Results 1 to 6 of 6
    Jul 11 2007
    San jose
    HELP! Transmission control unit reprogramming
    I was told by the dealership that my transmission control unit needs to be reprogrammed for it to work with my car, does anyone know where i can take it to be reprogrammed? and at what cost?
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: HELP! Transmission control unit reprogramming
    What year car?
    What engine?
    What type of transmission (assuming auto)?
    What did you do to your car that requires it to be reprogrammed?
    -Doug
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    yeah, we need some more info.....
    assuming it's an auto.
    they might be trying to tell you that the TCU needs to be updated if you have a performance flash on your ECU, since the TCU does not know about the change in the power band the tranny shifts at the wrong points. Nothing you can do about this but maybe get a custom flash for your TCU. if this IS what he is referring to it's just the way it is for the most part since only the very high-end models also get a TCU flahs with the ECU flash (S6 and some others). just use the manual shift mode and you won't have problems.
    of course...... i could be totally off base with that and you just have a bad TCU and your dealer isn't talking about any of what i just covered.
    Jul 11 2007
    San jose
    sorry i was in a rush earlier
    it's a 2005 1.8t fwd auto cvt
    I just got the car recently and it started doing that. For the most part, I think the car is stock.
    Veteran Member Three Rings phantom b6's Avatar
    Apr 02 2008
    LA
    Ah yes.. I had the same issue. The TCU went bad, the gear display in the cluster would disappear or blink at all times.. Sometimes reverse wouldn't work.
    Audi replaced the TCU... cost $3000. I only paid $300 thanks to CarMax Coverage
    APR 1+ | 380cc Injectors | APR TIP | FMIC | Snow Performance Methanol Injection | ATP 3" Downpipe
    Established Member Two Rings tarzjdm's Avatar
    Jul 15 2007
    B6 1.8t FWd
    san dayGo
    My car is at the shop right now getting my TCU replaced. I'm not 100% sure, but I think it should come programmed since its a Vin specific item... good luck with that. I got lucky my extended warranty is covering it...
