Results 1 to 9 of 9
    Registered Member Two Rings ComfortRacing's Avatar
    Oct 03 2007
    Audi A4 quattro
    Richmond Va
    cylinder orientation for 1.8t?
    looking into the engine compartment from the front of the car which cylinders are which (i.e. #1, #2, #3 & #4)?
    2002 A4 Quattro 5-speed, KO4, SPP Ported/Polished Turbo Manifold, ATP test pipe, APR ko4 tuning, APR injectors, APR R1 DV, Front mount intercooler, H&R sport springs/Bilstein sport shocks, Neuspeed snubber mount K&N, Blackedout grille, Badgeless rear.
    To Do's:
    -APR Sport exhaust
    -Porsche seats, brakes and wheels
    -Recarro Baby seat =)
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: cylinder orientation for 1.8t?
    Depends on how you look at it. Its all about reference frame.
    I, typically, refer to cylinder #1 as the one closest to the radiator and cylinder #4 as the one closest to the firewall. If posting online (or in email) I typically also provide that information to inform the reader what my reference frame is.
    -Doug
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    /\ What doug said....
    Now, the firing order is different though :
    4
    2
    3
    1
    -Sami-
    Oct 03 2007
    Audi A4 quattro
    Richmond Va
    so if i am misfiring on cylinder 3 they arent refering to firing order but the 3rd cylinder back from the radiator?
    To Do's:
    -APR Sport exhaust
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by ComfortRacing View Post
    Yup
    Feb 19 2007
    Charleston, SC
    correct
    -Sami-
    Oct 03 2007
    Audi A4 quattro
    Richmond Va
    great thanks guys! of course had another bought with the coils so i have the "set" on order from ecs and will just replace the retarded one till they arrive with my spare.
    To Do's:
    -APR Sport exhaust
    Aug 26 2005
    4
    2
    3
    1
    Huh? The cylinders are numbered 1, 2, 3, 4, from the radiator end to the firewall end. The firing order is 1, 3, 4, 2, so starting from cylinder 1, the next cylinder in firing order is 3, 180 crank degrees after 1, then cylinder 4, 180 crank degrees after 3, then cylinder 2, 180 crank degrees after 4. All four cylinders fire once every two crank revolutions, or 720 crank degrees.
    Aug 26 2005
    Cylinder #3 IS cylinder #3, regardless of layout arrangement order or firing order. The cylinder number doensn't change depending on what aspect regarding cylinder number is being considered.
