Results 1 to 9 of 9
    Oct 01 2007
    Location, Location, Location
    A4 3.2 Starting troubles?
    The car is a 2007 A4 3.2 6MT. It has had this problem since I bought it. When I turn on the ignition (holding in the clutch) it seems like it takes a bit too long to start up. I hear (im guessing) the motor trying to start and it sounds like it can't the first time. We have a 2.0T in the family as well (auto) and it starts "faster" than this one. Just wondering if its something common or if something is wrong and I should call the service dept.
    Thanks.
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    Re: A4 3.2 Starting troubles?
    How old is the 2.0t, because from what i gather, they changed something with the fuel pump and the newer ones dont have that problem. I have it with my car. search cold start issue another 3.2 has it too.
    I asked my dealer and they told me its in the manual or something and it is normal for FSI engines. i dont buy this but whatever
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Oct 01 2007
    Both cars are 2007. And yes, it only happens to me when i leave it overnight or for more than a few hours. It is really annoying and it makes the audi line look bad...in fact that was one of the first things that my friend mentioned when I turned it on.
    Veteran Member Three Rings Zebman's Avatar
    Dec 25 2007
    '06 A4, 08 R6s
    Morgantown/Hurricane, WV
    Let the key sit at the accessory position until you hear the mechanics from the engine stop. The FSI pump will then be ready to optimally deliver fuel. When you don't allow it to prime itself, it cranks over a few times to build pressure in the cam-driven FSI pump. Tah-dah. It's not just Audi; welcome to direct injection.
    2006 A4Q 6MT Arctic White - StageII++
    STaSIS SS Coilovers, EVOMS Intake, APR 93, OZ Ultraleggeras 17x8, APR Exhaust w/034 HFC, GSG Intake Pipe, AWE Front Mount, APR HPFP.
    2008 R6s
    : Racebike, don't feel like writing it all out.
    I don't get on Audizine anymore, so if you need me... sorry.
    Oct 01 2007
    Ah, that makes sense! I'll try this from now on. Thanks for the info!
    Veteran Member Three Rings CX-7&A4's Avatar
    Dec 08 2007
    CX-7 AWD/A4
    Foreclosure Captial of the US
    Quote Originally Posted by Zebman View Post
    Doesn't happen in my CX-7(DI turbo). This sounds like an Audi thing.
    07 Mazda CX-7 AWD
    06 Audi A4 Fail2Trak CVT - TRW Front/Mintex Redbox Rear
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    i think it is a result of the fact that the pump is cam driven
    All go no show
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Quote Originally Posted by masteroc View Post
    no it doesn't because the fuel is also primed when the driver's door opens. but anyways don't know too much about this.
    Feb 23 2008
    Hmmm, I can't remember when this change was made, but the 2008 A4 models pre-charge the fuel assembly (for lack of a better word) when the driver's door is opened, so when you actually get into the driver's seat, put the key in the ignition and turn it, the car starts almost instantaneously. So, Audi acknowledged a problem in the past, and fixed it at some point, unfortunately I do not have the specific timeline of that fix.
    2008 A4 B7 3.2 Quattro 6MT, S-Line, Titanium, Ocean Blue Pearl, Prem BOSE, Cold, Conv, Volterra Leather, BT, iPod
    2008 A6 Avant 3.2 Quattro 6AT, S-Line, Night Blue Pearl, Prem, Nav, Milano Leather, Cold, iPod
    2010 S5 Prem+ 6MT, Brilliant Red, Black/Platinum, B&O, Nav, Sport Rear Diff, Mods...
