Page 1 of 6 123 ... LastLast
Results 1 to 40 of 226
    Deactivated Four Rings
    Apr 09 2008
    Willow Grove, PA
    The Best Intercooler for the B7 A4
    The Best Intercooler for the B7 A4.
    Thats what we set out to design when we began developing our B7 Front Mount Intercooler.
    And after some extensive research and development, that's exactly what we engineered.
    What makes it the best?
    Tested and Proven Results:
    Data was collected on our Mustang MD-AWD-500-SE AWD dynamometer, on the street, and on various race tracks, using dual Omega DPi temperature meters outputting to the dyno's integrated data acquisition, and via a portable lab grade datalogger. Several runs were made recording temperatures and pressures before and after the stock and AWE Tuning intercooler assemblies and then averaged, with graphs of the changes shown below. All tests were done on our in house 2006 A4 2.0T quattro S-Line with our exhaust and GIAC chip installed. 93 octane fuel was used for all tests.
    Proven to Improve Intake Air Temps:
    Temperature drop is the measurement of how much heat the intercooler is able to remove from the intake air. The higher the temperature drop, the denser the air charge, resulting in more power and less tendency for detonation in the cylinders. Our design was able to hold intake air temperatures at redline to almost the same level as at 2500rpms, while the stock dual intercooler design allowed temperature to climb with rpms.
    Proven to Reduce Pressure Drop:
    Large intercoolers can do well in reducing intake air temperatures, but they can also introduce a lot of restriction to the intake air. That restriction will result in power loss even with the improved temps. Too much intake flow restriction means the turbo cannot deliver as much boost to the engine. Our design not only excels in temperature drops, but also in how pressure restriction is minimized to levels less than the dual side mount stock configuration.
    Proven to be more efficient the stock Side Mount Intercoolers:
    Intercooler efficiency is a way to determine how well the intercooler is able to handle heat removal, and any rating of 80% efficient or above is outstanding. Our design at its least efficient is still 93% effective even on a GIAC chipped A4, whereas the stock design takes a nosedive to near 77% at redline on the same GIAC chipped car.
    Proven to add dyno verified gains from Stock to Big Turbo Horsepower Levels:
    Power test of our Front Mount Intercooler design vs stock. The stock turbo is running near its capacity when chipped, producing more heat than at stock boost levels. Installing our Front Mount Intercooler reduced heat tremendously, to produce a cooler, denser intake air charge, resulting in a very nice increase in power as the rpms rise (nearly 14 crank horsepower when converting from the dyno sheet wheel power measurement). Even more impressive results were seen with our prototype GT28 71R turbo kit on this car.
    How did we achieve these results?
    Research and Development
    When most people see our B7 Front Mount Intercooler in person, their first reaction is typically “That thing is huge!”.
    It’s true, our FMIC is larger then any other design currently on the market. Where most Front Mount Intercoolers for the B7 are small enough to fit into the lower portion of the front grille, ours utilizes the space behind the OEM crash bar to give you the largest possible surface area.
    However, intercooler design consists of more than just finding the largest core that will fit on the front of the car. Exposed frontal area, number of pressure charge rows, cooling fin count, and end tank geometry are some of the key parameters that need studying when embarking on an intercooler project.
    Our Front Mount Intercooler Kit utilizes the entire area behind the front grille to give you the largest cooling surface area possible; the exposed frontal area is nearly double the size of the stock side mount intercoolers.
    We analyzed several smaller intercooler designs before realizing our production version was the best possible solution. Had we been able to bolt on our already proven B6 Front Mount Intercooler Kit and improved performance we would have, but in our testing this was not the case. There was no FMIC design that would fit neatly into the lower portion of the grille that could improve on the stock SMICs performance and require no modification to the OEM crash safety system.
    End Tank Geometry
    Below is a screenshot from our Computational Fluid Dynamics (CFD) software demonstrating the clear superiority of our end tank design vs the more common box shaped end tank found on most aftermarket intercoolers.
    While a box shaped end tank is much simpler to design and fabricate, the amount of turbulence created (show in red, orange, and yellow) results in very inefficient cooling and air flow through the core.
    Our end tank design went through no less than 14 revisions while we maximized performance. Our end tank design is the key to why we can use such a large core without tremendous pressure restriction issues. Our pressure drop is half of what the dual side mount system provides, while also providing nearly a 30F degree temperature drop vs stock.
    The Entire Kit:
    Key product features:
    • All aluminum construction, including tubing, for maximum heat transfer
    • Bar and plate core construction
    • Cast aluminum end tanks with inlet baffle
    • 2.5 inch diameter mandrel bent aluminum tubing
    • Stainless steel t-bolt clamps with heavy duty silicone couplers
    • Replacement power steering cooler assembly
    • Direct Bolt In, no modifications required for fitment
    Some other things that should be mentioned:
    We did extensive testing to measure the affects our FMIC would have on coolant temps and the stock AC. The results? Extensive track testing with ambient temperatures above 100º F showed no issues at all. This test was very important because we saw problems when testing various FMIC on the B5 S4, so we wanted to be sure the same issues did not come up in this application.
    Our design features 26 charge rows compared to 15 each for the stock SMIC which is a tremendous advantage, but our bar and plate design is also much more effective the a stamped end plate design. That equals lower pressure drop, a smoother path for the air to follow and more power.
    Each and every completed intercooler assembly is leak checked up to 30psi in a water dunk tank before leaving our facility. This is sadly a rarity in the Automotive Tuning World. Just one of the steps we take to ensure that your A.W.E. Tuning FMIC performs how it should and one of the reasons our products stand above the rest.
    Our kit is features aluminum tubing for extra heat exchange. Stainless or mild steel tubing as used on other kits, while easier to bend and form, does not have the superior heat transfer characteristics of aluminum. Using aluminum for our tubing maximizes the area where heat is able to be wicked away from the intake air going to the engine as aluminum transfers heat much better than steel.
    No performance product is worth taking away any important crash safety features these cars are equipped with. With our FMIC kit, no permanent modifications to the car are required. Our kit doesn’t ask you to cut bumper supports or modify/remove crash beams. This means that your cars crash safety is kept in tact.
    The best part about this unbeatable FMIC kit? It’s in stock and ready to be shipped.
    If you would like even more information about our B7 FMIC, feel free to shoot me an email at [email protected] or call us at 888-565-2257.
    You can also visit our website for more technical and pricing information: B7 A4 FMIC Section.
    May 11 2008
    Naples,FL
    Re: The Best Intercooler for the B7 A4
    that thing is amazing....and a beast
    2.0 T Quattro - 20% tint,hardwired 9500i,alpine 757 amp,alpine 12" type r sub,RS4 Sway,Giac X-chip, VMR 19 710's wrapped in Conti Extreme DW, H&R Coilovers .
    Senior Member Three Rings CapstoneJHS's Avatar
    Nov 12 2006
    '06 A4 2.0T Quattro
    Marysville, OH
    Quote Originally Posted by Alex/A.W.E. View Post
    SolidWorks?
    Veteran Member Four Rings Glassnpowder98's Avatar
    Mar 07 2008
    Audi A4 B7
    VA
    It's next on my mod list... Just gotta save up after blowing my "mod savings account" on quad tips from you guys.
    05.5 A4 2.0T Brilliant Red 6MT: Put some money and time into it...
    The only standing start, straight line racing I enjoy is on the way to the first corner.
    Veteran Member Four Rings vtracer20's Avatar
    Apr 14 2008
    Milton VT
    ahahah ^im in the same boat
    2007 A4 S-Line / Ti Pkg / Quattro / Bilstein Pss9 / JHM Short shifter / GIAC X+ chip / RS4 rear sway bar / 20% rear tint / 10mm front 15mm rear spacers / Forge DV / DTM CF replica rear lip spoiler / DTH CF roof spoiler / Cupra R front spoiler (not on) / Infinity BasslinkII sub
    looking for: CF front lip / S4 alum mirror hosing
    Veteran Member Three Rings 07audi4's Avatar
    Dec 06 2006
    2007 audi a4 2.0T quattro
    rochester, new york
    The AWE Front Mount is amazing, I rock it all day everyday! It does its magic with the Ko3, I can only imagine how much the BT will appreciate it. Some other intercoolers might be cheaper but I doubt they are tested like AWE tests their stuff. With AWE its always a guarantee, they always make me happy.
    2007 AWE Tuning Audi A4 2.0T Quattro
    APR Stock 91 93 Race / Evolution Motorsports Intake / AWE Tuning Front Mount Intercooler / AWE Tuning Downpipe Back Exhaust / Neuspeed Race Springs / H&R S4 Front And Rear Sway Bars / Fog Light Mod / 10% Tint With Custom Audi Emblems In Rear Windows
    Veteran Member Three Rings johntesi's Avatar
    Jan 17 2008
    Evolution X
    Texas
    Cool? yes. Wish I had one? Hell yes!
    Repost?
    Sadly, yes.
    Veteran Member Three Rings Zebman's Avatar
    Dec 25 2007
    '06 A4, 08 R6s
    Morgantown/Hurricane, WV
    I still want it! But can't afford it until next summer.
    2006 A4Q 6MT Arctic White - StageII++
    STaSIS SS Coilovers, EVOMS Intake, APR 93, OZ Ultraleggeras 17x8, APR Exhaust w/034 HFC, GSG Intake Pipe, AWE Front Mount, APR HPFP.
    2008 R6s
    : Racebike, don't feel like writing it all out.
    I don't get on Audizine anymore, so if you need me... sorry.
    Veteran Member Four Rings Geoffafa's Avatar
    Aug 31 2007
    The Big Blue Bitch and her mess
    Miami
    impressive post and research, i must say i am impressed.. will consider... have you guys done any logs with water/meth to see if i could help out even more?
    F.T.W.L.T.B.D.W.I.C.T.W.
    IG | @fukn_fafa
    So air is like the hot girl that is no fun in the sack, and good coils is the cute girl that is crazy in the sack. -chrislane
    Veteran Member Four Rings EMAXX's Avatar
    Jul 12 2008
    I really need to save up some more money so I can start adding some more mods.
    Established Member Two Rings positiv_rate's Avatar
    Apr 26 2008
    '15 Audi S4 // 04 BMW E46 M3 // 22 Audi SQ7 // '12 BMW E91 328xi
    Montreal, QC
    How about the stock SMICs from the B5 RS4? Do they fit on a B7? Would they show an improvement over the B7 units? I like my OEM+, can you tell?!
    2015 S4 // Technik+ // Mythos Black // 6MT // Sport Diff // Bose
    APR Stage 2 DP | APR Open Carbon Intake | AWE S/C inlet hose | JHM short shifter | Eurocode headers | JHM baffled hi-flo cat downpipes | 034 drivetrain mount inserts | 034 rear swaybar | CR-15 | ECS SS brake & clutch lines | ECS 8mm/12mm spacers | Tyrolsport caliper stiffening kit
    2022 SQ7 Technik | Daytona Grey Pearl/Black Optics & badges | Arras Red | Red Calipers | Black Alcantara Headliner | Tow Package
    Veteran Member Three Rings jimmya4's Avatar
    Aug 21 2008
    A4 b7
    The OC/ Boulder, CO
    of course this requires getting rid or cutting the front bar out? doesnt make me feel good about a crash
    2005.5 Quartz grey A4 Quattro 6mt/ REVO stage II
    Veteran Member Four Rings Hockenheim's Avatar
    Jul 09 2007
    Phoenix
    Quote Originally Posted by jimmya4 View Post
    fack that, any mod that requires body chasis manipulation = not worth it
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    E46 M3
    PA
    -Kris
    Dec 06 2006
    rochester, new york
    ^ Hes right, This kit bolts up without removing any factory equipment. It is one of the few kits that also allows you to run OEM fog lights. The bumper support must come off for install but once the FMIC is hanging the bar fits right back over it
    Active Member Four Rings SEXICN's Avatar
    May 20 2004
    More cars
    Never Land Ranch
    I just want to wait till i can get it for $300-$500 (hoping my dream comes true soon)!!
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    AMD/EPL Tial 605 B5 S4 SOLD
    Apr 15 2007
    WNC
    Quote Originally Posted by SEXICAN View Post
    And how will this happen?
    2013 RS5, 2014 Q7
    Aug 21 2008
    frederick
    group buy discount please?
    May 20 2004
    More cars
    Never Land Ranch
    Quote Originally Posted by rnp614 View Post
    I have my ways....
    in life, it's all about who you know
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    Apr 15 2007
    WNC
    Would an intercooler provide more real gains than an exhaust?
    Edit: What about if you have a k04?
    2013 RS5, 2014 Q7
    Veteran Member Four Rings Sly Raskal's Avatar
    Jan 22 2007
    Fontana, CA
    Any chance that you guys would offer a black painted setup like EuroA4 did?
    http://www.audizine.com/forum/showthread.php?p=2852841
    Having one with the black coating that is also tested by your facility to show that the benefits of adding it our cars would be a plus in my book.
    Back I go to saving up for all my mods, including this one, hopefully painted black.
    -Anil
    2019 A4 Sedan, Nardo Gray, 45TFSI, Prestige Plus, S-Line, Quattro, Black-Optic, PPF, Ceramic Paint Coating, Ceramic Tint, Audi Black Door Handle Kit
    Dec 25 2007
    '06 A4, 08 R6s
    Without a test pipe, yes.
    Larger turbo = hells yes.
    2008 R6s
    Veteran Member Four Rings fusionx's Avatar
    May 16 2008
    07 A3 2.0T
    Socal / Boston
    pretty legit intercooler but does it take out the front steel safety bar for accidents or w/e ?
    07 A3 2.0T S-line - REVO stage 2 - GIAC DSG Flash - AWE downpipe - Custom staggered quad-tip exhaust - H & R springs - H & R sway bar - Neuspeed CAI - fog housing LEDs - VMR boost gauge - JL 12'' Sub w/ Precision Power Amp
    Instagram: @superseany
    CanyonRacerMotorsports
    Project Matte Black: COMPLETE
    Aug 21 2008
    A4 b7
    The OC/ Boulder, CO
    Quote Originally Posted by fusionx View Post
    these guys are saying it doesnt. direct bolt on doesnt mean keeping the steel bar in my english you might directly bolt the fmic on after directly unbolting your oem steel protection bar. whats the real answer?
    Jul 12 2008
    You take off the front brace to put it on, then it gets put back in place in front of the FMIC. The safety bar stays. Don't worry about. Look at EuroA4's pictures.
    Veteran Member Four Rings Erocko's Avatar
    Feb 16 2008
    Honolulu, HI
    yeah, they just show it without the bar in their pics.
    http://www.audizine.com/forum/showth...light=awe+fmic
    Current: 2019 B9 A4 Quattro
    Former: 2016 8V A3 Quattro, 2011 Mk6 GTI DSG 4-door, 2005.5 B7 A4 2.0T FWD CVT
    Senior Member Two Rings DOBERMAN@UA's Avatar
    Sep 15 2008
    A6 c6 3.0 Tdi (300hp)
    Ukraine, Kiev
    HI, on the picture Entire Kit(in upper left corner) is that a bottle neck?
    That pipe is much thiner than other parts of kit!
    What about flow restriction and higher pressure in that part?
    A6c6 3.0 tdi(300hp), koni sport shocks, eibach pro kit springs, q5 4pot brake calliper, a8d3 sport seats
    Veteran Member Four Rings muffinman's Avatar
    Jul 01 2007
    Ask, USA
    Quote Originally Posted by hockenheim
    do you guys NOT READ???
    quoted from AWE's original post:
    2015 Audi S3 Prestige with Performance Package - on order
    2015 Audi Q3
    2009 Audi S5 Coupe - Tiptronic, B&O, Technology Package, Navigation, Carbon Atlas
    2009 BMW 328i
    2007 Audi A4
    FS: CPO 2009 Audi S5 - Tiptronic - Warranty - Seattle, WA
    Veteran Member Four Rings EuroA4's Avatar
    Feb 12 2004
    PA-NJ
    Quote Originally Posted by DOBERMAN@UA View Post
    That's the pipe that meets the turbo itself (which is only 2.25" wide) so the pipe transitions down from the core pipes to the turbo itself.
    You don't loose any saftey equipment with this...the crash bar comes off for install, then reinstalls in the factory position. No cutting or trimming of ANYTHING!!!
    Bump...for a great product in terms of performance, quality and especially fitment!
    Sep 15 2008
    Ukraine, Kiev
    Quote Originally Posted by EuroA4 View Post
    What the size of garret 2871 which is going tobe released soon? 2,25 or 2,5?
    IF AWE says that it is capable for BT, so 2,25 I guess?
    The main idea is that in that part air pressure would be greater than in other parts of system!
    Veteran Member Four Rings Vito Roma's Avatar
    Oct 08 2007
    Syracuse, NY
    wow great numbers!!
    '12 Bril. Black A4 2.0T/Quattro/Prem+/Sports package
    SLine body/Sline Door sills/3 spoke pref wheel w.Paddles/Sport seats/VMR 708 Matte Black(19x8.5) **For Sale**/Custom Black OEM caps/35% Tint/Needle Swipe/Fob/"Wink" & Amber Delete/More VagCom/RS4 Grille/ Hoen Endurance Fogs/ST Coilovers *Sold* /Debadged/V1 w. Concealed display *Sold*
    Sep 15 2008
    Ukraine, Kiev
    How much it would cost to deliver this stuff to Ukraine?
    Apr 09 2008
    Willow Grove, PA
    Quote Originally Posted by Ih8OEM
    I am not aware of any testing done with water/meth. I will talk to the Head of our Engineering Department and if we have indeed done that testing, will post what he has to say.
    Quote Originally Posted by Hockenheim
    We completely agree with you here! That extra hp won't help keep you safe in a head on collision. Like IceMole and 07audi4 pointed out, our FMIC does not require any modification to the stock crash safety system. You have to remove the front bumper support during installation, but it bolts right in after the intercooler is in place.
    I do not know of any plans to offer the IC with any sort of coating. If this changes, we will be sure to post up more information.
    Quote Originally Posted by Zebman
    Quote Originally Posted by EMAXX
    FMIC >> Food.
    Apr 09 2008
    Willow Grove, PA
    Check your PMs!
    Mar 07 2008
    Audi A4 B7
    VA
    More like... FMIC > Food = A.W.E employees eating filet mignon
    Alex, did you ever get the PM I sent?
    Apr 15 2007
    WNC
    was there/is there a group buy on this?
    2013 RS5, 2014 Q7
    Apr 09 2008
    Willow Grove, PA
    Quote Originally Posted by Glassnpowder98 View Post
    You've got a pm. I just needed to check something before getting back to you.
    Jan 17 2008
    Evolution X
    Texas
    A group buy with a significant discount would be quite attractive and I'm sure a lot of us would skip a few meals if the deal was good enough!!
    Apr 15 2007
    WNC
    Quote Originally Posted by johntesi View Post
    I'm sure we'd all appreciate our ride weight decreasing a little ;)
    2013 RS5, 2014 Q7
    Apr 15 2007
    WNC
    Question about the dyno numbers. It says 14chp on a chipped car. I noticed the chip you used was the GIAC and not the X / + chip. Whats it do on the more aggressive tune?
    2013 RS5, 2014 Q7
