wrap the wire around the outer metal part of the rcas at the head unit end - this part is called the barrel or jacket. Next, tape the wire in place. Finally, connect the other end of the wire to a good solid ground. One of the screws on the back of the head unit works nicely, as well as the same place you grounded the head unit.
    You should never use a ground loop isolator. If you have noise, you have a problem and should address it accordingly.
    2005.5 A4 2.0TQ 6MT
    Black on Black
    Loaded
    "Brown Chicken Brown Cow"
    Mods = 0
    Sep 02 2008
    Boston, MA, USA
    Yea i've tried all those steps already, so really my only option left is a ground loop isolator for the RCA's. I'm gonna order two in a few minutes.
    Mar 03 2008
    Washington
    Bummer.
    It's probably being induced by the Bose amp then. Have you checked all the OEM grounds to make sure that they're still good and nothing has corroded?
    2005.5 A4 2.0TQ 6MT
    Black on Black
    Loaded
    Mods = 0
    Veteran Member Four Rings Geoffafa's Avatar
    Aug 31 2007
    The Big Blue Bitch and her mess
    Miami
    it happens to me too, ijust turn up the music, kinda the reason i got the unit in the first place.... to play music louder and clearer then the OEM headunit
    F.T.W.L.T.B.D.W.I.C.T.W.
    IG | @fukn_fafa
    So air is like the hot girl that is no fun in the sack, and good coils is the cute girl that is crazy in the sack. -chrislane
    Sep 02 2008
    Boston, MA, USA
    Today i tried two different things:
    ipod connected to the Bose amp: no hum
    preouts on HU connected to a set of PC speakers: no hum, even with speaker volume on max
    I'm going to try using THIS instead of the preouts on the pioneer.
    One reviewer said this which makes me think it will solve the problem:
    Problem: Getting aftermarket head units to play nicely with 98' E320 stock Bose amplifier. Line out from aftermarket HU to Bose amp and you get a nasty thump when source is changed or volume turned to zero. I thought it was a flaw in the Alpine receiver. On to a new Pioneer DEH-P5000UB for bluetooth purposes (awesome!). I found the same problems. Also tried speaker out to factory amp but that option came with other issues like 'one click, too loud' and hissing on soft tracks. The Scosche SLC4 knocked these problems square out. Easy to connect. Adjustments were puzzeling. I just set all channels equal at half mark and set the mode switch to what sounded best. It delivered what Bose was looking for. 5 clicks into the volume and the sound increases nicely and has a solid full range as I continue to increase the knob. No clicks, pops or hissing!
    Sep 02 2008
    Boston, MA, USA
    Just wanted to update you guys. I bought that line level converter and installed it yesterday.... no more hum! Sounds better overall too.
    Jul 03 2007
    Thanks to yettavr6 above, I installed the Scosche SLC4 this weekend as well, worked great. The headlight hum is nearly gone. I used the RCA outputs to feed the signal to the bose amp. I also had to use an adhesive cable tie mount and a couple zip ties to firmly attach the line-level inputs to the Scosche. As some reviewers have mentioned, the Scosche line-level input screw terminals don't hold the wires very well.
    Active Member Two Rings Dimon's Avatar
    Dec 21 2011
    04 A4 1.8T USP 6MT
    State College PA
    Ohh yeah I found what i need!!
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    humming? strange, just buy my headlights in the classifieds section :)
