Results 1 to 19 of 19
    Veteran Member Four Rings SeKKeY's Avatar
    Mar 06 2005
    MKVI GTI (dd), DTM S4, B6 USP (sold), B5 1.8T (RIP)
    San Jose, CA
    N249 removed...now DV flutters
    I did the N249 removal/bypass just as explained in the writeup a few threads down. However after, my diverter valve will flutter when i get off throttle (anywhere higher than 5psi, otherwise its normal). Any help to what causes this? My DV is hooked up in reversed position, and the vacuum line is directly attached to the intake manifold as per directions. The N249 is looped to itself. Any troubleshooting tips? DV going out? switch DV orientation? I don't want to run it too long like this because its probably bad for the K04.
    USP CLUB MEMBER #10
    Stage 2++++++++ JHM B7 S4
    Saint Cloud, Fl
    Re: N249 removed...now DV flutters
    It is normal for your dv to flutter under partial boost. If it flutters under full boost you have a problem.
    That is what it reads for my Spltr valve.
    instagram ------------> low_enforcement
    Veteran Member Four Rings initiala4's Avatar
    Feb 24 2004
    Land of the smiles
    Mmmm I wouldnt install it reverse though, but I remember when my DV flutters, it means I got a vacuum leak because my guage would read funny.
    2019 B9 RS4 - O.CT Tuning Stage 1 | Wagner Intercooler / Radiator | Ohlins R&T DFV | 034 Motorsports Dynamic + Sway bars | 034 Motorsports Transmission mount | Ignition Projects Coilpacks | HHC Rear rotor upgrade 370mm + Endless MX72 brake pads
    Formerly - 2003 Audi B6 A4 1.8T QM, 2013 VW Passat Variant 2.0 TSI
    Mar 06 2005
    San Jose, CA
    i have 21-22 inHg vacuum at idle and 25 inHg in gear... but my max boost is about 16-17 psi (should be 18-21 psi for APR K04)..if the vacuum is fine but the boost is lower, can there still be a leak?
    USP CLUB MEMBER #10
    Dec 12 2007
    mpk
    Quote Originally Posted by SeKKeY View Post
    i had the same problem... doing a boost leak check..i found that the vac line on my DV was torn.... vac was fine..boost was lower.
    o2 Silver 1.8TQM
    APR 1+
    Forge 007 DV
    Buncha motorcycles
    Memphis, TN
    Quote Originally Posted by antz View Post
    i had the same problem.. only boosting 18psi on 1+...did boost test and all kinds of BS.. DV was torn
    APR Stage 2/AWE Intake
    Feb 17 2005
    Sarasota, FL
    What spring in the DV?
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    i guess sit would depend on the DV, i don't know how a piston DV would function correctly if you had it in reversed since the pressure would only push on the side of the piston and not the bottom which is required to open it. I guess if this was the case though then the DV would never open which is not what you are experiencing.
    Mar 06 2005
    San Jose, CA
    APR R1.so no adjustable spring inside. i believe it is a diaphram type also, but im going to check for boost leaks/switch it around today
    USP CLUB MEMBER #10
    Veteran Member Four Rings BNZ TOY's Avatar
    Oct 29 2006
    1G FX35, 03 R6, B6 A4 MT6
    Vancouver
    Sorry, but how does the N249 removal/bypass cause this? Has it been confirmed?
    Possibly just a coincidence that your APR R1 is going bad?
    Another silver B6
    Go/Stop: K04-015 ~ Intake/TIP ~ Forge Splitter ~ Neuspeed turboback ~ B&M SS ~ H&R Sport w Bilsteins ~ S4 Sways ~ Eurocode FMIC ~ 245 Rotors/18z ~ FX300 240mm LWFW ~ Snow Meth Inj ~ EURODYNE tune
    Flair: USP Front ~ Cupra R ~ S4 Trunklip ~ Euro Roof Lip ~ VMR v710 235/19/35 ~ S4 doorblades ~ B7 rear valance ~ LED fogs ~ B7 DTM skirts ~ Euro RS4 Steering Wheel ~ S4 Recaros
    Veteran Member Three Rings phantom b6's Avatar
    Apr 02 2008
    LA
    I have the same DV and I don't have this issue. Perhaps the DV diaphragm has torn.
    APR 1+ | 380cc Injectors | APR TIP | FMIC | Snow Performance Methanol Injection | ATP 3" Downpipe
    Veteran Member Four Rings gdawg'05a4's Avatar
    May 03 2005
    '17 Q7, '95 Audi 90 AAN Swap
    Boston
    If you can, swap the lines back to the way they were and confirm if the same thing happens.
    '17 Q7 3.0T | Graphite Gray | Rock Gray || Prestige | Cold Weather | Tow
    '14 A6 3.0T | Daytona Gray | Black || Prestige | Cold Weather | Driver Assist | Rear Sunshades | 19" Sport
    EPL S2 + TCU
    '95 90 Quattro Sport MT5 | Pearl | Black || 20vT AAN swap
    Previous Cars:
    '12 S4 | '13 Q5 2.0T | '11 A4 2.0TQ | '07 A4 2.0TQ | '06 S4 25quattro | '05 A4 1.8TQ MT6
    Dec 18 2007
    nj
    the 249 removal is removing the valve that controls the pressure to the top of the DV holding it closed along with the spring pressure. this causes full pressure from the manifold to be constantly holding the DV shut and in turn allowing you to hold boost longer since the DV isn't opening. this shoudl not create a fludder unless you had a very light spring in the dv but it's not changable in the R1. like it was mentioned, it sounds like you have a rip in the diaphragm.
    Sorry about my previous post, i can see how a diaphragm dv would function in both directions, i just assumed it was piston since thats what i have :P
    Senior Member Two Rings inaforest's Avatar
    Sep 10 2008
    is full of junk.
    Los Angeles, CA
    I don't mean to change the subject, but does bypassing the n249 decrease the life of the engine?
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    The N249s sole purpose is to reduce flutter.
    Veteran Member Three Rings whiteUSPflow's Avatar
    Feb 22 2008
    2004 USP 1.8tQ, 2003 RS6
    Richmond, VA
    your not suposed to install that DV in the opposite way since it is a diaphram DV and it will tear. they have a life time warrenty so go to the shop you got it from and get a new one and install it the correct way.
    USP CLUB MEMBER #97
    APR tuned K04-Carbonio-Forge-Podi-Stasis-034 Motorsport-RAI motorsport
    Unitronic tuned RS6
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    ^^^ Like he said, don't install diaphragm DVs in the "reverse" position. That should help your problem.
    -Darrick
    Veteran Member Three Rings Killerteve's Avatar
    Nov 09 2006
    02 A4 1.8TQM
    SF
    What is bad about flutter? I used to get it with my K04 and Forge 007 but I just thought that's how it sounded with a aftermarket TIP and intake. Didn't have any vacuum leaks and still held strong boost, 26 spike, 22 hold on Revo stg. 2.
    REVO GT2871r Elim - 034 - Southbend - Racetec - Forge - HID's - RS4 reps - Podi - APR Snub - Tein - Genesis - Neuspeed
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Quote Originally Posted by Killerteve View Post
    Flutter on a piston type valve is a lot different than a diaphagm valve fluttering because it was installed the "wrong way". I might cause the R1 to "kick the bucket" and stop working. Which is what might be reason for the flutter in the 1st place - A RIPPED VALVE and also could lead to the decrease in boost pressure.
    Just a few thoughts
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
