Results 1 to 25 of 25
    Registered Member Two Rings
    Apr 27 2008
    lorton
    Possible to achieve low 5 (seconds) 0-60 time?
    on a b7 tiptronic quattro?
    What type of mods would be needed?
    Apr 14 2007
    Philadelphia
    Re: Possible to achieve low 5 (seconds) 0-60 time?
    You should search first....
    From what you posted this is the person you want to talk to, and the mods needed, this is to start you of.....
    http://www.audizine.com/forum/showth...hlight=results
    USP CLUB MEMBER #87
    .......If life passes you by... DOWNSHIFT!!!
    "thus how i thrived in my natural habitat of rural wisconsin. but now that i live in milwaukee with all these chicago whooores, i had to develop this thing called "game". I miss the days when lifing bails of hay got you a bj" SO NAUDI
    Apr 27 2008
    lorton
    Quote Originally Posted by s4raf88 View Post
    I have already searched, and that's one of the first threads I looked at. I remember in another thread, he said he hit just under 5 seconds (rs4 territory). I just don't see how that's possible with the setup he has.
    Jan 10 2007
    VA
    ^ its not. see post #64 of that thread. he admits that his best time was a 14.429, not the 13.8xx he originally claimed.
    BTW S4s run ~13.5 and RS4s and break 13 flat.
    so to answer the question, to get a B7 0-60 in the low 5 second range, you'll need a turbo upgrade and full supporting mods.
    Apr 27 2008
    lorton
    Quote Originally Posted by b6onboost View Post
    I'm not referring to that thread.
    Look at the #1 post here - http://www.audizine.com/forum/showthread.php?t=221718
    Jan 10 2007
    VA
    I mean, yeah that's the claim. However if his car ran well at the track and only put down a 14.4xx then there is no way it does 0-60 in ~5 seconds.
    Normally cars that hit 60 in ~5 seconds post low 13.xx 1/4 mile times.
    So to hit those times you'll need a turbo upgrade, a GTRS, 28RS, 2876r, ect. I don't think a K04 would cut it.
    Quote Originally Posted by briboy9989 View Post
    Jan 01 2008
    Long Island NY
    A K04 puts down 340HP APR Claim, 340tq. The A4 is lighter, and the same HP and more torque than an S4 so less than 5 seconds is very possible on a A4. My 4.9 was on a very hard launch. My 60' time is 1.919 and could get better so that shows you how my acceleration is down low.
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    It is possible, but not without some work. ^look at Auditude2.0T
    But for most consistent results, go aftermarket turbo kit.
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Veteran Member Three Rings Kevin2772's Avatar
    Apr 17 2008
    Cincinnati
    You sure its completely necessary for a full turbo kit upgrade. According to APR the 93 tune chip makes 292lb-ft of torque. Since torque will launch you off the line, thats more more torque then my E46 M3 was making. That should get you pretty good acceleration increases in itself. Problem is as you get to the higher RPMS, the lack of hp from that kit will make you feel a substantial drop off after 5500 rpms. Not trying to prove anyone wrong, I just feel that a low 5 seconds shouldnt be THAT hard to attain.
    03 BMW M3 Convertible
    13 A4 2.0T 6MT Premium Plus (Gone)
    08 A4 2.0T 6MT S-Line Ti.Pkg / APR 93oct. Tune / Forge DV (gone)
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Quote Originally Posted by Kevin2772 View Post
    don't forget that is torque at the flywheel... you are comparing apples to oranges and the bottom line is what kind of power goes to the wheels... nevertheless you are again comparing a quattro versus RWD in which case the AWD will have susbstantial drivetrain loss. I suggest you read all threads on this stuff... you will learn so much from AZ... you just gotta go back and read it all.
    and by the way... we have been hearing stories from way back in the day so we are positive to what we say. Learn from the mistakes and make your car better.. Go BT if you want a 5 second car.
    Apr 17 2008
    Cincinnati
    Quote Originally Posted by Sanjman View Post
    No i understand all of that, just asking a question. To be perfectly honest, it makes zero sense to me to dump the amount of money into these cars just to make it a 5 second car. A 5 second car is anything but fast in todays standards. To dump an additional 10G's into a car and have it be not as fast as many cars in its class just seems worthless. Audi's are anything but a reliable car and all these aftermarket parts I cant imagine make them any more reliable. I chipped mine because the car is slow as shit without it. The chip makes it bearable. I just got tired of having to white knuckle it home anytime there was a heavy rain or snow.
    Veteran Member Four Rings Ewok_Fetus's Avatar
    Mar 04 2007
    nothing
    nowhere
    Or you could buy a Charger/Magnum/300C with a Hemi and get mid to high 4's on about 1/4 the price of modding...
    ΜΟΛΩΝ ΛΑΒΕ
    Apr 17 2008
    Cincinnati
    Quote Originally Posted by Ewok_Fetus View Post
    Exactly my point...although not really my choice of cars. My thought would have been a new or used 335I without the mods is already there and the same price. Xi if you want the AWD. Then of course there are the EVO's, the STI's and all the other rice rockets that will smoke you at half the cost and NO mods whatsoever.
    Aug 29 2008
    Excelsior, MN
    http://www.mjbmotorsport.com/sitebui...medatabase.htm
    definitely possible, but most of the low 14/ high 13 runs were with a 6MT, and if you can't drive worth a crap you won't even be able to get an RS4 into the low 5s. Trying to measure any car's capability without an expert driver is a little silly IMO, so just because Auditude didn't get there with all his mods doesn't mean it's not possible -- no offense to Auditude, your car rocks! :)
    Veteran Member Four Rings kooltechie's Avatar
    Sep 04 2007
    '13 S5, '18 540i, '21 ID.4
    Pasadena, CA
    Quote Originally Posted by Auditude2.0T View Post
    hey, Pete.
    I think it's time you let go of the claim that your A4 runs 4.9 sec 0-60.
    just as you did not make it under 14 sec 1/4 miles with all the mods you've got, your car doesn't seem to have the kind of capability to achieve 4.9 sec 0-60.
    how many cars do you know that runs 4.9 sec 0-60 and mid 14's for 1/4 miles?
    I'm not trying to start an argument here, but I think it's about time to have a reality check.
    2013 S5 Glacier White | Black Alcantara | DSG | Sport Diff | MMI Nav + | B&O | Carbon | Advanced Key | 19" Ti Peeler
    APR ECU/TCU | PSS10 | AWE Touring | EC Alu Kreuz/Sways/End Links | SPC MS Edition UCA | VMR V810 Gunmetal 19x9.5 (et25) | Michelin PSS 265/35 | Xpel Ultimate | 3M Crystalline
    Mar 04 2007
    nothing
    nowhere
    Quote Originally Posted by kooltechie View Post
    hey, Pete.
    Just want to know how he measured it exactly... G-tech FTL...
    ΜΟΛΩΝ ΛΑΒΕ
    Veteran Member Three Rings extremesport3's Avatar
    Apr 14 2008
    '11 Jeep Wrangler Unlimited, '90 BMW 325i
    Oceanside, New York
    well if i may interject here. Pete may be off slightly however i do not think he is far off. I would venture to guess my car is about 5-5.2 0-60. granted i have alittle more power i would say a maxed out k03 can run to 60 in the 5.2-5.5 range. the stock car according to car and driver runs a 6.5 0-60 time so i would think with all the mods a second would be very attainable. The transmission issue i am not sure about because i have not driven a tip car with mods. Can someone else do a test of there 60 times? that way we have something to compare it to? I will try out mine as soon as i get a minute.
    JD
    BMW M3 ZCP
    2005 - TiAg/Cinn - 6spd
    CSL Headers, Euro Cats, Recaro Pole Position, Schroth Quickfit 4 Pt, Autosolutions SSK 42%, BMW M Sport 4:10 rear diff, Rogue Rear Lower Control Arms, AST D/A4200's w/ 550f/650r, Vorslag Camber Plates ,H&R Front Sway (30mm), Stop Tech ST40 (fronts) , PFC06 Pads(f) PFC01 (r) , TR Motorsport 18x9.5 w/ Direzzas (265/35) (track setup), Vorsteiner Carbon Fiber Trunk, ACS RW diffuser, ZHP shift, VCSL Diffuser
    Nov 16 2006
    Skokie, IL
    so why are you on this forum and why are you reading the thread related to a faster car... shouldn't you be hanging out in the chatterbox or reading upon what you can do in case anything breaks?
    overall... it's called a hobby for some and it's called a profession to others... modifying cars, making them go faster, letting all the potential out that a car can be makes a man feel good.
    I think pete's car being automatic is a limitation... but I think he can hit his 4.9 at some point.
    Aug 08 2008
    2017 Q5
    Houston, TX
    true. its all in good fun. I am very interested in performing mods once i can afford it a little more. I just moved to another state and have to find a place to stay and everything. I have decided to chip asap though. GIAC ftw. word.
    Jul 20 2008
    Chicago
    Fastest way to get a great 0-60 is to install a lower (numerically higher) set of gears in both differentials and ensure your Tiptronic transmission is programmed for the fastest possible shifts. This will, of course, lower your highway fuel economy and provide some additional wear & tear on the engine over time, but you will get sub-5sec 0-60 times if that is your end-all goal...and it won't cost a fortune.
    Nov 16 2006
    Skokie, IL
    Quote Originally Posted by Bmeister View Post
    thanks for stating the obvious... i don't think he is just going for achieving 0-60... especially since 0-60 doesn't even come close to hitting all your gears... but he has his goals set, so let him be.
    Jul 20 2008
    Chicago
    It was so obvious, nobody else mentioned it. Thank you for sharing your intellect.
    Mar 05 2007
    2012 BMW 135i M Sport, 2008 Jeep Liberty
    San Antonio, Tx
    Also, the talk of K04 in these threads can be confusing and misleading. The "K04" that people like Auditude2.0T talk about isn't really a K04 at all. It's a Garrett Turbo setup in R&D by APR currently. They have it available for the transverse (VW GTI, Audi A3) 2.0T engine right now and 340 HP is the crank dyno on that. Fast as shit in those cars because they are FWD and don't have near the drive train loss of a Quattro A4.
    The k04 most commonly referred to in this particular forum was the stock turbo from a S3 that's slightly bigger than the stock K03 turbo on the 2.0T engine. That particular turbo was never fully tuned for the longitudinal mount engine in the A4 and thus, doesn't put down $5000 worth of HP gains.
    Papachristou: i just said "yeah well you are still driving a neon, and she still wants to ride in my car"
    Registered Member Two Rings tech_frog's Avatar
    Jun 09 2008
    Fort Worth
    Not worth it.
    I just came out of a C55 into the A4 (by choice). No way you are going to get an A4 close to a 5 second car without adding $10K. Not worth it. Go buy a used C55 or S4.
    C55 was a BLAST!
    Hey yall, watch this.......
    The Stable
    08 A4 2.0 Dolphin Q-Tip + APR
    08 Wexus RX-350 (Wife's)
    04 WJ Jeep GC Overland (doesn't use much gas while sitting in the garage)
    06 C55 (Gone, but was a blast!)
    04 A4 3.0 Ultrasport (Gone)
    Veteran Member Four Rings Cargo8's Avatar
    Dec 06 2006
    Get an S4
