Results 1 to 21 of 21
    Veteran Member Four Rings manhertm's Avatar
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Where are the fuses in the engine bay located?(pics)
    OK, so my weekend has started out in the shitter. I'm on my way to do my Reserve duty and my cars starts smoking, UNDER THE DASH! It smelled like an electrical fire, so I pulled over with the quickness. I already knew where the problem was coming from, the previous owner rigged some make shift kill switch that cut all the power when flipped. The only problem is it would always short out, about a 6 months ago ,I took out the switch and connected the wires directly. I'm not electrician by far and it worked so, I left it alone, I figured as long as the car was running) About a week ago, I started smelling a weird scent, I thought it was coming from my cabin filter, since I haven't changed it since I owned the car, but it was those wires, I spliced. To sum it up, I think the wires were being overloaded and they got hot and shorted out something. I don't know what fuse it shorted out, but by looking at the size of the wire, I'm guessing it's not located on the side panel. Now back to the title, where are those engine fuses located? Thanks I'm gonna go take some pics so you guys can see what I'm talking about.
    By manhertm, shot with Canon PowerShot SD550 at 2008-10-18
    The yellow wires were used with the previous toggle switch,one wire leads to the port that is circled in blue. The red wire circled is what was orginally connected to the blue port. When I first pulled over I cut ends of the yellow wires and twisted them together temporarily until I could get off of work later. It worked but I accidently touched the metal part of the steering rack and thats how it shorted out something.
    ThetaAlphaThetaMember#1
    MY CAR IS ON AN EBAY BUDGET!! DEUTSCH REIS!
    Veteran Member Four Rings T0M3K's Avatar
    Sep 14 2007
    Valley Stream, NY
    Re: Where are the fuses in the engine bay located?(pics to come)
    Electrical components on German cars is one of the few things I don't want to mess with. Tracing wires usually helps, but I don't think it is even possible in our cars without comprehensive schematic.
    Veteran Member Four Rings michgo's Avatar
    Oct 21 2007
    Wagon/Variant/Avant A4 B6
    Re: Where are the fuses in the engine bay located?(pics)
    Were the yellow ones for the killswitch? If so just completely remove them.
    The wire circled in red goes back on the middle bolt circled in green. It will spark and probably reset a few things in your car (Date/Time, Radio nothing major).
    Basically replace red wire with yellow wire and just get rid of yellow wire.
    I just messed around with the same area recently wiring up my airbag controllers. Let me know how this goes!
    I heart wagons.
    'It's actually a pretty big pet peeve of mine when people mess around with my photos', MmmBoost
    shave it mold it sand it paint it
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Quote Originally Posted by T0M3K View Post
    Well, whatever fuse that wire leads too is directly linked to the battery. If it wasn't connected the car had no power at all. The original red wire looks like it is OEM( and I'm hoping the cluster of red wires connected to that port is too) I just need to take a look at those engine bay fuses to see if anyone of them are blown.
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Quote Originally Posted by michgo View Post
    Yeah they were connected to the switch, but I think I blew a fuse anyway because when I would connect those yellow wires the power would come back immdiately. Now they are connected ,but there is no power. I'm gonna connect the original red wire anyway, but I don't think it will work.
    Oct 21 2007
    Yes, that is your direct distributor block for battery power so it saves the hassle of wiring through the firewall
    The red one is the OEM one and needs to go on that middle bolt.
    Your fuse box is located to the left of your steering wheel and light switch. Basically open the drivers door and there will be a little plastic panel you can remove with your key.
    I heart wagons.
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    ugh.. is that bare wire? what the hell haha. rip their kill switch out
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
    Jul 09 2007
    01 A6 4.2 QUATTRO
    Portland, OR
    uhm i need some more pictures here, i cant tell if that grouping of wires at the bottom screw in that pic are all screwed into that screw, or bare and twisted together, if they are just bare and twisted together you need to solder and shrink wrap them badly man, and that yellow wire jus looks like you can unbolt it and toss it away and then bolt that red wire back up to the fuse panel where the yellow wire is bolted right now, and for future refrence never just twist wires together and leave them bare in cars, ive seen it all done wrong and it always results in something not working right, the best way to do it by far is solder the wires then shrink wrap them, that ensures the connection is solid and continuity is intact.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Those fuses will be on the drivers side just in frt. of the windshield under the ECU cover.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Quote Originally Posted by brewmastr View Post
    The twist yellow wires were supposed to be temporary until I could get home and take a closer look, that bundle of red wire, beats the hell outta me, I'm not even sure they are oem.
    I tossed the yellow wire and hooked everything back the way it originally was ,but my car still has no power. I got the ECU cover off and checked the 2 fuses , but they looked fine for the most part, they work not blown. I can't really tell if they are still good though. I took some pics of the fuses under the dash and around the ECU, can you guys tell if I need to change them? The orange fuse is the one under the ECU cover and other two are one pictured under the dash. Orange fuse is more brown than usual around the connectors and other two connectors under the dash has that white corrosive stuff you find on battery terminals.
    By manhertm, shot with iPhone at 2008-10-18
    If anybody has access to wiring diargrams under the dash, that would be a big help. I'm pretty sure it has to be a fuse because everything is connected back the way it should be. Maybe I'm not seeing a fuse that could be blown. I gotta try to tackle this before, I take it to my mechanic, I know diagnosing electrical problems can get expensive real quick.
    Mar 21 2006
    Lakeland, FL.
    They look good, does anything work?
    I'm back bitches!
    Aug 26 2005
    There is a master fuse at the battery. I think it is a strip fuse.
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Quote Originally Posted by dirtybrd View Post
    That's the problem nothing has power, it just like I disconnected the battery. I have no clue why the car has not power, like I said earlier, I twisted the wires together temporarily until I could get home, but as I tried to push them back under the dash, I touched the metal part of the steering rack and sparks flew. It was fine until I did that, so that's why I think it's a fuse that's causing the problem.
    Mar 21 2006
    Lakeland, FL.
    I think you're right. It's in a plastic housing. I think you have to replace the battery term. if it blows.
    I'm back bitches!
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Where is that located? Wait, would that be on the battery?
    Mar 21 2006
    Lakeland, FL.
    Look at the positive battery terminal.
    I'm back bitches!
    Jan 21 2007
    "Old Yella"
    san antonio tx
    What exactly would I need to change here?
    Mar 21 2006
    Lakeland, FL.
    Ding, ding, ding. You can get that at a VW dealer, I doubt a parts store will have it.
    I'm back bitches!
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Well, I hit up the Audi dealer on Monday and see if that works, thanks dirtybrd.
    Aug 26 2005
    Replace the blown strip fuse circled.
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Wow, you are the diagnosticator!
