Results 1 to 9 of 9
    Veteran Member Four Rings 3.0L AUDI A4's Avatar
    2004 A4
    Central Jersey
    My xenon headlight intermittently turns off, then back on.
    I have a 2005 A4 1.8T USP. When I get into the car at night, both xenon lights are on, I start driving... couple minutes later, I see the passenger side headlight turn off, the bulb out warning comes on "dipped right headlight" then shows a O with an X in it (bulb out), then the xenon light will come back on eventually. Sometimes it will flicker a few times, sometimes it will be once. regardless, this is a huge problem that I have! What should I do?
    I had my friend drive my car and I drove in front of it in another car at night to see what it looks like, it looks like its winking at me lol
    Help?
    Thanks, Matt.
    Senior Member Two Rings GermanAudi's Avatar
    Jun 01 2008
    2003 Audi A4 1.8T Multitronic
    San Diego, CA
    Re: My xenon headlight intermittently turns off, then back on.
    Check your ballasts. When ballasts reach their end of life, they start cycling -- that could explain the flickering that you are seeing.
    2003 1.8T Multitronic CVT, Canvas Beige Metallic
    GIAC Stage 1 || 710N TT Diverter Valve || 6000K Xenon HIDs || VMR Vent Boost Gauge || Eibach Pro/Bilstein Sport Suspension
    Active Member Three Rings lowestA4's Avatar
    May 08 2005
    hanover germany
    Check the bulbs first (swap left and right) to identify if it's a bad bulb or a bad ballast. Mostly it's the bulb only.
    lowestA4 -- Germany based parts collection & experienced overseas shipping since 2004. German engineering meets passion.
    Veteran Member Four Rings jbrown7815's Avatar
    Mar 12 2008
    Portales, NM
    Ok I had same problem, and jumped to conclusions and bought bulbs. It ended up being one of the wire/connectors going to the ballast. SO take it apart and jiggle wires, etc around.
    Veteran Member Four Rings El_Chapusca's Avatar
    Jun 06 2008
    Long Island, NY
    Is there a change in color temp Thats what happen to mine
    -Joey aka Chappy
    GCC Law/Rule #22 Enforcer.
    GCC: Its Serious Business
    Tastefully Modded
    Senior Member Three Rings demea's Avatar
    Jun 12 2008
    2004 A41.8q | 05 Tr. Blzr LT
    Warminster, PA
    Aftermarket or OEM?
    2004 Moro Blue A4 1.8TQTip
    GIAC | Genesis | Forge | Magnaflow | RS4 | ABT | Sport | Premium | Cold | Dings mod ~ Painted lowers are overrated
    Want to see a fun coverband in the Philly area?
    2004 A4
    Central Jersey
    OEM, NO change in color. I will try swapping each side and see what that does... If anything, I guess I will need to buy a bulb.. or ballast.. Wish me luck!. LowestA4, If I need a bulb, I will let u know. Thanks for the PM
    Registered Member One Ring Turturelo's Avatar
    Sep 20 2008
    '03 Audi A4 Avant S-line
    Bulgaria
    ^ I have the same problem. Was the bulb or the ballast in your A4?
    2004 A4
    Central Jersey
    I switched the bulb sides and the bulb is broken not the ballast.
